Question about AO Smith Pool Pump Motor Hayward Swimming Pool Pump Full Rated Motor / Cen
Pool motor makes a buzzing sound but doesn't work
I have a 2 HP AO smith motor on my pool filter and when I flip the timer switch on it makes a buzzing sound at the motor but does not come on. I checked power at the timer and have 118 volts on both sides. I have not checked power at the back of the pump as it is too difficult to get to. I'm assuming some power is getting there because of the buzzing sound. I also reached inside of the pump and spun the impeller to make sure the motor is not seized up. I bought the motor a few months ago from a rebuilding company so it's not very old. Any suggestions or help would be greatly appreciated.
Thanks,
Jim
  • AO Smith Master
  • 1,384 Answers
Sounds like it has a bad capictor .. look fr a otor shop in your area that tsts them , should be free test
Posted on May 31, 2010
POOL FILTER BUZZING
bad motor replace whole unit less hassle
Aug 12, 2012 | AO Smith Pool Pump Motor Hayward Swimming...
Pool Pump Motor (AO Smith 2HP 56Y CX) won't turn over when switched on. Makes slight humming sound. Removed the motor from pump housing. When I spin the impeller when powered on, the motor starts up
3 THINGS QUICK.. RUN CAPACITOR THIS IS LOCATED ON TOP OF MOTOR HAVE IT CHECKED. OR START SWITCH DIRTY OR STAR CAPACITOR BAD.. SEARCH YOUR AREA FOR YOUR LOCAL POOL PUMP MOTOR REPAIR GUY WITH FREE TESTING.. WARNING THESE CAPACITORS HOLD HIGH VOLTAGE AND WILL NEED TO BE SHORTED ! USE A DRY RAG AND COVER CAPACITOR THEN SHORT WITH SCREWDRIVER
Dec 26, 2011 | AO Smith Pool & Spa
Ao smith century 1 hp 56y pool pump sqeals for few minutes at start up and then is ok - sounds like bearings - unit 6 yrs - what is fix
How do I change the front and back bearings in this pool pump motor 1hp. ao smith motot I did the shaft seal last year myself but needs bearings now. thank,Bill
Feb 06, 2011 | AO Smith 1 hp 3450rpm 56Y Frame 115/230...
First stage of my 2 speed hot tub ao smith pump doesnt work electrcian says switch is not lined up right?
these are a hard motor - pump to work on. i would take it to your local pool pump motor repair guy who has free motor testing , un plug the motor from the control box not at the motor, if you do take pictures or make a diagram of each wires place ! if you hook it up wrong you can BURN THE MOTOR UP AND THERE IS NO FIX'N IT. sept for a new motor $$$ yuk .take the pluming lose and leave the pump on the motor.... good luck .. hope i was a little help if so please leave feedback .. Jay THE PPMRG FLORIDA
Aug 01, 2010 | AO Smith 1.5hp Pool Pump Motor 2 Speed Ao...
My A.O. smith pool pump doesnt seem to be getting electricity. It makes no noise at all when you turn it on. We had a storm last night I don't know if it tripped some sort of switch. I have checked the...
VOLT METER TO THE 2 LINES 230 OR SO ? THE MOTOR MAY BE BAD.. SEARCH YOUR AREA FOR YOUR LOCAL POOL PUMP MOTOR REPAIR GUY..USE YOUR ZIP CODE ... GOOD LUCK AND VOTE FOR ME...JAY
May 31, 2010 | AO Smith 2 hp Swimming Pool - Jet / Well...
Motor has died, how to disconnect from pump. 2
The thru-bolts hold it to the seal plate and the impeller is threaded onto the shaft.
Aug 09, 2009 | AO Smith Pool Pump Motor Hayward 2 Speed...
Pump cuts off when water gets on motor
CHECK VOLTAGE AT THE MOTOR.. SOUNDS LIKE YOU MIGHT HAVE LOSE WIRES AT THE MOTOR, TIMER, BREAKER OR A SWITCH IF YOU HAVE ONE I'M YOUR LOCAL POOL PUMP REPAIR GUY IN LONGWOOD FLORIDA. WHERE THE POOL IS ALWAYS OPEN
Jun 25, 2009 | AO Smith Pool Pump Motor Hayward Swimming...
AO Smith Pool Pump Motor Hayward Swimming Pool Pump Full Rated Motor  / Cen Logo
839 people viewed this question
Top AO Smith Pool & Spa Experts
Jay Finke
Jay Finke
Steve
Colin Stickland
Colin Stickland
Are you an AO Smith Pool and Spa Expert? Answer questions, earn points and help others
