Question about RCA HD50LPW42 50" Rear Projection HDTV
ATC 336 Thanks for the solution. You mentioned it being the capacitors. I did smell something that resembled burnt electronic components. Well, I am a software geek and not a hardware geek. Could you recommend a guide on how to replace them or where I should go to get it done and maybe be a gestimate on how much it may cost. Would you also recomend on just getting a new TV because these RCA's just seem to be craping out a lot. I also already had the light engine, sound board and light bulb replaced on this particular set. Again, thanks for the addvise.
  • Gigagrunt Apr 08, 2008
    Thnx. I will look into it some more.
  • RCA Master
  • 8,617 Answers
Sadly, most repair shops are getting away from component level repair and want to do module replacement which would be between 4 and 6 hundred. I can give you a link to a site that I am part owner of as well as a support tech. We sell service manuals and provide free tech support as well as sell replacement parts.. If you can solder I would recomend that route as putting alot of money into a new module. If you would like to try to repair it with free tech support just look on the rear of your set for the Chassis number and go to the following link,
http://servicemanuals.vstore.ca/
let me know if I can help you further.
Posted on Apr 08, 2008
Got it new at Walmart in 2006? Never had any problems with it, and always had a surge protector. I know the kids have abused it though. Anyway, yesterday they had a pink, washed screen, turned it off/on...
No.The tv video board have dead components,that the board where it is connected to the CRT-(tv picture tube).Troubleshooting that video board and changes parts should fix ur tv problems.Hope ur tv problems,it is not the video board main big IC colors processor inverter.This big IC is a pain to change and probally not in the market anymore.Troubleshoot test all the capacitors around that big IC colors processor inverter alot of times just those few capacitors are dead only.
Apr 02, 2011 | Sanyo HT30744 TV
Printer smells
it may be ur power board.
discconnect it from power first and leave for 2hras
Jun 22, 2008 | Konica Minolta magicolor 2400 Laser...
Tip
Power supply repair for ATC 336 chassis HD50LPW175
I have seen quite a few of the ATC336 have dead capacitors in the power supply preventing start up . The capacitors in question are CP647, CP624, CP639 and CP641 all were bad. Replaced these capacitors and the sets powerd up and operated
on Feb 23, 2008 | RCA HD50LPW175 50" HDTV
I have a pioneer vsx-9900s- was running it hard for New Year's and at the end of the night it started to smell and then the sound stopped dead. The front panel and all controls work, but no second click-...
If the thing smells you shouldn't need any test equipment apart from your eyes and nose. That should lead you to something burnt up! Unlikely you will encounter any high voltage parts.
Jan 02, 2011 | Pioneer Audio Players & Recorders
Capcitor Burnt
the capacitor has value printed on it. if it is not burned you can still read it.
Aug 24, 2009 | KitchenAid KSB560 5 Speed Blender
I also need a service manual for the mets cl4
BE CAREFUL!!!!! FLASH GUNS ARE EQUIPPED
WITH CAPACITORS THAT STORE HIGH VOLT-
AGES TO DISCHARGE THE FLASH. IF YOU
ACCIDENTALLY SHORT OUT A CAPACITOR
WITH YOUR FINGER OR HAND, SERIOUS IN-
JURY OR WORSE COULD RESULT!!!
Jun 20, 2009 | Metz mecablitz 45 CL-4 TTL Flash
Burnt part. no pic. no sound
You can get them online at http://www.partstore.com . they run about 55.00 each part
Nov 23, 2008 | RCA HD56W58 56" TV
Won't power on. Burning smell, High pitch arcing sound,
I have a HD56W58 and it had the same problem. One day the picture went blank and then it made a loud popping sound and smelled like something burning. Now it will not turn on. Has this happened to anyone else? I
Jul 20, 2008 | RCA HD56W58 56" TV
Update Graphics Card + PSU and my computer DIED.... please help
as u mentioned yea if ur computer smelled lyk sumthing is cooking so may b da capacitors or da chip inside them myt be burnt by heavy game called GHOST RECON so it is possible ur motherboard is half burnd half fine lol
Nov 17, 2007 | Intel Motherboard
SDM M51 major problem
Based on your post/description, the "fizzling noise and a smell of ozone" are indicators of electronic component(s) that burned. Should you be comfortable and have a fair knowledge of component level repair, soldering and the use of a VOM then it is possible to repair it yourself. The inside would basically be divided into 3 electronic group; 1. power supply; 2. video; and 3. illumination. This should be fairly straight forward since the "fizzling noise and a smell of ozone" indicators would also be visually apparent. Fizzling would normally be capacitors leaking their oil at high temp/high pressure. this would probably be in the power supply section (but the other 2 groups have their own capacitors also). Smell of ozone would usually come from high voltage arcing which is only present in the inverter circuitry of the illumination. It is the group responsible for supplying the high voltage high frequency supply of the small fluorescent tube (CCF) that provides the backlight of the display panel. As earlier mentioned, it has also its own capacitors. If for some reason you do not feel comfortable opening and working the electronics inside, you might be better off seeking the services of a qualified professional. Good luck and kind regards. Hope this gives you and idea and how to go about it.
Aug 20, 2007 | Sony SDM M51D 15.1" LCD Monitor
RCA HD50LPW42 50" Rear Projection HDTV Logo
124 people viewed this question
Top RCA Televison & Video Experts
jason
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
