Question about RTO Ford Tractor 2000 3000 4000 5000 Water Pump Sngl Pulley
How to repair a Ford 3600 leaking rear oil axle wheel seal
Right rear wheel is leaking oil. the inside of the tire and wheel and wheel wall show oil.
Jack the vehicle up and check the brake caliper. If it isn't a seal on the caliper make sure you check the shock absorber to make sure that isn't leaking. If that is not leaking it is most likely the axle seal. Unless Ford has changed the design of that your going to have to open the rear differential, remove the retaining clip for that axle and extract it from the Axle housing. The seal is typically pressed on so it is going to be a pain to remove the old seal then press the new seal in place and re-assemble the rear end. Make sure you fill the differential with the proper fluid or you'll burn the rear end out. When your checking the caliper make sure you check the brake line for breaks and the bleed valve to make sure that is in place and not leaking.
Jun 08, 2011 | 2006 Ford Mustang
How to remove rear wheel bearings on my 1999 Ford Expedition and how do i know what pulley to rent/buy?
The 1999 Ford Expedition is built on an F150 platform. The Expedition uses a 9.75-inch rear axle. The axles are retained with C-clips at the end of the axle shaft, inside the differential carrier. The axle bearings are of the roller type. A failed axle bearing can manifest itself as a noise at the rear wheel or gear oil leaking past the oil seal. When replacing axle bearings, the oil seals must also be replaced.
Torque the caliper mounting bolts to 30 foot-pounds. Torque the bolt to 20 foot-pounds with a torque wrench and socket. Click this link below for complete detailed procedure:--- http://technoanswers.blogspot.com/2011/06/how-to-remove-rear-wheel-bearings-on.html -------------- This should help.Thanks.Helpmech.
Jun 07, 2011 | Ford Expedition Cars & Trucks
1998 ford explorer 2 wheel drive rear wheel bearing replacement
what about it?
conventional axle or limited slip? Get axle code off door sticker.
SECTION 205-02: Rear Drive Axle/Differential - Ford 8.8-Inch Ring Gear 1998 Explorer/Mountaineer Workshop Manual
IN-VEHICLE REPAIR Rear Wheel Bearing and Axle Shaft Oil Seal -4.0L SOHC and 4.0L EI, Conventional
Special Tool(s) swn~us~en~file=st1514a.gif~gen~ref.gif Axle Seal Replacer
T83T-1175-A swn~us~en~file=st1283a.gif~gen~ref.gif Axle Wheel Bearing Puller
T83T-1225-A swn~us~en~file=st1322a.gif~gen~ref.gif Axle Wheel Bearing Replacer
T83T-1225-B swn~us~en~file=st1326a.gif~gen~ref.gif Driver Handle
T80T-4000-W swn~us~en~file=st1185a.gif~gen~ref.gif Impact Slide Hammer
T50T-100-A
Removal
  1. Remove the axle shaft; refer to Axle Shaft in this section.
Axle Shaft Removal
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not use heat to loosen a seized lug nut. Heat can damage the wheel (1007) and the rear wheel bearings (1225).
    Loosen the lug nuts (1012).
    1. Remove the center cap.
    1. With the weight of the vehicle on the wheels, loosen the lug nuts.
  1. Raise and support the vehicle.
  1. Remove the wheel and tire assembly.
    1. Remove the lug nuts.
  1. Remove the axle housing cover (4033).
    1. Loosen the axle housing cover bolts (4346) and drain the rear axle (4001).
    1. Remove the axle housing cover bolts.
    1. Remove the axle housing cover.
  1. Remove the rear disc brake rotors (2C026); refer to Section 206-04 .
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Once the differential pinion shaft (4211) has been removed, turning the differential case (4204) or an axle shaft (4234) will cause the differential pinion gears (4215) to fall out of the assembly. This could result in chipped or damaged components.
    Remove the differential pinion shaft.
    1. Remove the differential pinion shaft lock bolt.
    1. Remove the differential pinion shaft.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the rubber O-rings in the U-washer grooves.
    Remove the U-washers (4N237).
    1. Push the axle shafts inboard.
    1. Remove the U-washers.
  1. Reinstall the differential pinion shaft.
    1. Install the differential pinion shaft.
    1. Install the differential pinion shaft lock bolt finger-tight.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the inner wheel bearing oil seal (1177).
    Remove the two axle shafts.
Installation
  1. Lubricate the lip of the inner wheel bearing oil seal.
    • Use Premium Long-Life Grease XG-1-C or equivalent meeting Ford specification ESA-M1C75-B.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Once the differential pinion shaft has been removed, turning the differential case or an axle shaft will cause the differential pinion gears to fall out of the assembly. This could result in chipped or damaged components.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the inner wheel bearing oil seal.
