Question about Olympus SP-350 Digital Camera
Please help Hi there, thanks for helping me. I have tried putting my memory card into my computer but it will not read so how can I back up the files?
  • kit101111 Apr 09, 2008
    It won't let me open the files because it says I need to format it. Is there anyway I can download the images before I back it up and reformat?
    President:
  • 1,944 Answers
What happens on your computer when you put the card in?
Posted on Apr 09, 2008
In sert SD card turn on camera. screan shows Memory card refquires formatting, continue and stills reads card needs formatting. put new card in and does the same. Camera does not read card always say card...
Hi halestone26,
I would like to help you out with this problem ,
Please follow the below instructions :-
  1. Make sure that your remove the memory card out of the camera and connect it to your PC via a card reader.
  2. After you connect the memory card , to your pc via a card reader , you should get a removable drive icon relevant to your memory card in your my computer folder.
  3. Then all you need to do , is select format by right clicking on the card , and then when you see the options in format dialog box you need to select the NTFS and FAT32 one at a time and format the memory card and then check if it works with NTFS file system in your memory card or FAT32 file system.
  4. Unless your memory card is damaged , the above solution works 90% of the times.
Hope this helps ..:) Your feed back would be appreciated.
Jun 21, 2011 | Kodak EasyShare DX4530 Digital Camera
My daughters nintendo ds keeps coming up with sd.tf card error.have read about formatting the card but will i loose all the data and pre loaded games? I have also read about downloading a kernal which i...
Hi anna21,
Formatting the card may fix the problem however you will loose all the data on the card. I have a solution here that can help you but you need a SD Card Reader on your computer to back up the files.
1. Put the SD Card in your Card Reader.
2. Connect it to your PC.
3. If the window pop-up like asking to open with what program select Open as File.
4. If the window does not pop-up, Go to My Computer/Computer. There should be the SD Card Memory.
5. Backup all the save file in your SD Card in other word copy the whole SD card. Save it in your computer. Make sure you remember where you put it.
6. Reformat the SD Card by Right Click and click Fromat
7. Tick Quick Format
8. After it finish formatting, Try open the SD Card. It should be empty.
9. Put back all the copied file back into SD Memory Card.
10. Plug it on your DS. Check the files. Play and Enjoy
Rate me if this helps so I can help others. Thanks for using Fixya.
Feb 04, 2011 | Computers & Internet
Hi, I can view the pictures of a memory stick on my camera, but when I put it in the sleeve and insert it in the computer, the computer can not read the disk. I have also used the USB wires hooking the...
possibility: the memory card is not formatted in a way that your computer to recognize it.
give this a try...
*format the memory card first (FAT32 or NTFS) using your computer
*put the memory card back to your cam, then click away
*then try to read it again in the pc.
Jun 22, 2010 | Sony 4GB Memory Stick PRO Duo Memory Card
Need help in getting my phone to reconize the memory card
Try formatting the card.
Put the card into your computer so you can view it and everything on it. Take all the files off the memory card and store them someplace on your computer.
Go to MY COMPUTER, right click the memory card and click FORMAT. Follow the directions and make sure QUICK FORMAT is NOT ticked. Then click format and give it a few minutes.
When it is done, put the memory card into your phone and see if it recognizes it now.
IF IT DOES, put the card back into your computer and put the files back onto the card. Then put it back in the phone. Should work now, if not, there is a defective file on the card and needs to be found because its interrupting the the phones processing.
IF IT DOESNT, try another memory card. The current card could be defective. If the phone still doesn't read the new card, the phones card reader is defective and needs to be sent to your phone provider to be fixed.
Hope this helps!
Have a nice day!
- Neal
Apr 27, 2009 | Motorola Mobility RAZR V3x Cellular Phone
Bluetooth
Back up first files on your memory card on your computer. then format the memory card on the pc. Then put back the formatted memory card and format it again on the phone. Take out your memory card then put it back again on your pc to copy your previous files. This should work.
Memory cards need also formatting same as HDD's
Hope this helps...
Jul 24, 2008 | Nokia 6131 Cellular Phone
Problem reading micro sd card on lg kg290
well...all you should know about the micro SD card is that you should format it, when it's inserted in the computer's card reading/writing unit... once (the first format) and don't put any file in it...insert it in the phone, and format it again (formatting is rewquiring FAT 16, or FAT file system in both formatting processes) after that, reinsert it in the computer's card reader/writer and find a way to defrag it...after that do a check with a disk checking tool, or program...and after all is ok...you can put any file type on, insert it in the phone, and restart the phone...if this doesn't work...the card is either bad, or the phone does not support it's memory size...
Jul 22, 2008 | Cell Phones
Unable to add default folder - Memory Card
take the card out and put in back in. it worked for me,
Feb 03, 2008 | Cell Phones
Memory card currupt
heyy..well try this..copy ur files 2 ur pc..formatt the memory card frome the pc in file system then try it on ur mobile it should ask u 2 format it..well do it it must work then recopy ur files..hope this will help
Feb 02, 2008 | Nokia 3230
Olympus SP-350 Digital Camera Logo
22 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
