My harmon kardon av amp keeps losing its memory/settings when its switched off, it also loses audio on the 3/2/1 on the aux, dvd channel, intermittent loss of volume help, too good a system to bin thanks
    Problem Solver:
  • 14 Answers
Could be the memory chip, I used to see this a lot with Panasonic tv's that would lose all memory settings ie channel and tuning memory, with the intermittent vol problem it sounds like dry joints in the amp section, always check the components around the heatsinks for dry joints, especially capacitors and transisters, pay to get your hands on a service manual showing all the layout and different componets.
Posted on May 31, 2010
Not getting any sound out of speakers help please :(
You need to set the device on the aux mode. Connect the cable at aux. Sign at the back of the device
good luck
May 07, 2015 | Harmon Kardon Harman Kardon Harman/kardon...
No disc error dvd
You need to try cleaning the lens of the player. If that doesn't correct it you might have lens damage.
Jul 28, 2013 | Harmon Kardon Harman Kardon Bds 400 2.1...
Harman kardon 2650 auxiliary ports 2,3,4doesn't work
if you are talking about the hdmi ports, 3 are ins and one is out, but I use the hdmi from player direct to tv, and use coax or optical connection to my receiver for the audio
Mar 23, 2013 | Harmon Kardon Harman Kardon AVR 2650 7.1...
We are hooking up our harman kardon avr 2600. does the pvr & dvd player go in to the receiver then out to the tv?
only if the harmon kardon has video in (yellow) and video out. otherwise just the audio should go into the harmon
Mar 13, 2011 | Harman Kardon Audio Players & Recorders
No Memory Stotred in Harman Kardon AVR 65
You have a memory cap ,usally located on the front display,that is most likely defective.measure voltage on cap with unit off should measure at least 3-5 volts
Apr 10, 2010 | Harman Kardon AVR 35 Receiver
I am wanting to connect my portable wharfdale dvd player to a tv. where can i get the right connection cable. thanks
Usually somewhere like radio Shack will have those cables, they are called AV, Audio Visual Cables, You need 3 Cables, with "Male Jacks" at both ends, usually Red & White, (The Audio), & Yellow, (Video). They connect color to color at each end, and on the TV you select "Aux", "Extern", but NOT a channel. If you have "Component Video, then you will need a set of 3 & 2 cables, (5 all together) Blue, Red, Green, ALL Video, & White & Red, Audio. you select the "Input" on the TV the same as for AV. So with AV, you use 3 cables, with Component, you use 5. If HDMI you need a single HDMI cable. cables.
Feb 21, 2010 | Televison & Video
I have a Harman/Kardon AVR 325. Left speaker not working with TV
How is TV audio (from the cable box) getting into the Receiver? If digitally, you wouldn't be missing any one channel on a connection malfunction, you'd lose them all. If analog, swap the channels around to isolate the problem (and reconsider using digital).
Feb 11, 2010 | Onkyo HTR500 Receiver
Harmon Kardon AVR 235 no sound
Ensure that your speakers are connected to the terminals that you have your speaker selector switch turned to.
Then check that you have your device, whether it be a CD or DVD player, or turntable, plugged into the correct input and that you also have the correct input selected on the receiver.
Dec 29, 2009 | Harman Kardon AVR 235 Receiver
Losing memory settings
On remote control before you shut off yor receiver press "TEST" button to save the memory. It will save every setting. Make sure to do that all the time after you change the setings.
Nov 23, 2008 | Onkyo HTR500 Receiver
Hooking up an amp
plug eash units sound in red whites from dvd tv main out the set speaker wires in place front ch a ok turn it on make sure ch a speakers on only select corect video input dvd ect turn it up
Feb 11, 2008 | Harman Kardon AVR 130 Receiver
 Grubhead
Grubhead