    Install the two axle shafts.
    Install the U-washers.
    1. Position the two U-washers on the button end of the axle shafts.
    1. Pull the axle shafts outward.
    1. Align the hole in the differential pinion shaft with the differential pinion shaft lock bolt hole.
    1. Install the differential pinion shaft lock bolt.
  1. Install the rear disc brake rotors; refer to Section 206-04 .
  1. Install the axle housing cover and fill the rear axle housing (4010) with 2.4 liters (5.5 pints) of specified lubricant; refer to Axle Housing Cover in this section.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif WARNING: Always remove any corrosion, dirt or foreign material that may be present on the mounting surfaces of the wheel or the surface of the wheel hub or rear disc brake rotor that contacts the wheel. Installing wheels without proper metal-to-metal contact at the wheel mounting surfaces can cause the lug nut to loosen and the wheel to come off while the vehicle is in motion, causing loss of control.
    Clean the wheel hub and mounting surfaces.
  1. Install the tire and wheel assembly.
    1. Position the tire and wheel assembly.
    1. Install the lug nuts and lower the vehicle.
    1. Tighten the lug nuts.
    1. Install the center cap.
  1. swn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Never remove the axle shaft oil seal by itself. Always remove the rear wheel bearing and the axle shaft oil seal at the same time.
    NOTE: If the axle shaft oil seal is leaking, the axle housing vent may be plugged with debris.
    Use Impact Slide Hammer and Axle Wheel Bearing Puller to remove the rear wheel bearing and the axle shaft oil seal.
Installation
  1. Lubricate the new rear wheel bearing.
    1. Use Thermally Stable Rear Axle Lubricant XY-80W90-QL or equivalent meeting Ford specification WSP-M2C197-A.
  1. Use Axle Wheel Bearing Replacer with Driver Handle to install the rear wheel bearing.
  1. Lubricate the lip of the new axle shaft oil seal.
  1. Use Axle Seal Replacer with Driver Handle to install the axle shaft oil seal.
  1. Install the axle shaft; refer to Axle Shaft in this section.
May 18, 2011 | Ford Explorer Cars & Trucks
How do you change a wheel seal on a mercury mountaneer 1998 rear end
Axle Vent
NOTE: If the vent cannot be cleared, it must be installed new.
A plugged vent will cause excessive seal lip wear due to internal pressure buildup. If a leak occurs, check the vent. Make sure the vent hose is not kinked. Remove the hose from the vent nipple and clear the hose of any foreign material. While the hose is removed, pass a length of mechanics wire or a small diameter Allen wrench in and out of the vent to clean it. Connect the hose when done. The vent is located on the drivers side top of axle housing.
If you plan on doing most repairs yourself I would suggest buying a Haynes or Chilton manual for your particular vehicle. Or there are some data disks on e.bay($12-$15) For a cost of under $25, you can almost do any repair yourself with these manuals.Also there are online manuals like the site called ALLDATA where guides can be viewed for a fee. All these solutions will save you time and money, and give peace of mind over correct repairs. I can post you some procedures here also.
  1. CAUTION: Do not use heat to loosen a seized lug nut. Heat can damage the wheel (1007) and the rear wheel bearings (1225).
  2. Loosen the lug nuts (1012).
  3. Remove the center cap.
  4. With the weight of the vehicle on the wheels, loosen the lug nuts Raise and support the vehicle. .Remove the wheel and tire assembly.
  5. Remove the lug nuts.
  6. Remove the wheel and tire assembly. Remove the axle housing cover (4033).
7.Remove the rear disc brake rotors You will have to remove the brake caliper to get rotor off.
8. CAUTION: Once the differential pinion shaft (4211) has been removed, turning the differential case (4204) or an axle shaft (4234) will cause the differential pinion gears (4215) to fall out of the assembly. This could result in chipped or damaged components.
9.
1.Remove the differential pinion shaft lock bolt. 2.Remove the differential pinion shaft. 4fd1df0.gif 10.CAUTION: Do not damage the rubber O-rings in the U-washer grooves. Remove the U-washers (4N237).
  2. Remove the U-washers.
    11.Reinstall the differential pinion shaft.
      12.CAUTION: Do not damage the inner wheel bearing oil seal (1177). Remove the two axle shafts. 1848771.gif
CAUTION: Never remove the axle shaft oil seal by itself. Always remove the rear wheel bearing and the axle shaft oil seal at the same time. NOTE: If the axle shaft oil seal is leaking, the axle housing vent may be plugged with debris. Use Impact Slide Hammer and Axle Wheel Bearing Puller to remove the rear wheel bearing and the axle shaft oil seal.
0ffed5b.gifAxle bearing puller end..
