Question about HP OfficeJet 6110 All-In-One InkJet Printer
Couple of issues...
Couple of issues...
1) my color does not dry on glossy inkjet paper despite airing out overnight,
2) how so inset 4x6 photo paper into my HP 6110, I have always just used full size paper before
3) I cannot figure out how to print more than one photo per full size sheet, How to I fix that:
    Problem Solver:
  • 15 Answers
1. Is this an actual HP cartridge? 2. HP Photo Smart Essentials 3.5 software, available for free from HPweb site will let you change how many photos on each page.
Posted on May 30, 2010
How do I print postcards on HP PSC 950
Hello!
Here is your solution to print postcards size.. 1. Select your image and press mouse right . 2. Select print and select your printer. 3. There may be many sizes indicate there... but you must select 4x6 or 5x7 as it is postcard size. 4. Now select your paper quality (eg. Photo paper plus glossy ) 5. Press print.... That is it .... good luck
Sep 08, 2011 | HP PSC 950 All-In-One InkJet Printer
How do I print color photos on glossy paper with Canon Pixma MP 6
printer supports it. just you have to goto printing preferences or printer properties and set rear tray to accept glossy paper. it will accept size of paper ur using. so give the actual size.
Apr 23, 2009 | Office Equipment & Supplies
Paper jam
Unplug the printer from power for ten minutes.
Remove cartridges and put them back, open all doors and close them back.
Oct 25, 2008 | Canon PIXMA MP530 All-In-One InkJet...
When I use my Brother MFC-465 CN printer to print 4X6 photos with the photo paper bypass tray in proper position, it jams sending the photo paper through. Printer is set to 4x6; software set to photo as...
Hi there!
The compatibility of the paper may affect the issue that you are having. I have a brother printer also and prints on 4x6 size what i can suggest is to try turn the photo paper upside down, so facing the tray, 2 sheets at the bottom should have the glossy side up. and the sheet where you need to print the photo should be facing down. So when the paper roller grabbed the photo paper at the top it will smoothly pass thru,
Hope this helps! Vikroks
Mar 06, 2011 | Brother MFC-465CN InkJet Printer
When I insert the 4x6 paper portrait it won't advance it to print.
You are probably using a glossy paper or photo paper 230gsm or above, some printers are having a hard time feeding with those kind of papers, try using lower than 230 gsm.
Jan 11, 2010 | Epson Stylus Photo R320 InkJet Printer
When I print on photo paper the ink doesn't dry and picture quality is unrecognisable
You have to match your print settings with the correct type of media used !
When you print, set the preferences, set to PHOTO quality and not draft, set paper type to PHOTO PAPER, or GLOSSY PHOTO PAPER whichever - If you select wrong media type your colors might be off. Select the settings that match the closest to your media. If you use paper use "plain paper" setting, if you use glossy photo paper, use "glossy photo paper" as settings and PHOTO quality.
I recommend use you use inkjet PHOTO paper, glossy, you can use HP or EPSON or even the cheap LIKON ones work amazing for me, they should be able to dry quickly, if they don't you are not using the correct settings.
By your description above it looks like you are using economy or draft mode - NOT good for photo paper.
Sep 26, 2009 | HP Office Equipment & Supplies
Color not coming out right when printed
In this case what i would request u to do is....... Take out both the catridges from the Printer......... Take 2 Paper Towels one should be wet with Luke warm water and the other one should be  dry...........
Take the Colour catridge first turn it upside down and u will see a small copper plate on the  catridge from where the ink comes out.......
Place the wet paper towel using ur thumb on the Copper plate and press it a lit bit for 10  Seconds......
Now remove it and see whether u see any ink on the paper towel.......... U should see some ink on it now place the dry paper towel on the ink catridge in the same  way........
Now do the same procedure again.......... Do the same procedure twice on the Black Catridge................. Now take the dry paper towel and turn the direction of the cartridge so that u can see a  Copper plate on it with small boxes just clean that copper plate with the Dry Paper
Towel..........
Know insert both the catridges inside the Printer... Good Luck
Jan 28, 2009 | Canon PIXMA iP4000 InkJet Photo Printer
Epson printer that can print at art glossy paper
Epson's ink uses a dift technology so far better result you need to check what brand of glossy or photo paper you can use. You can purchase an epson photo or glossy paper for best results.
Your printer would work best using the list below:
Paper Types
  • Supports a variety of Epson plain and photo papers. Supports plain, bond, air mail, Epson Premium Bright White, Glossy Photo Paper, Premium Glossy Photo Paper, Premium Semigloss Paper, Premium Luster Paper, ColorLife paper, Matte Paper Heavyweight, Double-sided Matte, Inkjet Transparencies, Self-adhesive Sheets, Photo Quality Ink Jet Paper, Greeting Cards, High Quality Banner paper; labels; envelopes, Iron-on Transfers and Photo Stickers; Printable CD-R/DVD-R; Panoramic 8.3" x 23.4" Photo Paper
If you may have other questions pls feel free to ask.
Just rate me Fixya if your issue has been resolved.
Cheers.
Jun 17, 2008 | Epson Stylus Photo R300 InkJet Printer
Horrible print quality
hi i am a certified Canon repair tech for this printer. the first problem is the paper you are using hp photo paper is specialty formulated to be used with there inks. every manufacture is the same if you want the proper looking photo and you are using a Canon printer you need to use Canon photo paper because the paper is formulated for their inks. hope this helps to clarify.
Jan 04, 2008 | Canon PIXMA iP6700D InkJet Photo Printer
Balck ink not working
This is what worked (so far) with my Dell1.gif AIO A940 printer1.gif that wouldn't print black ink.
It worked for awhile when I chose photo/glossy paper, but then it quit printing again (see below).
PRINT, PROPERTIES, PAPER SETUP, SPECIALTY PAPER, PHOTO/GLOSSY
I got it to print, again, by putting SEVERAL papers in the feeder (instead of just 1) - there is a sensor that is supposed to automatically detect paper type, and it might not be working right, especially with one or only a couple of sheets.
Mar 16, 2007 | Canon S 330 InkJet Printer
HP OfficeJet 6110 All-In-One InkJet Printer Logo
139 people viewed this question
Seeker5211
Seeker5211
