Question about CTX PL 9 19" CRT Monitor
Re: CTX monitor getting blurry
Hello! My monitor gets blurry / fuzzy the longer it is on. Any suggestions?
  • 180 Answers
Hi Beth,
Your focus screen network turn faulty. It can be solved by by passing the original focus screen network to a new assembled focus screen network.
Posted on Apr 09, 2008
Screen locked
I would suggest turning the monitor off and unplugging it. Then retry the settings.
Try this manual:
http://support.octek.com.au/Downloads/Files/CTX/S762A.pdf
Jan 07, 2012 | CTX S762A 17" LCD Monitor
My monitor got bumped in a move and all of the text on the display is now fuzzy....any suggestions?
The picture board on your monitor is malfunctioning that is why the display is now fuzzy, This is a sign that the picture board of your monitor has developed fault.
The best thing for you to do now is to take the monitor to a local repairer within your vicinity to help with the replacement of the picture board because the fault is not something you can fix yourself, in order not to complicate issues.
Take care.
Apr 23, 2010 | LG 22" FLATRON LCD Monitor
My monitor's screen resolution and color depth are at a very very low resolution and I am unable to increase/improve this. Consequently, everything is fuzzy and colors are impossible to view. My monitor is...
please try doing a factory reset of the monitor.
please press the menu button on the monitor itself. you can easily locate the buttons below or on the right hand side of the screen on the monitor panel.
select the factory reset /recall options with the help of the arrow/+ - buttons.
this would reset your monitor color settings to default.
Jan 22, 2010 | CTX Computers & Internet
I have a ctx moniter says undectected mode
CTX 15"1024x768 TFT LCD-Black Monitor · i have a ctx moniter says ... Answer. i have a ctx moniter and wen i plugnitin to pc tower itsays undeceted mode watdoes this mean. Close Close. ASUS Eee PC 1000H
Dec 03, 2009 | CTX 15"1024x768 TFT LCD-Black Monitor
Hello, A family member gave me a CTX S760 17- LCD Monitor. When I hook it up and start my PC the screen looks GREAT for about 15 sec or so and then goes black. Same thing will happen if I power off the...
christoph972, This really sounds like a SMPS going into SHUTDOWN MODE after detecting a fault in the "cold-cathode-fluorescent-lamp" electronic ballast circuit which is called an INVERTER CIRCUIT, or it has a problem all by itself. The big question is? ? ? WHAT is causing the fault? I need you to do the flashlight test to evaluate the condition of the LCD monitor's "switch-mode-power-supply". With a KNOWN-GOOD, fully booted pc that has the WIN-desktop showing, reconnect the S760 to the pc. then and only then push the "ON" button for the monitor and note what happens. After the screen goes black, shine a bright flashlight at different angles about 1" from the LCD screen. Get back to me with the results of test. Did you see or not see the WIN-DESKTOP? Also visit YOUTUBE and search for and view videos of typical lcd monitor disassembly and or lcd repair. FYI only!! The longer ones (8-12min) will be more informative. The symptom you have with this freebie monitor is classic! It could possibily be repaired for $12 or less. Get back to me here at fixya by posting another comment to the above stuff you already did. I"m louie12fix onfixya or lmistyrel @aol.com
Oct 08, 2009 | CTX S760 (Beige) 17 in. Flat Panel LCD...
Xbox 360 Blurry/Fuzzy Screen
The machine is overheating and the graphics chip on the main board is acting up cause of it. Make sure there is no dust or dirt blocking the air vents that would cause the system to heat up more then normal.
If that doesn't do it then maybe think about getting a cooler for the system, here is a website that talks about a few of them. Click here.
If that doesn't help then your mainboard is going bad and would need to be replaced.
May 29, 2009 | Microsoft Xbox 360 Console
Fuzzy lines on my monitor
Good morning! possible that there is a loose/cold soldered electronic part/s inside your monitor. I suggest to get assistance from a professional service electronic techinician for proper identification of defective part/s & fix it. best regards
May 08, 2009 | Dell Computers & Internet
Blurriness/Fuzziness
Hi, Using the OSD, select the Auto image adjust.
Sep 15, 2007 | ViewSonic VA703B LCD Monitor
Picture is going fuzzy and blinking red light...
This is the classic symptom of a CRT (picture tube)that is starting do get weak. The picture takes longer and longer to come on, it appears greenish and blurry, and it blinks on and off in different scenes, and when it is off the timer LED blinks 5 times. Sony has a circuit called "IK Blanking" which monitors and adjusts the colors in the picture tube, and shuts the picture off when the tube is getting too weak. The good news is that the Sony tubes always respond beautifully to a CRT rejuvination (recharge), and the picture returns to perfect. Since the set is 36 inches and VERY heavy, it should be serviced in-house and an appropriate charge for a service call for your set should be around $150.
Jun 22, 2007 | Sony KV-36XBR400 36" TV
CTX PL 9 19" CRT Monitor Logo
759 people viewed this question
Top CTX Computers & Internet Experts
Rommel Balcita
Jerry Greenberg
Jerry Greenberg
Are you a CTX Computer and Internet Expert? Answer questions, earn points and help others