Installation
  1. CAUTION: Once the differential pinion shaft has been removed, turning the differential case or an axle shaft will cause the differential pinion gears to fall out of the assembly. This could result in chipped or damaged components.
  2. Remove the differential pinion shaft.
  3. Remove the differential pinion shaft lock bolt.
  4. Remove the differential pinion shaft.
    CAUTION: Do not damage the inner wheel bearing oil seal. Install the two axle shafts. CAUTION: Do not damage the rubber O-rings in the U-washer grooves. Install the U-washers.
                                                            Install the rear disc brake rotors; Install the axle housing cover and fill the rear axle housing (4010) with 2.4 liters (5.5 pints) of specified lubricant
                                                            WARNING: Always remove any corrosion, dirt or foreign material that may be present on the mounting surfaces of the wheel or the surface of the wheel hub or rear disc brake rotor that contacts the wheel. Installing wheels without proper metal-to-metal contact at the wheel mounting surfaces can cause the lug nut to loosen and the wheel to come off while the vehicle is in motion, causing loss of control. Clean the wheel hub and mounting surfaces. Install the tire and wheel assembly.
                                                            Position the tire and wheel assembly. Install the lug nuts and lower the vehicle. Tighten the lug nuts. Install the center cap. 6a78fd6.gif WHEW Hope this can help you
                                                            Mar 21, 2010 | 1998 Mercury Mountaineer
                                                            Leak rear ruim around tire oily
                                                            This is most likely an axle seal leaking.
                                                            Nov 25, 2009 | 2005 Mercury Grand Marquis
                                                            I have a leak from my rear axle seal. How do you
                                                            JACK up the truck and block other rear wheel both back and take hand brake off ,,remove rear wheel/brake drum/handbrake cable from rear brake/remove metal brake hose/remove rearbacking plate with all parts fitted to it ie brakeshous 4or5 bolts holding the rear axle in to housing and when all parts off then put on a IMPACK PULLER and remove complete backing plate with axle assy and take to the engineering shop to get it pressed off and a new bearing and seal assy pressed back on .
                                                            Then refit in reverse of removal and bleed the brakes and top up the rear axle of oil (EP90) apply h/brake take out blocks and lower jack and test drive .. BUT MAKE SURE THE BRAKES ARE 100%
                                                            Oct 14, 2009 | 2005 Ford F 350 Super Duty
                                                            Rear brake drum leaking on my 1989 ford bronco 2 y did it happen and how do u fix it
                                                            The drum isn't leaking, either the wheel cylinder is leaking or the line is leaking
                                                            Oct 07, 2009 | 1989 Ford Bronco II
                                                            Grease and differential oil inside left rear drum
                                                            Not that difficult, raise and support the rear of the truck and remove the wheels. Might as well replace both sides so you know you have new seals, remove the differential cover and drain the fluid. Once differential is opened and cleaned , remove the axle "C" clip that hold the axle in place and slide the axle out. Once the axle is out remove the wheel seal and clean around the area. This would be a good time to replace the wheel bearing too since you have access to them and there not that expensive. Install the new bearing and seal, note make sure you oiled the bearing and seal before installing it back and take care when installing the axle back in and "C: clip. Use RTV silicon gasket maker to seal the differential cover and wheels back on and lower. If your lazy like i am, you can drain the differential fluid and replace it with a 50/50 mix with gear oil and Lucas engine oil additives. That may stop the leak and get you a few more miles. You gear oil is (ford 75W-140) (Dana 80W-90)and the capacity is 2.6 liters and 3.5 liters if you have the 10.25 Ring gear. Good luck and hope this helps.
                                                            Jul 07, 2009 | 1998 Ford F150 Regular Cab
                                                            Rear wheel bearing
                                                            SECTION 205-02B: Rear Drive Axle/Differential — Ford 8.8-Inch Ring Gear 2003 Mustang Workshop Manual IN-VEHICLE REPAIR Axle Shaft Removal
                                                            1. Raise and support the vehicle. For additional information, refer to Section 100-02 .
                                                            1. Remove the wheel and tire assembly. For additional information, refer to Section 204-04 .
                                                            1. Remove the rear brake disc (2C026). For additional information, refer to Section 206-04 .
                                                            1. Remove the differential housing cover (4033) and drain the lubricant. For additional information, refer to Differential Housing Cover in this section.
                                                            1. Remove the differential pinion shaft (4211).
                                                              1. Remove the differential pinion shaft lock bolt (4241).
                                                            1. s3b~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the rubber O-ring in the axle shaft groove.
                                                              Remove the U-washer (4N237).
                                                              1. Push the axle shafts (4234) inboard.
                                                              1. Remove the U-washer.
                                                            1. s3b~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Damage to the rear brake anti-lock sensor (2C190) may occur if it is not removed before the axle shaft.
