Question about Garden
3.5 hp b/s edger motor replaced gas tank gasket, and carb diaphragm. will start and run if I pour gas in carb.. wont **** from tank
    Scholar:
  • 38 Answers
If this is a vertical crankshaft 3.5 then you may have the gasket and diaphragm inverted, the diaphragm must be against the tank, and the gasket against the carb for the fuel pump to work, also check the pickup tube screen for being plugged, water in the tank bowl or a film or varnish or oxidation on the main jet sock.
If this is a horizontal shaft, like a go-kart, all the stuff about plugged pickups and main nozzles applies, only big difference is if there was a lot of corrosion in the bowl under the carb, the main jet could be permanently plugged, also there should be a removable jet on the control lever side of the carb that will probably need cleaning as well, also when removing the carb from the tank make note of any fuel in the bowl, if there isn't any, make sure the pickup tube isn't plugged or split, the diaphragm spring is installed, and the bowl doesn't have a hole rotted through it.
Posted on Jun 01, 2010
Engine runs but back fires then dies when put under load
Rebuild the carburetor. Just replace the old gaskets, diaphragms, needle and seat. You can get a rebuild kit from your local lawm mower repair shop. also, don't run last years gas and if you keep gas in the tank over the winter buy a winterizer and pour it in the tank when starts to get cold. Hope this helps!
Apr 12, 2014 | 5.5 HP GX160 Engine
My Craftsman 17cc gas weed trimmer wouldn't start.
Hi There, Check the primer bulb for tare or pin holes. Replace it. Check and clean carb jet it maybe plugged with debree. Also check for spark which you didn't say. Replace with correct plug.
Note; Do not use strong cleaners on rubber seals (O rings and gaskets) They dry up and crack.
If needed use a dabble of grease on seals
Jun 13, 2011 | Craftsman Garden
My yard machine Edger 3.5 hp wont stay runing if i put ges in the air filter hole it runs for a few sec. if I put my hand completly over the hole on the air filter it will run on low idle but as soon as i...
remove the gas can carefully the pulsa primer carburetor sits on top. Once you remove the tank open the cap and pour out the gas. THen carefully unscrew the five screws holding the carb on. Carefully lift the carb up leaving the gasket in place and clean the small 4 chambered bowl with starter fliud. Replace all parts put gas in it, push the primer until you see gas squirt into carb then pull the handle.
Sep 03, 2010 | Yard Machines Red Edger
Stihl model f545 will start but will not throttle up
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
I’m happy to assist further over the phone at https://www.6ya.com/expert/rolandw_c013176d62ee17ae
Nov 24, 2009 | Husqvarna Garden
Bp30185 wont full run wide open
1) spark plug
Chain Saws:
Remove Carburetor
Nov 22, 2009 | Homelite Garden
Mcculloch start with choke will run when choke in will not run when use throttle wont pick up
1) spark plug
Chain Saws:
Remove Carburetor
Nov 21, 2009 | McCulloch Garden
No gas when you prime it
1) Check fuel lines from tank for cracks, fuel filter in tank, primer bulb for cracks
2)Remove Carburetor
Nov 13, 2009 | Craftsman Garden
Yard machine ym26ss straight shaft trimmer. New gas,
1) spark plug
Chain Saws:
Remove Carburetor
Nov 12, 2009 | Yard Machines Garden
Wont run in run position
if it runs on choke only and it sat up for two or three months the carb diaphragm may be brittle and not pumping fuel. install a carb diaphragm and gasket kit or try opening the high speed jet a 1/4 turn
Jul 01, 2009 | Craftsman 25cc Gas Line Trimmer
Craftsman weedeater will not start
The most probable problem is no fuel delivery to the engine.
1. Check/replace the fuel in-tank filter, you should be able to easily blow through it once removed. The primer bulb will sink down and not return quickly if the filter is bad. Fuel will not return to the tank via the return line if the fuel filter doesn't allow fuel to be pulled in.
2. If fuel is returning to the fuel tank when the primer is pushed then your problem is inside the carb.
3. To verify this put a small quantity of gas in the lid of a water bottle (half full). And pour it into the carb throat. Replace the air filter to prevent a backfire from shooting flames out. Try to start the weedwacker. If it runs and then dies the problem is inside the carb.
4. If you are really good at working on things with small parts you can clean out the carb and replace all of the gaskets to solve the problem. If this isn't for you then you should take it to a lawn shop and have them clean the carb and replace the gaskets.
NOTE: Replacing the gaskets is very important because the gaskets get stiff and the fuel pump action of one of the gaskets is reduced or stopped.
Hope this helps, Karl
May 20, 2009 | Craftsman 25cc Gas Line Trimmer
Garden Logo
41 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
