Samsung HP-R5072 50 in. Plasma HDTV Logo
Anonymous Posted on May 30, 2010
After one hour or more, the lower part of the
We own a Samsung HP-R5072 Plasma TV. After one hour or more, the lower part of the screen goes black. This black screen comes and goes and then stays for 15 minutes or more. Last night the lower screen had striped white, red, yellow stripes. This is too much. I hope you can help
  • 1 more comment
  • Anonymous May 31, 2010
    WHEN YOU NSAY LOWER PART IS IT FROM THE MIDDLE GOING DOWN
    Middle going down. It seems to be temp related. It takes longer to black out half way if the AC is on and the house is cooler. Make any sense?
  • Anonymous Jun 02, 2010
    Yes it goes black from the middle down to the bottom of the screen.
    Thanks
A
Anonymous
THIS LOOKS LIKE A LOWER Y BUFFER
Testimonial: "Thanks for your insight. Now I need to get a repair man in to do the job. Or is it something I could do myself?"
  • Anonymous Jun 22, 2010
    YES ITS EASY TO REPAIR
    1 UNPLUG TV
    2 TAKE OFF BACK COVER REMOVE PLASTIC COVER BUTTOM MIDDLE THATS PART OF THE CABLE HOLDER ,AFTER TAKE OF MIDDLE METAL COVER THAT PASSES OVER CONNECTERS DONT FORGET TO UNSCREW VGA SCREWS BEFORE .
    3 REMOVE BUTTOM SCREW ON BUFFER BOARD ONLY ONE
    4 UNDU TOP CONNECTER BY LIFTING IT UP DELICATLY
    5 DISCONNECT THE 3 BROWN FLEX CABLES BY LIFTING UP
    6DISCONNECT THE BIG BLACK CONNECTER AND THE WHITE ONE BESIDE IT BY SLIGHTLY PULLING THEM OUT OF THE Y MAIN PCB HOLD THE PART FIRMLY AND WORK IT OUT DELICATLY .
    PICTURES 1 BACK COVER 2 PLASTIC COVER 3 Y BUFFER 4 WAY TO POSITION YOUR (TWO) HANDS TO PULL OUT BOARD
My samsung 50 inch plasma tv has a black and white 2 inch stripe from top to bottom one third from the left side of tv our tv is about 1.2 years old is there a addjustment to be done ? thank you from mike
Image retention, Go to Menu and I believe pic settings go to the Burnin Scrolling feature..Will run white and black in full screen, run for an hour problem huold be solved..Happened to mine and the scrolling feature got rid of it.
I have 2 vertical black line in the left botton, space by an inch and they are going un to mid screen
Hi.
It is probably a defective buffer board. In that case the lines will be positioned in correspondence of the buffer board connection to plasma panel. In less frequent cases the problem can also be a defective plasma panel. There are more faults that can cause the problem. The TV must be tested.
Here parts for this set: Samsung HP-R5072 shopjimmy.
Regards.
Ginko.
HP-R5072 50 in. HDTV Plasma Television Samsung Plasma TV is snowy/dotted. When I turn it
Most likely it sounds like a Logic Board problem. The Logic Board is what controls images on the screen. It's a somewhat expensive part to replace. Maybe in the $200 range. Being that the part isn't cheap, best to have a TV tech come to your house to take a look at the TV to confirm the diagnoses before buying the replacement part.
4helpful
BOTTOM HALF OF SCREEN GOES BLACK R A MINUTE OR SO THEN RETURNS T NORMAL
remove the back of the tv.disconnect and reconnect the ribbon cables into your buffer pcb.if this does not correct the problem replace the buffer pcb in that location where the screen is going black.you also could have
a defective panel if the buffer pcb does not correct your problem.
50" Samsung Plasma HP-R5072
it is a myth about how the tv is positioned, if you have audio but no video then it is probably the y-main bopard or the y-scan board, if you replace the y-scan buffer then you have to replace the y-main at the same time, if the tv is in warranty call 1-800-samsung
Samsung Plasma 42" TV - 2006
Hi, this is quite a common problem for plasma screens and LCD screens. The fluroscent backlight is more than likely faulty and would need replacing. The best thing to do is to take it to a service centre because there are no user servicable parts inside the plasma.
Samsung 50 in dlp
It sounds like the Screen is coming to the end of its life. Has the screen been recently moved or dropped? Plasmas tend to lose its contrast after 60,000 hours of use. It could also be a loose connection from your source to your TV. Have you checked all your connections to the TV?
HP-R5072 50in.
If the band is vertical in nature and it goes from top to bottom then you might just have a bad address board. This requires a technician to look at it and replace it.
Screnn going blank
sounds like sky tv issue, try different cabling
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
