Question about Panasonic KX-P1131 Matrix Printer
Panasonic KX-1091i carriage goes to right and makes loud noise.
I have had an old Panasonic KX-1091i since it is new. I just got a new computer running Windows 7, and am using the standard mode (Epson-FX/RX emulation). Every time I try to print, the carriage goes to the right side, shakes, and makes a loud noise a little like a jackhammer. Usually if I then turn off the printer, unplug it from the computer, and turn it on again, it will produce a so-so job for most of the print job. However, sometimes if I turn on the printer even when it isn't plugged into the computer it does the same thing.
Some background:
I am using the printer to print checks, for which it is ideal. I formerly had the printer connected to a rather flaky XP system that would bluescreen and reboot frequently. I had dipswitch 1 set to IBM proprinter emulation. For that system the printer mostly behaved okay. I had dipswitch 1 set to standard mode, and other than the printer printing a couple of garbage symbols at the beginning of each print job it did okay. However, whenever the computer would reboot, the printer carriage would go over to the right and make that loud noise. I was able to mostly work around this by keeping the printer off when not in use. However, when I turned on the printer, occasionally it would go over to the right and make the noise. Very infrequently, even after unplugging and reattaching both the power and parallel cables the problem would persist. It seems that if I leave the printer off for a while and then try again, it is more likely to work. Since this was happening infrequently, usually I could print ok.
I have been unable to find a Proprinter driver for Windows 7, so that is why I am using the Epson FX Series 1 (80) driver. In addition, the computer does not have a parallel port, so I am using a parallel to USB converter cable. I don't know if any ot these things are contributing to the problem. I was able to do the autotest with the dipswitch configuration on the third try, and that printed perfectly. However, the first 2 times I turned on the printer it did the carriage to the right routine, even though it was not connected to the computer.
Also, the printing quality is not great when I do manage to print. I managed to print the Windows test page, and although it is legible, the alignment isn't great, especially with the graphics.
  • haakonc May 31, 2010
    Well, on a hunch I looked thru all the Windows 7 drivers, and found one for the IBM Proprinter. It is not under IBM (there is nothing under IBM), but instead is listed under Generic, and called "Generic IBM Graphics 9 pin". It works fine, actually even better than the driver I was using under XP.
    I don't think this totally solves the problem, since the problem was sometimes happening even when the printer wasn't connected; however, at least I can print now.
2 Suggested Answers
  • 1606 Answers
SOURCE: I tried to print to
It has been a while since I've run across this but the printer you want to select is actually the Epson MX-80. That was the standard for narrow dot matrix printers. Panasonic equivalent was something like the KX-1180 but the Epson setting worked better.
And you will still have to adjust either the form layout or adjust the form template so the text ends up in about the right place. This is a pain to do but that is the only way if you have to use a dot matrix. Usually you only see these on multiple copy forms but most places have just changed to print multiple copies pages so I don't run across too many dot matrix printers these days.
Posted on Sep 02, 2011
Loud wheezing noise on spin cycle
you need to unblock the pipe work from the tub to the pump ,,then the pump,, and the pipe from the pump to the drain
Jan 12, 2014 | Panasonic Washing Machines
KX-FLB756 Grinding Noise, Unable To Print
if you have driver for this printer pls. install
Dec 24, 2011 | Panasonic KX-FLB756 Plain Paper Laser Fax
After switching the printer on it gets ready to print and I hear the usual sounds, I persume the ink cartridge carrier moving but recently it has started making a loud chattering sound for a few seconds...
First of all, check to see if you also hookup the phone cable to jack too? If yes, temporary unplug it to see if noise goes off.
Also, open the lid to check on the drive belt. It may be loose and not able to drive the carriage. There is the gear on the right side of the carriage and a pulley on left side of the of the carriage. The spring which holds the pulley tight might be broken. Check that to see if it is the case. If it is that is why it makes loud noise when printing. And if it is not fixed, eventually you will receive an error message and printer will not work.
Check that and let me know.
Jul 20, 2011 | Canon PIXMA MP530 All-In-One InkJet...
My gatewayspeakers started to make loud noise when i shutting down the device or starting or if I inser any USB devise. the loud noice goes away if I mute it or attach the headphones to the system. What do...
Is it an electric noise ?
I've it is, its because your computer is a bit old, and it has problems providing power to all your hardware. But, i've you listen to music, the music will mask the noise.
So you probably need to buy a new pc, i've you dont want any noise.
Jul 17, 2011 | Gateway Audio Players & Recorders
How to clear and set margins and tabs please on
You must hit the carriage return button to find the current position of the left margin, then hit the mar release button and use the backspace key to move the carriage to the new position that you want the margin to be set at, then hit the left margin key to set it. Then move the carriage to the right to find the right mar, hit the mar release key and use the spacebar to move the right mar to the new position you want, then hit thr right mar kay to set it.
Sep 02, 2009 | Office Equipment & Supplies
Carrige goes to extreme right and chatters. this occured just after cleaning, had worked fine before the cleaning
Alignment is off on the slider track that the carriage moves left/right on. Power down, move the carriage to the far left. power back on and let the system calibrate. There should be a reset sequence where you hold down the menu or online button and keep it down while you turn the unit on. That will put it in a self test mode that you can cancel by powering off then back on.
Jul 26, 2009 | Panasonic KX-P2023 Matrix Printer
HP 1610 Carriage Jam
Remove the ink jet, make sure you removed any pckg. material and the contacts cover on it.
Nov 10, 2017 | HP PSC 1610 All-In-One InkJet Printer
Panasonic answering machine not working
We had the same problem. Unplugging the unit and restarting it again solved the problem.
Nov 15, 2008 | Panasonic KX-TG6700 Cordless Phone
Panasonic KX-P1131 Matrix Printer Logo
129 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
