Question about Jacuzzi Bellavista 6 Whirlpool w/2-Speed Motor JAC-EE20
Our Jacuzzi Espree 6060 corner whirlpool stopped working after about 15 months of light use. I called the company and they had me order an air switch. Our motor does nothing. No clicking. GFI is working. I haven't installed the air switch yet. I was actually on line trying to figure out how and where to put the air switch. After reading this I'm not so sure it's our air switch if there's no clicking.
    Scholar:
  • 81 Answers
You dont't need tp install your air switch anywhere until you find out if it is the problem. Simply connect it to the airline that activates the motor and push the button, If it works then it was the switch all along. If it doesn't, the the problem is with the switch on the motor or the motor itself.
Posted on Jun 03, 2010
My air bubbles on my Espree Aero Flo modelDS75 are not working why
If the bubbles are not working on the tub it could be the check valve is stuck closed or the air blower is not working.
Sep 15, 2014 | Jacuzzi Home
How to fix jacuzzi tub will not shut off bubbler
if the air blower will not shut off then it will either be the air switch in the blower or the control module that operates the blower will be bad.
Sep 11, 2014 | Jacuzzi Home
I have a jacuzzi espree 536 model U640. The jets would not shut if with the switch. I unplugged the unit and now it will not turn on
When a jetted tub will not turn off it is usually because the air switch in the motor has quit functioning.
A new air switch for your pump costs around $20
US Parts Center
Oct 27, 2013 | Home
I have a Jacuzzi whirlpool bath model U640 Espree 536 and it wouldn't shut off. I cut the air line off at the pump and nbow it won't stay on for more than a few seconds. Any ideas?
I assume you hooked the hose back up to the air switch on the motor.
There will only be a couple of things to check.
Make sure you have a good connection with the air hose to the air switch on the motor. Sounds like maybe the air switch may be bad.
The Air Switch is a latching air switch so if is broken then it won't latch when the air button is pushed.
Rod
www.uspartscenter.com
Jan 23, 2013 | Jacuzzi Home
I have a U.S Whirlpool Jacuzzi tub that has been installed for about 6 years but have only used 5 or 6 times. We have not used it in over a year and now we cannot get the motor to run. We checked the...
Call a local bathtub service company but check to see it the tubing on the back of the motor has come off. If your tub turns on/off with an air button on the top of the tub, that tubing has to be hooked up in order for the pump to be able to turn on/off.
let me know if you need further help. I would need to know what the control looks like on the top of the tub in order to further assist you.
Rod
Jul 29, 2011 | Jacuzzi - Whirlpool - Corner - Gallery...
Hi, I am wanting to download and print out the installation manual for: Jacuzzi 60'L x 32"W x 22"H Espree 1-Person Hourglass Whirlpool Tub. I want to read this before I purchase this tub. ...
Hi Pat,
The installation manual should be available on this webpage but there seems to be a broken link when you try to download:
http://www.jacuzzi.com/baths/options/models/espree-6032#
You can e-mail Jacuzzi from the webpage and they should send the pdf install document out to you.
Hope this helps!
May 10, 2011 | Plumbing
I have the espree 536 jacuzzi tub. which heater is required for this unit. i ordered the s750000 but it is the wrong one
you will have to look to see where the fitting is to install this heater.
there are two styles of heaters they use (mostly)
In-line pressure heater that installs after the discharge of the pump but before any of the jets.
the in-line Vacuum heater installs before the front of the pump in the suction line.
Jan 16, 2011 | Jacuzzi RapidHeat In-Line Heater U395000 [...
I have a Jacuzzi Espree 6036 and switch will not shut off whirlp
Hello. yes you can replace the switch. All of the parts come with instructions. plus you can call the jacuzzi repair technician directly and have him/her talk you through the procedure at 866-905-2289. here is the owner manual in case you don't have one
http://www.guillens.com/jacuzzi/images/ESPREE.PDF
Apr 02, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Whirlpool Jacuzzi with 10 jets one stopped working.
either one of ur hoses has come off or is stopped up get to the sides and see if one has come off
Feb 24, 2010 | Whirlpool 5' Jacuzzi Tub Bathtub Cetra...
Jacuzzi Bellavista 6 Whirlpool w/2-Speed Motor  JAC-EE20 Logo
706 people viewed this question
Top Jacuzzi Home Experts
Mike
john h
Donni Steen
Are you a Jacuzzi Home Expert? Answer questions, earn points and help others
