Want to replace my cooling fan on an acer 2350 cannot grt it apart??
  • Obakeng Diale May 11, 2010
    Travelmate 2350?
  • William Rodriguez
    William Rodriguez May 11, 2010
    Are you talking about the Travelmate 2350?
    Sergeant:
    Champion:
  • 293 Answers
Bring the laptop to the service center to be safe
Posted on Apr 08, 2008
Why isMy Acer aspire gettting really hot, would replacing the battery help?
Sometimes, the computer gets really hot because the "ventilation" (cooling) system (fan, etc.) is not working properly. Normally, if it gets too hot, i.e. to an unacceptable level, the system will shut down. Or, it will catch on fire.
Yes, it's known that some battery will get too hot ... and potentially damage the system. So, if you already know that the cooling system is working properly, then try replacing the battery.
May 28, 2014 | Acer Aspire One PC Notebook
I need a large image of acer travelmate 2350 motherboard
http://www.nodevice.com/user_manual/acer/SOUND/travelmate_2350.html#.U4ZI3HamXp8
May 27, 2014 | Computers & Internet
Acer guet hot end shut down en 10 minuts
Three reasons laptops get hot:
1) Dust - Dust inside the laptop, dust clogging the vents and fans, dust around the cpu and heatsink. Remedy - take laptop apart and use a can of compressed air to blow out the dust.
2) A Fan not working - Listen and see if your fan is working, Air should be pulled in through the vents. Remedy - take laptop apart and replace the fan.
3) The Thermal Paste around the CPU and Heatsink has either dried up or is too thin to keep the unit cool. Remedy - Take the laptop apart and put a fresh coat of Thermal Paste around the CPU and HeatSink.
You could purchase a Laptop Cooling Pad that the laptop sits on and it plugs into the usb ports to keep the laptop cool. Try Tiger Direct at:
http://www.tigerdirect.com
When the site comes up just type: Laptop Cooling Pad in the white search box at the top and click GO. Sort the returned results by Price Low to High.
Below is a link to one that I use when someone can't afford the expense or have the time to take the laptop apart. It costs $12.99
http://www.tigerdirect.com/applications/SearchTools/item-details.asp?EdpNo=1879782&CatId=3486
Jun 02, 2012 | Computers & Internet
Aspire 5742 i3-370m overheating how do i fix it
Three things that will make a laptop overheat:
1. Dust - Dust inside the laptop, dust clogging the vents, dust around the fans, dust around the cpu and heatsink. To fix it, take the laptop apart, take a can of compressed air and blow out the dust.
2. A fan is not working. To fix it, you will have to take the laptop apart to replace the fan.
3. The Thermal Paste around the cpu and heatsink has dried up or is too thin to keep the unit cool. To fix, take the laptop apart and apply a fresh coat of Thermal Paste.
Another work around for a laptop that is overheating is to by a Laptop Cooling Pad that has fans on it and it plugs into the usb port of the laptop. The laptop sits on it and it keep the laptop cool. You can buy a laptop cooling pad for less than $20 from Tiger Direct.
When the site opens just type Laptop Cooling Pad in the search box at the top of the screen then press GO. Sort the returned results by Price Low to High.
May 16, 2012 | Acer Computers & Internet
I have acer 4530, and it's going mad, my laptop temperature reach 90 -100 degree. it's going burn, please help...thx
Hi neo nietzsch...
Sounds like your cooling fan is faulty...
You need to try and blow the dust out of it using compressed air, by blowing air into the exaust of the laptop and hopefully this will clear your fan of dust and make your laptop run cooler.
If that does not solve the problem then your going to have to take your laptop apart and replace the cooling fan as it is defective.
Please take time to rate me
Aug 30, 2011 | Acer Aspire 4530-5889 Notebook PC
My computer overheats and shuts down. The more programmes you use the quicker it shuts down. So fed up and Acer want a fortune to fix it. can i fix it myself.
Yes - take apart the CPU fan. Underneath is the CPU. Remove the old heat compound (silicone) and re-apply new compound. Don't forget to clean the fan assembly and heat fin radiator - it'll have lots of dust and dirt. Here are some pictures: http://www.facebook.com/album.php?id=104583522919354&aid=7377
Feb 14, 2011 | Acer Aspire Z5600 (AZ5600U2092) 23 in PC...
Acer travelmate 2350 wont boot or display
I have seen this on several ACER Laptops. It is always the Motherboard. Contact Acer repairs and order a new motherboard. IT will likely be about $200ish dollars. Then follow one of the guides on the web for taking your laptop apart and replace the board.
Feb 15, 2009 | Acer Computers & Internet
Starting problem
Hi, This indicates that the cooling fan for the CPU has failed, you will need to have it replaced ASAP and it is a good Idea if you are using this computer as your home unit to purchase a cooling pad to rest it on.
Regards mistyman
Aug 14, 2008 | Acer Computers & Internet
Noisy fan old older computer
Buy a new one here for $10
http://cgi.ebay.com/NEW-DELL-DIMENSION-2350-2300-CASE-FAN-92mm-x-25mm_W0QQitemZ250245854784QQcmdZViewItem
May 10, 2008 | Dell Mini Fan. Dimension (W x H x D) in....
Computers & Internet Logo
David Payne
David Payne
