Question about Samsung WF419AA Front Load Washer / Dryer
De1 error message on Samsung front load washer
After doing a load of wash this error appears as I try to do a second load... if I wait a few hours it works fine. What is the problem?
  • 327 Answers
Hello,De error refers to "Door Error".
You do not need to buy a new machine. You can fix this.
Look at the below mentioned link
http://lgknowledgebase.com/kb/index.php?View=entry&EntryID=799
No doubt the above page is for "LG", However it's the basic and would remain the same for all models and machines whether that's GE, LG, Samsung etc....
Thanks
Posted on May 31, 2010
  • bioscomsoft
    bioscomsoft Apr 14, 2013
    was very helpful. thanks for keeping this post on the internet.
My Whirlpool washer #W10251314 Will fill to required level,Locks,Wait a few seconds,Attempt washing and then sounds as something trip.Will keep doing this.
Try washing a half load to see if it will actually work, if it does then you may have a load sensor problem. Are any economy switches on, like half load or other types ? Set all switches to 'max' so to speak and try a half load wash also try a different program cycle (but try with a few old towels and sheets, don't want to risk any good stuff)...... Red.
Dec 03, 2014 | Whirlpool Washing Machines
Konica minolta bizhub c253,how to reset transferbelt by using fusser
There are two ways to reset an error code:
  • 1. Open the front cover, wait for a few seconds and then close it. If the error is still there try the second method.
  • 2. Shut down from the main power switch wait for a few seconds and then start it up while keeping the 'Utility/Counter' button pressed; keep it pressed until the reset button appears on the touch screen, release the 'Utility/Counter' button, touch the reset button and an OK message should appear below.Restart it normally and it should work. If the error is still there, try to follow the steps provided in the solution found based on your error code.
Aug 21, 2014 | Office Equipment & Supplies
Dryer will not operate
We are sorry to hear of the problem with your Whirlpool appliance. We would recommend having a local certified technician in your area properly diagnose and repair the issue you are experiencing. Please email us at Whirlpool_Digital@Whirlpool.com with your name, phone number, address and the model and serial number for your dryer.
Apr 04, 2017 | Whirlpool GEW9250P Electric Dryer
I am getting an E02 error. It has been running for about a half an hour and clothes is still dry. Water appears to be going in, but not sure to where???
I've encountered this a few times. I still haven't been able to find out what the E02 stands for, but if you unplug the machine, wait 30 seconds, then plug it back in, it seems to work fine.
Sep 30, 2010 | Bosch Nexxt 300 Series WFMC2201UC
My dsi wont let me upgrade it.
You won't believe this answer but it works!
The same thing happened to me, I kept waiting and waiting and then it would say error. But, all you need to do is close the top of the dsi ( NOT THE POWER! ) and wait a few seconds. Then, when you open it up it almost always has one bar loaded! Keep doing this till loaded.
NOTE: You must open the top and then close it again, even if you wait an hour before opening it will have on bar more loaded!
Good luck!! :)
Dec 17, 2009 | Nintendo DSi White Console
Neptune front load washer showing code LO. Door
You can try either prying the door open and then replacig the door switch which is probably what caused the problem in the first place. Or try unplugging the machine for several hours, press and hold power button for a few seconds, wait half hour more, plug back in to see if it resets itself.
Nov 25, 2009 | Maytag Neptune MAH5500B Front Load Washer
I keep getting error 20. How do I fix it.
error 20 in a general error try to Reading Error Codes 1. Wake the washer by pressing any button. 2. Wait 5 seconds. 3. Press and hold the START/PAUSE and CANCEL buttons simultaneously. As long as the buttons are held, the failure code will appear in the display as an “E” followed by two numbers, a number and a letter or two letters. The control will beep and the Door Lock, Wash, Rinse, and Final Spin indicator lights will flash.
Sep 19, 2009 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
LE sighn on NEC washing machine
Generally LE is as you said a load error. This can refer to an unbalanced load in the machine. You should try to redistribute the clothes to even the loadThe addition of a P.I error code indicates it is having problems loading the programmed wash instructions.
The fuzzy logic is a form of artificial intelligence that controls the preprogammed operations of the machine and warns of wring usage.
If redistribution of the load does not work unplug the machine from power and leave for a few hours. Then replug and turn on.load with a few items only and set the unit to wash ...
Aug 11, 2009 | Washing Machines
How do i find what an error code means?
if that is a whirpool or kenmore remove bottom panel look for tech sheet in plactic bag codes are in it
Sep 02, 2008 | Washing Machines
Samsung WF419AA Front Load Washer / Dryer Logo
1,934 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
