Question about Rinnai Heating & Cooling
Gas heater develops a windy noise, then switches itself off
We have a REH 181 UCH
and it has been making a strange noise coming from the main flame source. Sounds like a windy day! After a while the flame cuts out altogether and the heater switches itself off.
The Marv
  • 72 Answers
SOURCE: Heater goes off
Possibly A bad thermocoupler. It is the part that looks like a stiff solid copper wire with on end sticking in the flame of the pilot light and is a safety feature if the pilot goes out it starts to cool and the resistance changes back you the module and the module shuts the gas off. I have seen these go intermediately faulty in waterheaters and do just what you described.
Posted on Jan 08, 2007
  • 4 Answers
SOURCE: pilot lights but when ignition pops back up the flame goes out
will either be the unitrol control box or the thermocouple, when you push down you are holding two magnets together and waiting for a small charge to be created from the probe in the flame , if this is not working you have no charge and the magnets won;t stick to allow the valve to open, change the thermo and see if that works first, its way cheaper than a new controler
Posted on Feb 05, 2009
  • 189 Answers
SOURCE: Burner flame going out on windy days on Coleman Evcon LP furnace
This sounds like a bad heat exchanger. It is possible that you do not see the crack because the crack is closed when the heat exchanger is cold (or room temp). Allow the furnace to heat up, this will allow the expansion of the crack. Turn the power off and examine the heat exchanger while it is still hot.
Posted on Apr 10, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: York Diamond 80 furnace (propane conversion),
Check for 24 volts across the two terminals on the gas valve when the ignitor glows. If yes, bad gas valve or blockage in the gas train. If no, bad ignitor or circuit board. Even if the ignitor glows, it still may be bad and not sending the proper signal to the board. If you jump the R and G terminals on the circuit board, does the fan still only run for 90 seconds? If so I would say replace the board.
Posted on Dec 28, 2009
  • 415 Answers
SOURCE: FURNACE MAKES STRANGE INTERMITTENT CLICK SOUND
Looks like an older system. Tighten all of your electrical connections. Inspect all of the low voltage wiring for any insulation cracks or other damage. The problem you describe sounds like something is either "shorting" or breaking down electrically. Unless the technician can catch it while he/she is there, it will be difficult to determine exactly what is happening. You might get lucky and resolve it yourself by tightening all electrical connections and reinsulating (use electrical tape) any damaged low voltage wire connections. If you continue to experience problems, get the tech. Hopefully the last company you used will be willing to work with you on the bill considering they were unable to "catch" it during the last visit.
Without being there with toolbox in hand, I hope you find this information very helpful moving forward. :-)
Posted on Mar 19, 2010
Testimonial: "Thanks for taking the time to answer my inquiry. I'll let you know how it works out."
How to clean clogged condensate drain of ruud furnace achiever 90 plus
You can easily blow through the drain with pressurized air through the p trap. There could be a number of reasons the furnace side is not working. In the case of windy conditions there is a possibility that your pilot will need to be adjusted or the flame sensing rod might need to be cleaned. If the pilot wavers off of the sensing rod it could cut off the heating cycle because the system could not verify a flame yo bring on the main gas valve to continue with the cycle
Mar 01, 2015 | Ruud Heating & Cooling
Glo warm heater
the regulator IS not only the issue, but it's a major safety benefit,..the pilot flame is non adunstable..get a cheap regulator(like the ones for the outdoor bbq's)
Mar 16, 2008 | Heating & Cooling
My Toyota vista is making noise when I make a sharp turn what could It be ?,
Depends on the kind of noise. Worn CV joints will make clicking sounds, worn bearings can make whining/grinding sounds. Worn out front end parts can also make strange sounds squeeling, clunking, grating and many other kinds of noises. The kind of noise can be used to identify the source.
Aug 08, 2014 | Cars & Trucks
Reh 252uc - Service or Replace? Smell gas when turned off....
You may have a small gas leak. Use a water sprayer with dish soap mixed with water and spray the gas fittings. If bubbles develop, you have a leak. Careful not to spray any electronics!
Jul 20, 2014 | Rinnai Heating & Cooling
Hello why do I have a loud buzzing noise coming from my umc combination 21 inch television so bad you cannot here program dialogue ?
You need to send your TV Model first, but in general any strange sounds in a TV come from the followings:
1- High ripple in the power supply of the sound card.
2- Bad polarized capacitors in the sound card
3- High noise in the main power supply (SMPS)
4- For CRT tv, weak insulation of the Line Transformer
5- An external source near your TV set which is picked by your TV and amplified.
Jun 09, 2014 | Televison & Video
I bought my 06 Dodge Charger, used, in 2011. First year no problems, then sometime in 2013, I would get in, turn the key, "reh-reh-reh-reh-reh"... stop, turn key off, wait a few seconds, turn key and...
Its not the plugs. And probably not a sensor.
It could be the fuel pump relay or the pump in the tank.
A sensor going bad would make the check engine light come on with a trouble code. A faulty pump relay or pump would make it take longer to get the fuel pressure up to normal. You could probably make it start by just cranking it longer too.
I would check to see if the pump comes on when it fails to crank.
Sep 02, 2013 | 2006 Dodge Charger
Measure the voltage to Terminals #2 and #3 on the main gas valve. If the voltage remains consistent while you hear the sound and the burners diminish slightly, the problem will be your main gas valve. If the voltage fluctuates, you will have to trace it back through the wiring to see through which switch you are losing it.
If this furnace has a hot surface ignitor with flame sensor, try cleaning the flame sensor with some emory cloth.
I hope you find this information to be very helpful as a good starting off point for you.
Please leave a rating. :-)
May 11, 2010 | Heating & Cooling
When gas wall heater lights a ball of flame comes
Lets get a tech in there to get it cleaned and the gas pressure checked.
Jan 18, 2010 | Off The Wall Heating & Cooling
Heating & Cooling Logo
89 people viewed this question
Top Rinnai Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
vance jones
Are you a Rinnai Heating and Cooling Expert? Answer questions, earn points and help others
