1996 rca tv
The problem that I described to you yesterday has been going on for about 6 months, why does that matter in your solution?
  • gpac97 Apr 10, 2008
    no help with my problem
    Genius:
  • 1,142 Answers
Just wanted to know if that has bothered you then i opologize.
Please do a flea power to your TV
Unplug the power cable
hold down the power button on the tv for 60 seconds without connecting to the power source then leave it disconnected for 10 mins and after that you can turn the tv on and give me the report.
Regards
Posted on Apr 08, 2008
SOURCE:
Burning rubber smell whilst going up hill
This sounds like an oil leak. Look for leaks at valve covers, and other areas above the exhaust. It often is the burning off of this small volume of oil, that makes the smell like you describe. Inspect the whole exhaust...Something is melting, somewhere.
Oct 09, 2012 | Toyota Avensis Cars & Trucks
Sound, no pic
THE PROBLEM IS SIMPLE, THEY MAKE CHEAP VIDEO BOARD CARDS THAT BURN OUT WITH SHORTS, YOUR ONLY REAL SOLUTION IF NO ONE IS GONNA FIX IT FOR FREE, LOL. IS TO BUY A NEW TV BECASUE REPAIR OF THIS ITEM, LAST TIME I CHECKED WAS CLOSE TO 400 BUCKS. HD TVS ARE CHEAPER NOW THAT THERE MORE AVAILABLE SO GO GET YOUR SELF A VAIO ON SALE TODAY AT WAL MART
Sep 11, 2009 | RCA L32HD32D 32 in. LCD HDTV
RCA L42WD250 42 in. will not turn on
Try unplugging it for 30 mins. If it still has the problem, it may have when into protection mode.
When this happens, a part in the TV when bad. The protection mode keeps the TV from staying on to prevent further damage.
At this point, I would use the warranty on the TV. Being that it's only 6 months old.
Feb 08, 2009 | RCA L42WD250 42 in. LCD HDTV
RCA HD52W66 convergence
Ceck CP150 and CP114 to see if the tops are domd eve slightly if so they will need replacement. They are both located on the deflection board where the flyback is also located.
Jan 16, 2009 | RCA HD52W66 Projection Television
I have a 53" rca hdtv model r52wh74 and the tv won't turn what do you think could be wrong? HELP i've only had the tv 6 months
This could be a number of things, but sonce the set is only 6 months old, it should still be under warranty. Call to request warranty service .
Dan
Oct 09, 2008 | Televison & Video
One channel is suddently in B &W - All rest in color
is it on a cable box? try unplug tv and box, that usually resets everything
Nov 17, 2007 | RCA TruFlat 27F520T 27" TV
1996 RCA Color TV model G27720tn
If you are on cable, first run the cable wire from the wall directly to the TV, eliminating any cable box and/or VCR. If channel 2 is snowy but the rest (especially 3-6) are clear, it is most certainly a cable problem and not a TV problem. The TV uses the exact same circuits for channel 2 to 6 (VHF-LOW) so if the tuner was bad and 2 was snowy, 3, 4, 5 and 6 would be snowy too. Bring a second TV into that room, disconnect the cable wire from the RCA and connect it to the second TV. Is channel 2 on the second TV as snowy as it was on the RCA?
Aug 18, 2007 | RCA 24V511T 24" TV
GE 31GT740
You may have a sticking button on your front control panel. Sometimes they become intermittent and cause crazy things to happen. I've found this in RCA tv's and GE's are made by the same manufacture. Stargazer
Apr 23, 2007 | GE 31GT740 31" TV
Rca truflat with green tinted picture?
Just because a machine has failed, there is no cause for you to call it a stupid TV. And as it is only 6 months old, why not take it to the Company service Centre? There must be warranty.
Apr 01, 2007 | RCA 27F530T 27" TV
Televison & Video Logo
Top Televison & Video Experts
Marvin
Marvin