                                                              Carefully remove the rear brake anti-lock sensor. For additional information, refer to Section 206-09A .
                                                            1. s3b~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the wheel bearing oil seal.
                                                              Remove the axle shaft.
                                                            Rear Wheel Bearing and Axle Shaft Oil Seal Removal
                                                            1. Remove the axle shaft (4234). For additional information, refer to Axle Shaft in this section.
                                                            1. NOTE: If the wheel bearing oil seal is leaking, the axle housing vent may be plugged.
                                                              Using the special tools, remove the rear wheel bearing and wheel bearing oil seal.
                                                            Installation
                                                            1. Lubricate the new rear wheel bearing with the specified lubricant.
                                                            1. Using the special tools, install the new rear wheel bearing.
                                                            1. Lubricate the lip of the new wheel bearing oil seal.
                                                            1. Using the special tools, install the new wheel bearing oil seal.
                                                            1. Install the axle shaft. For additional information, refer to Axle Shaft in this section.
                                                            Installation
                                                            1. Lubricate the lip of the wheel bearing oil seal
                                                              Install the U-washer.
                                                              1. Position the two U-washers on the button end of the axle shaft.
                                                              1. Pull the axle shaft outward.
                                                            1. NOTE: If a new pinion shaft lock bolt is unavailable, coat the threads with Threadlock and Sealer EOAZ-19554-AA or equivalent meeting Ford specification WSK-M2G351-A5 prior to installation.
                                                              1. Align the hole in the differential pinion shaft with the case lock bolt hole.
                                                              1. Install a new differential pinion shaft lock bolt.
                                                            1. Install the differential housing cover and fill the rear axle with the specified lubrication. For additional information, refer to Differential Housing Cover in this section.
                                                            1. Install the rear brake anti-lock sensor. For additional information, refer to Section 206-09A .
                                                            1. Install the rear brakes. For additional information, refer to Section 206-04 .
                                                            1. Install the tire and wheel assembly. For additional information, refer to Section 204-04 .
                                                            1. Lower the vehicle.
                                                            Apr 10, 2009 | 2004 Ford GT
                                                            Replace left rear axle seal 1999 ford explorer
                                                            Axle Shaft Removal
                                                            1. Remove the differential housing cover (4033).
                                                              1. Loosen the bolts and drain the lubricant from the rear axle housing (4010).
                                                              1. Remove the bolts.
                                                              1. Remove the differential housing cover.
                                                            1. sxn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Turning the differential case (4204) or an axle shaft (4234) with the differential pinion shaft (4211) removed will cause the differential pinion gears (4215) to fall out of the assembly and damage the components.
                                                            2. sxn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the rubber O-ring in the U-washer groove.
                                                            3. Remove the U-washer (4N237).
                                                            4. Push the axle shaft inboard.
                                                            5. Remove the U-washer.
                                                            2. Install the differential pinion shaft lock bolt finger-tight.
                                                            3. sxn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Do not damage the wheel bearing oil seal (1177).
                                                            Seal Removal
                                                            1. Remove the axle shaft (4334). For additional information, refer to Axle Shaft in this section.
                                                            1. sxn~us~en~file=ani_caut.gif~gen~ref.gif CAUTION: Never remove the wheel bearing oil seal (1177) by itself. Always remove the rear wheel bearing (1225) and the inner wheel bearing oil seal at the same time.
                                                              NOTE: If the wheel bearing oil seal is leaking, the axle housing vent may be plugged with foreign material.
                                                              Using the special tools, remove the rear wheel bearing and wheel bearing oil seal together.
                                                            6c7eb46.gif Installation
                                                              • For 4.0L SOHC and 4.0L EI with limited slip rear axles and 5.0L vehicles, use SAE 75W-140 High Performance Rear Axle Lubricant F1TZ-19580-B or equivalent meeting Ford specification WSL-M2C192-A.
                                                              • For 4.0L SOHC and 4.0L EI with conventional rear axles, use SAE 80W-90 Premium Rear Axle Lubricant XY-80W90-QL or equivalent meeting Ford specification WSP-M2C197-A.
                                                            1. Using the special tools, install the rear wheel bearing.
                                                            1. Using the special tools, install the wheel bearing oil seal.
                                                            Feb 22, 2009 | 1999 Isuzu Rodeo
                                                            Open Questions:
                                                            See all RTO Ford Tractor 2000 3000 4000 5000 Water Pump Questions
                                                            RTO Ford Tractor 2000 3000 4000 5000 Water Pump Sngl Pulley Logo
                                                            277 people viewed this question
                                                            Top RTO Garden Experts
                                                            John Trevino
                                                            Joseph Mueller
                                                            Joseph Mueller
                                                            JOHN BROWN
                                                            Are you a RTO Garden Expert? Answer questions, earn points and help others
