Question about Miele Washing Machines
The Miele W2105 starts - flashing light on SPOELEN
The Miele W2105 starts ok but then after water gets added - the program stops and the SPOELEN light starts flashing? Then it does not turn or continue? Any ideas?
SOURCE: miele novotronic w/m fault light flashing
We had the same problem on a Premier 500 and solved it by tilting the machine forward. Some more water ran out and the lights went off.
Posted on Jan 05, 2008
SOURCE: Washing machine problem
my w830 is doing exactly the same thing.
I am usually pretty good at fixing these sort of things so if/when I solve it I will post back here.
I think it is a motor fault - most likely the motor brushes are worn out.
Posted on Aug 07, 2008
  • 4 Answers
SOURCE: Miele W1926 water light flashes
That happened to me too. If the machine is a few years old and the hoses are not kinked it's possible the water inlet valve needs to be replaced. On this machine there is a triple cold water valve and a single hot water valve. Mine needed the triple valve and it is about $300 if I remember. Check to see if it's the cold or hot water valve by looking at the water filling through the soap drawer for cold or hot water cycles. When the valves go bad they run but the output is very low which causes the light to flash because it can't fill to the correct level.
You can get to the valves by taking off the top. If you don't feel comfortable working on your own machine have a professional do it.
Posted on Aug 06, 2009
  • 14 Answers
SOURCE: Miele Novatronic W360
there is still water in the waterproof tray at the bottom of the machine and the float switch has activated. pull the machine out (if pipes allow) and tip the machine backwards to drain the water from the tray.
Posted on Aug 26, 2009
odiebugs
  • 949 Answers
SOURCE: the check inlet light flashes. I have cleaned the
If your sure the water way is clear, unplug the unit, plug it back in,
and see if the error is gone, if not, place the water lines into the tub and turn on the water to make sure water is coming into unit, if so the problem lies somewhere else.
Re-post if this didn't help, and say you did this but still have the error.
Good luck, hope it helps.
Posted on Feb 05, 2010
Miele Dishwasher 626 SC starts but no water is received and it stops soon after. Water supply is ok and has pressure. Main solenoid is also ok. Any suggestions?
Is the drain pump working? is it fed to a sink trap and end hasnt been cut out.i know but ive had this happen when sent to check a machine!pump is always first part of program
Apr 17, 2017 | Miele Dishwashers
Miele dishwasher G1040 stop starting then all three lights start flashing
Sounds like bad control board. Try calling the guys from the service, I don't think you'll be able to fix this by yourself. Source: PDF Keep
Dec 27, 2015 | Miele Dishwashers
Miele G 851Intake/Drain light flashes and program stops
http://m.miele.ca/OperatingInstructions/en-CA/Dishwashers/Previous%20models/Miele%20Dishwasher%20Manual%20G851%20SC%20Plus.pdf
Page 39
Jul 01, 2015 | Miele Dishwashers
Miele Futura Crystal Dishwasher can't select program
I am getting the impression there is some fault in the water softener unit. BUt as I don't have the actual model available it is hard to confirm.
Please check if your dishwasher is the same as the one on this site.
http://data.manualslib.com/pdf3/59/5824/582385-miele/crystal_g_5225_sc.pdf?bdaf1d0752c567e0adc42018ba077d86&take=binary
Refer problems and trouble shooting section.
Apr 10, 2014 | Miele Dishwashers
Water keeps filling up the drum and inlet light flashes
either the inlet water valve is bad and needs to be replaced or the controller for it is not cutting off the electricty to it, If you are going to replace something, replace the water inlet solenoid valve.
Feb 10, 2014 | Miele Washing Machines
Miele W1926 check inlet light flashes at the end of rinse fill. When the fill ends, the light goes off. I cleaned all 4 filters at the intake hoses. The problem still exists. What does it mean?
Hi dear.It sounds like you'll need to change water inlet valve very soon.Because,machine waiting water level to be reach,in specific time frame in chosen program parameters to be get completed.If that does not happen,then it starts giving fault indication.Indication stops after fill,because task been competed & computer disregards the fault.If that won't happen then machine going to get stop completely & indication will carry on.Chage the water inlet valve if you can.I hope that helps. Thanks.
Jul 25, 2010 | Miele W1903A Front Load Washer
Starts ok then skips programmes lights flash then stops without finishin wont complete any programme
starts ok then skips programmes lights flash then stops without finishing wont complete any programme
Jul 02, 2010 | Miele Washing Machines
Miele G638 CS Plus - Salt PC light flashes and will not run
have you added salt to unit?If so then you have a water intake problem or unit is oversudsing.
Dec 07, 2007 | Dishwashers
Washing Machines Logo
128 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
