Question about MSI K8N Neo3 Motherboard
I have a MSI K8N Neo3 MB with AMD 64 2800+ C. IPU; (1) PC-3200 256Mb and (1) 512Mb DIMM's; ATI video card. The unit has not changed in past 3 years and has worked fine. Now it just will not power down without pulling out the power cord. Windows is NOT a factor here (it goes through normal shutdown). The monitor shuts off but fans do not turn off. I have tried stripping the unit down to just the MB, CPU and one piece of RAM with same results. Tried new power supply - same. Checked on/off switch - no short. Tried different video card - same. I've checked the BIOS many, many times including a complete reset. Put in new battery. I pulled the CPU and checked all pins, sprayed contact cleaner on everything. Any suggestions???
  • 553 Answers
I don't know your experience level so if I'm to basic please don't take offense and if I not basic enough don't hesitate to ask for clarification. I've split this up into 3 parts; hardware, software and security.
First you should quit unplugging your computer to shut it off. If you don't have hardware problems already unplugging you computer while it's running is a good way to cause them.
Other than a physical problem with the CPU or motherboard you seem to have ruled out almost everything. If you haven't tried it yet try holding down your power button until the power supply shuts down (usually 10-30 seconds). If this doesn't work given what you've already tried you probably have a damaged CPU or motherboard or an incompatable power supply (any ATX supply should shut down).
If this does shut down your system your problem is more likely software related. There are several possibilities (all can cause the system to not turn off);
1) corrupted system files
2) corrupted system settings
3) malware (spyware, viruses, data miners, ect...)
4) hacked system (there are numerous possibilities here)
a) to get an idea if you've been hacked open system info in control panel, if your RAM is showing considerably less than what you have installed that's a strong sign you've been hacked.
I would recommend doing a new install of Windows, not a reinstall. Your problem could be corrupt settings and Windows may import your old setting with a reinstall. If you have a spare hard drive I'd do the install on it, this will allow you to save your data while you determine for certain if the problem is hardware or software related. If this doesn't solve your problem then your problem is (again) most likely hardware. If you determine it's hardware, you need either spare parts or expensive testers to determine your exact problem.
If a new install on another drive solves your problems you need to consider items 3 and 4 above. A new O.S. install should solve the problem for now but you need to consider your security options. You'll need a firewall, anti-virus and anti-spyware. You should also set the password on your CMOS/BIOS. If you can use accounts with your version of Windows set up a (supervisor) maintenance account and a (limited) user account. Use passwords on these accounts, use the user account unless your actually doing system maintenance that requires superviser access, this will help limit the ability for others to make changes to your system.
Your passwords for your CMOS/BIOS and supervisors should be strong, at least 14 characters with upper and lower case letters and numbers if your system will allow it included special characters. Write these down and store them in a safe place, the only persons you should tell your passwords should be "me, myself and I".
Posted on Jun 04, 2010
Will My ATI RADEON 9550 Video Card Work With GTA IV/4? the boz says: "ATI RADEON 9550 FUELED BY SAPPHIRE" "256MB DDR MEMORY" "WITH TRIXX OVERCLOCKERS UTILITY" This Is The Same As My Video Card:...
these are the specs you need!!
Minimum System Requirements
  • OS: Windows Vista - Service Pack 1 / XP - Service Pack 3
  • Processor: Intel Core 2 Duo 1.8Ghz, AMD Athlon X2 64 2.4Ghz
  • Memory: 1.5GB, 16GB Free Hard Drive Space
  • Video Card: 256MB NVIDIA 7900 / 256MB ATI X1900
Recommended System Requirements
  • Processor: Intel Core 2 Quad 2.4Ghz, AMD Phenom X3 2.1Ghz
  • Memory: 2 GB (Windows XP) 2.5 GB (Windows Vista)
  • 18 GB Free Hard Drive Space
  • Video Card: 512MB NVIDIA 8600 / 512MB ATI 3870
Jun 15, 2010 | ATI RADEON 9550 Graphic Card
Can I Play gta IV/4 on my pc? Specs Ar As Follow: DELL PRECISION 650 With: 2X Seprate Intel Xenon CPU's @ 2.40Ghz Each (4.80Ghz Tot) 1.50GB RAM (Memory) 80GB IDE Primary, 40Gb IDE Seccondary, 40GB...
Source :- IGN PC
this is what it says on the box...so if you dont have these specs..forgett it!!
Jun 15, 2010 | Rockstar Games Grand Theft Auto™ IV for...
I need the user guide board K8N neo3
try to google the number-youll find something also search msi's website
good luck!!
May 04, 2010 | MSI K8N Neo3-F Motherboard
Can i run ati radeon HD3650 512mb on asus k8N motherboard
you can upgrade your processor to a 3200+ or a 3600+ but the problem is availability and it should be socket 754 pin compatible...
regarding the HD3650 card...as long as its aa AGP card you should not have any problems..
also check your SMPS (power supply) it should be atleast 350(V)..
Jan 28, 2009 | ATI RADEON HD 2400 PRO Graphic Card
firstly you need to make sure *********** board has a PCIe slot or a AGP... this is where your ATI HD3650 will go...see the graphic 512mb has nothing to with your main system RAM which is also 512mb.. so they wont be any problems as such and both will work together without any problems... but i suggest you to add another 512mb to your system RAM.. the difference between DDR and DDR2 is that... DDR2 is a bit newer and is faster in terms of memory read/write/access... do let me know if u have any futher problems....
Jan 27, 2009 | ATI RADEON X1650 Graphic Card
Can i run ati radeon x1650 512 on asus k8N motherboard
Yes you can run the AGP version of the Radeon 1650 pro on your system. It is always best & recommended to upgrade memory in pairs. You could upgrade to `gb by purchasing a 1 gb kit which would be 512 x 2. That way you have a matching pair of RAM modules. As for a cpu upgrade you can go to the Asus website and see what cpu's are supported by your motherboard. Hope this helps & please remember to rate my answer. Thanks.
Jan 24, 2009 | ATI RADEON X1650 Graphic Card
Memory synchronization Problem
Did you reset the cmos on board first?
Jan 18, 2009 | MSI K8N Neo3-F Motherboard
Vista Home Premium locks up on a load
How long do you wait before you determine it is locked up? Vista uses minimum graphics to facilitate a faster install. It may seem like nothing is going on when Vista is loading in the background. If it is locking up try a reinstall. Are you upgrading or going a new install?
Dec 30, 2008 | MSI K8N Neo3 Motherboard
MSI K8N Neo3 Motherboard Logo
67 people viewed this question
Top MSI Computers & Internet Experts
vsri9
Alun Cox
David
David
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
