Question about Tatung V20KQDX 20.1 in. LCD Television
Please hgelp TV turns on and then powers back down seconds later.
  • 11,361 Answers
Check the power supply for bad caps with leaking/bulging tops first, the power supply may have gone into shutdown mode if it senses shorted circuits such as shorts in the backlight inverter board. Before buying the power supply, you need to checkt the inverter circuits first.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Posted on May 31, 2010
  • Tatung Master
  • 8,457 Answers
Power supply board is dead,the board that where the power a/c cord plug into it.Replaced the power supply board will solved this problems.Tries websites like Shopjimmy.com,Ebay.com to buy a refurbish power supply board for the replacement.
My computer laptop And Tv Got Hacked by a Samsung Galaxy s2
Power-off the cellphone.
Remove the SIM card.
Put it into a new cellphone.
Dec 21, 2013 | Microsoft Windows 7 Home Premium 64BIT...
AKAI MODEL CFT2716. AT POWER ON TV COMES
AKAI MODEL NUMBER PT50DL24 it turns on then goes off n all th screen says LAMP TEMP WHAT DOES THAT MEAN N WHAT DO I ND TO GET IT WORKING
May 10, 2010 | Akai CFTD2011 20 in. EDTV-Ready LCD...
Turn power on, approx. 30 sec later it the power
It varies as to what is actually making the TV shut down. Shorting the connectors on the A.C. plug have nothing to do with it turning back on. Its just the fact you are unpugging it for a few moments.
Nov 11, 2009 | Zenith Z19A11S TV
TV turns off and on
you have bad electrolytic caps in the power supply---remove power supply replace swollen caps--if you do not think you can replace caps try shopjimmys.com enter model number scroll down to find power supply-if they do not have in stock write down part number then google it to find one
Sep 15, 2009 | Samsung LN-T4061F 40 in. LCD HDTV
I power on tv and it shuts down after few seconds
There is a high voltage leak here, the reason it closes down is the protection mechanism isw trying to prevent more damage. better to turn it off and have it repaired before it catches fire or blows all the boards and becomes totally useless or beyond repair.
Sorry this isnt what you wanted hear but there is a safeyty factor involved here.
Please rate our help to keep the FREE service online ++++
Aug 31, 2009 | Mitsubishi WS-55807 TV
TV turns on, then turns itself off about 2 seconds later.
set has a self diagnostic---after set does shut down press and hold MENU AND DEVICE(INPUT) buttons on front of set for 5 seconds----if 2 blinks, a pause and 2 more blinks: this is short protection error code---The set does use 2 Stk394-250 and each is protected by a pico fuse in the power supply---if either fuse is blown the set will shut down(it detects no voltage or missing voltage;) It is not uncommon for a shorted IC to cause this problem; if you locate the STK's look carefully at the resistors around them---if any are discolored or burnt---you have found your problem.
Aug 17, 2009 | Mitsubishi WS-65413 65" Rear Projection...
Tv comes on just the sound about three seconds later tv shuts off
I have the same issue with mine and have a solution that sometimes works. I had a repair guy come to check it out and he powered off the TV so that the red light was no longer blinking, then he unplugged the TV for about 30 seconds or so and then plugged it back in. He then turned on the TV and it worked. He said it would cost about $400 to fix the issue (some circuit or something). I have since expeerienced the on/off problem (due to power outage) and now I cannot get the TV to work. But at least give this solution a try and please post to let me know if it worked or not. Good luck!
Dec 23, 2008 | Sony FD Trinitron WEGA KV-32FS120 32" TV
MagicSing EG-18000 TV picture
i believed the problem is the TV mode. (NTSC or PAL mode)
try this
turn mic OFF
press and hold 8 then press power buton (PAL to NTSC)
or
turn mic OFF
press ang hold 9 then press power button (PAL to NTSC)
customerservice@magicmic.com
Sep 05, 2008 | Magic Sing Along Consumer Microphone
Tatung V20KQDX 20.1 in. LCD Television Logo
320 people viewed this question
Top Tatung Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Josh Whitehead
Josh Whitehead
Are you a Tatung Televison and Video Expert? Answer questions, earn points and help others
