Question about HP LaserJet 3330 All-In-One Printer
Scan Hi. I would like to know how to install the scanner thing. im tryn to scan some documents but it tells me waintin on PC
  • Justcantscan Jun 02, 2008
    I had to disconnect my printer to move it and on reconnecting I noted the following. My printer and copying functions are fine, however I can't scan. I get an error message saying "An error has occurred while acquiring this image" or "unable to detect" . Appreciate any help Tx
    Problem Solver:
  • 9 Answers
There is a manual at this link.
http://www.printcountry.com/troubleshooting/hp_help.asp
You can also download the latest firmware/softare using hp's auto detection www.hp.com
Posted on Apr 22, 2008
I would like to scan a document. I am using the All In One printer. I am using a brother printer with the printer, fax, copier, scanner, and PC fax. How to I begin to scan my document?
Hi Gerrid,
There should be a scan program on the pc or a scan button on the scanner itself. You can go to the brother website and see if you can find a downloadable program for this unit. Alternatively, if the scanner is 'seen' by the pc, you can search your Windows program for "Windows Fax and Scan" from which you can select "Scan", if the printer is seen it will do the job, if not, it will tell you "No Scanner found".
If the scanner is not found, you can go to "Device Manager" and do a scan of the pc to detect "Plug and Play" devices. This should find the scanner.
I hope this answers your query, Please rate and comment, Thank You Joe
Sep 07, 2011 | Computers & Internet
Dont know how to scan a document
The first thing that you must do is make sure that the device is already installed to your computer. Insert the document to be scanned on the scanner. Double click the icon of your scanner and on the option menu click scan. After the scanning process, open the My Picture folder of your computer and locate the image file.
Sep 02, 2011 | HP Deskjet F4140 All-In-One InkJet Printer
I want to scan documents but i don't know how to do it. please give me the steps to operate the scanner
Title: Scanning a document
Hi, at first connect your scanner with your pc then-
?? Install your driver
?? After installation restart your computer.
?? When your computer start, go to "Start " and see the new installed software, open it and choose "Ulead photo Express" any thing which is your scanner supported.
?? Then open your scanner and put document into the scanner.
?? Close the cover.
?? In scanner a scan button is there , just push it.
?? Scanning will be start automatically.
Thanks!
May 13, 2011 | Computers & Internet
I AM ATTEMPTING TO USE THE SCANNER FUNCTION ON A CANON IR2230
Firstly, the machine must be connected to a pc or network. Secondly, you must scan the document to a pc so, after you have switched on, as you have, the scanner so that it says 'online' you will need to go to the pc and 'PULL' the document to the pc from the scanner. However, to do this you will need to have installed NETWORK SCAN GEAR on your PC inorder to SCAN. When you install the software, you will need to DISCOVER the scanner before it will be ready for use. So, a recap:
1. You NEED a program called NETWORK SCAN GEAR on your PC
2 Your ir2230 must be connected to a PC or network
3 You need to DISCOVER your ir2230 from your PC
4 You then need to INSERT picture FROM SCANNER and select your ir2230 from within a program such as WORD using NETWORK SCAN GEAR
Good luck
Jan 01, 2010 | Canon IMAGERUNNER 2230 Copier
HOW TO SCAN THE DOCUMENTS IR4570 TO P.C ????
On the device you want to chose the SCAN option and set it to ONLINE.
You then need an application that does TWAIN scanning and aquire image data. Set your scanner device yo "Canon Color Network Scangear".
A freeware product you can use to test is irfanview
You would otherwise need to do an aquire / TWAIN scan from MS Word or Adobe Acrobat (full/pro) or another software that does TWAIN scanning.
May 06, 2009 | Canon imageRunner C3100 Copier
Scanning to PC
hi,
try using the kodak aio home center
it is much easier and gives you more conrtol, including editing
dont scan directly from the scanner
Feb 11, 2009 | Kodak EASYSHARE 5500 All-In-One InkJet...
Driver scanner benq 3300u
If you have a BenQ Scan to Web 3300U, just plug in the scanner to your USB port on the computer and plug the power into the power bar. XP will recognize that you have connected the scanner to your pc. It will install the scanner immediately.. Go to MY PICTURES. The top option on the left hand side of the screen will be "to obtain pictures from a scanner or a camera". Click on this.. It will tell you that you have a flatbed#23 . Click on next. Using the preview button, scan the document. Using your mouse, make the scan box fit your picture or document. Then click on scan. Save your scan job . You can then view your scan job.
Dec 24, 2008 | BenQ Scan to Web 3300U Flatbed Scanner
I cannot get it to scan any more.
hi kenbush1;
Are you referring to your all-in-one printer? or a standalone scanner? what brand is it? how long did you experience this problem?
ple unstall ur scanner driver
and restatr computer
again install scanners driver
Jun 02, 2008 | Computers & Internet
HP PSC 1410
Hi ,
Please follow the below procedure to scan a document.
  1. Connect the scanner to the computer
  2. Install the software with the help of CD which you get from hardware manufacturer
  3. Open the Lid of scanner, Place the document you want to scan
  4. Close the Lid after placing document
  5. Open HP software which you have installed above, click scan now ( or any thing similar )
  6. Scanner will start scanning you can hear the sound and strong light rays passing through the document
  7. After this it creates a soft copy
  8. Save the file , by default is get saved in my documents you can save any where else if you want
  9. For better results veiw soft copy in PDF that is acrobat reader.
Hope this answers your post, Please let me know by providing your valuable feed back
Thanks,
Robosoft
Dec 24, 2007 | HP PSC 1410 All-In-One InkJet Printer
HP LaserJet 3330 All-In-One Printer Logo
60 people viewed this question
Ben Johnson
