Question about General Electric Adora GHDA670N Built-in Dishwasher
Dishwasher isnt filling up with water the arms inside arent spinning and it shuts off after 3 minutes.
  • GE Master
  • 43,501 Answers
Here is a tip the will elaborate on your problem more, but the bottom line is that you need to replace that fill valve...
Dishwasherdishwasher isnt filling up with water the arms - 2_bing.gif Trouble No Water entering Dishwasher2_bing.gif
http://www.fixya.com/support/r4021363-dishwasher_trouble_no_water_entering
heatman101
Posted on May 31, 2010
I have to initate the spinning of the sprayer arm.
uasally it isnt the spinning of the spary arm that does the fill it is controlled or a timed fill then the motor comes on if there isnt enough water in the unit it will not have enough pressure really need more info though
Jun 02, 2010 | Dishwashers
Kitchen Aid dishwasher is not cleaning like it use to
Check the following to address this issue further.
1. No water
Make sure you get water to the dishwasher. Check to see if the water shut-off valve (located under the sink) is open. If you get water to the dishwasher, but there is still no water inside during the fill cycle, the problem might be with a faulty water valve (located at the bottom of the dishwasher, behind the kick panel, on either side), in which case replace the water valve.
2. Not enough water
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
3. Clogged spay arms
There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
4. Water temperature is too low
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
5. Not enough soap
If you only fill one part of the soap cup, try adding soap to both parts.
6. Smoky film on dishes and glasses
This problem occurs due to excessive calcium build up inside the dishwasher. Try cleaning you dishwasher using a dishwasher cleaner. There are a few out there.
Jun 21, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Dishes not getting clean
Check the following to address this issue.
1. No water
2. Not enough water
5. Not enough soap
Jun 19, 2009 | GE GLD4600NCS Built-in Dishwasher
Just a little water seems to be coming into the dishwasher and the dishes are not getting clean even on the Potscrubber cycle
1. No water
2. Not enough water
5. Not enough soap
Jun 06, 2009 | GE Dishwashers
My Bosch Dishwasher doesn't clean
Check the following to address this issue--
1. No water
2. Not enough water
5. Not enough soap
Jun 02, 2009 | Bosch 24 in. SGS47E02 Exxcel Free-standing...
Arms are not spinning
If the spray arms arent clogged up then you have a clogged filter.
Please Rate this !
Jun 23, 2008 | Frigidaire 24 in. FDB1050REC Stainless...
Residue left
make sure the screens in the unit are clear,also check that the wash arm holes arent obstructed or the arm isnt cracked at the seams.let me know.also is the unit getting hot?
Dec 13, 2007 | Smeg 18 in. DWF410SS Slim-Line...
Upper washer arm not rotating on KitchenAid dishwasher
check and make sure the arm holes arent clogged or the wash arm isnt cracked at the seams,also check the screens in the tank for obstructions,let me know.
Nov 27, 2007 | KitchenAid KUDC25CH Dishwasher
TUW model - not cleaning fully, top sprayer does not spin
make sure the wash arm holes arent obstructed and the wash arm seams arent cracked.
Sep 17, 2007 | Champion 24 in. UH-150B Built-in...
Water not going through spray arms
1.does motor run? no. replace motor. 2.open door and leave the bottom rack inside dw.spin the spray arm underneath the bottom rack by hand. it should spin freely without binding. if it doesnt spin freely take out the bottom rack and try again. if it does spin freely then your bottom rack is laying on your sprayarm preventing it from rotating. 3.you could also not be getting enough water into your dw.
Mar 21, 2007 | Frigidaire 24 in. FDB421RF Built-in...
General Electric Adora GHDA670N Built-in Dishwasher Logo
135 people viewed this question
Top GE Dishwashers Experts
Mike
Oloyede Monsuru
Are you a GE Dishwasher Expert? Answer questions, earn points and help others
