Question about Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System
Very hot frame
The inside frame, where the doors meet in the center of the frig is very very hot.
    Novelist:
  • 77 Answers
Turn your frig off as soon as possible! this is an easy fix but if it goes to long it can cause permanent damage to the compressor and then you have a huge repair bill, or a big piece of trash :(
What has happened is this:
There is a fan called the condenser fan that blows air across the compressor to keep it cool. This fan has stopped working for some reason and now the compressor is VERY hot. When this happens it stops running and you get zero cold produced.
The reason the mullion is hot is because there is tubing connected to the compressor that is run through this area for condensation prevention purposes. When the condenser fan stops working, this tubing gets much hotter than normal, and that is what you are feeling.
So, replace the condenser fan motor before the compressor gets to hot that it damages itself! If I can be of further help please let me know, good luck friend!
Posted on May 31, 2010
I have a ge refig side by side the # is 62D581P016 the door frame where the gaskets are located gets hot to the touch. We have cleaned the back under the frig and the fan is running, however, it is st
Most modern refrigerators have heaters around the gasket to keep frost and condensation from forming. What you're seeing may be normal.
Sep 09, 2014 | Refrigerators
Small amount of water drips down from back/center top inside frig.
it sounds like the drain is blocked in the freezer.unplug it,pull everything out of the freezer,remove the back inside wall of the freezer,melt out all ice with hair dryer,next you'll see a hole under the evap coil,that's the drain hole,you have to clear the drain line,i use a steemer to do this,if you don't have a steemer you need something that will blow through the line like a turkey baster or something like that,keep heating up the area around the drain opening,also you can heat up the ceiling in the fridge section with the hair dryer,open the fridge door,in the back middle where the ceiling and back wall meet heat up this area,this is where the drain runs into the back wall,when you think the drain is clear pour a half cup of hot water into the hole,if it drains you're done,if not keep at it ubtil you free it up.
May 19, 2011 | Kenmore Top Freezer Refrigerator
Frig leak. I opened the door and it was very hot
condenser fan motor? compressor ? stalled in defrost? without mod# and more info who knows...
Aug 26, 2009 | Refrigerators
The freezer door pops open when the refrigerator door closes
there was an service flash on some type of these frig's but the fix was only a small spacer on the frig door where the gasket meet the frame not a very good fix to save frustation try less force or then again try to gap the gasket a bit not too much to allow air to enter too much
Aug 19, 2009 | GE Refrigerators
KitenAid KSRX25F -- HOT FRONT FRAME
The fan which cools the compressor is not working , OR , the coils under the front of fridge are very dirty .
Aug 01, 2009 | KitchenAid KSCS25IN Side by Side...
Frig is hot only in upper front (divider) where two doors meet.
need to see if your fan is running in the freezer side if not replace it if it is then check to see if you have frost on the back lower wall inside the freezer if you have frost then you have a defrost problem
Dec 29, 2008 | Frigidaire FRS3R5EMB Side by Side...
I have a side beside whirlpool refrigerator/freezer. today I noticed the strip between the frig and freezer was very hot and coil under frig are almost too hot to touch. It has been this way since about...
no danger of fire, they(Whirlpool) run a copper heat tube through the center mullion of frig, to cut down on amount of undesirable condensation that may build up between doors, reason for extra heat can be from leaving door open too long, perhaps the coils under the frig need to be vacuumed,
Oct 12, 2008 | Whirlpool Refrigerators
Kenmore side by side model 106.55512400 inside frame hot to touch
There is an electric heater in the center which is called a mullion heater. If you have an energy saver switch on your model turn it to the saving position.
Jul 13, 2008 | Kenmore 53642 / 53644 Side by Side...
Door frame really hot to touch
Also clean the coils underneath the unit as far as the fan (condenser ) you can put a house fan on the back blowing to cool the compresser until you get a replacement. That fan runs anytime the compresser runs
Jun 06, 2008 | Frigidaire FRS26R4A Side by Side...
Door frame around freezer door is very hot for a long time in side-by-side refrigerator/freezer
The problem you describe is caused by the hot gas pipe that runs around the cabinet, this is normal for it too get warm, the only reason it would be very hot is that for some reason the gases are not being cooled, probable cause is that the condenser is blocked with dust or fluff, depending on axact version some are located behind the plastic trim that runs below the doors and others are in the back behind the lower rear panel. Regards Advisor
Aug 30, 2007 | Kenmore 57029 Side by Side Refrigerator
Whirlpool 25.6 cu. ft. Side-by-Side Refrigerator with In-Door-Ice Dispensing System Logo
98 people viewed this question
Top Whirlpool Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Dan Webster
Dan Webster
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
