Question about Ricoh Aficio 1035 Copier
Code sc 541 is poping up - Ricoh Aficio 1035 Copier
  • 155 Answers
SC 541 is caused by a defective thermistor check clean or replace the thermistors (center and Edge) of your fuser unit
Posted on May 31, 2010
  • Joel Baleta
    Joel Baleta May 31, 2010
    after cleaning/replacement of the thermistor reset the unit.
    1.On the operation panel, press Clear Mode ".
    2. Use the number keys to enter 107.
    3. Press and hold Clear/Stop # for three seconds.
    4. On the touch-panel, press Copy SP.
    then turn off the machine then on again.
Sc 541 in sp 100
THIS QUIESTION NOT CORRECT , SC 541 ERROR IS SCANNER ERROR PLAESE CHEQUE THE SCANNER CABLE
Apr 28, 2015 | Office Equipment & Supplies
Errore code sc 541
kindly call for a change of themostat
Feb 02, 2013 | Gestetner DSc338 Copier
Errore code sc 541
Your problem is in the fusing unit.Check the thermistors and thermofuses.Reset the code :
Interrupt(yellow)key - 1 0 7 -press and hold STOP/CLEAR key more 4 seconds,enter in SP mode,open the front cover,turn OFF the main switch,wait 1 minutes,close the front cover,turn ON the copier.
Error cod sc 541
This SC-541 code comes when the fuser thermistor fails ore contaminated or poor connecton finellay power supply bord defective most of this cases we find thermistor failure first replace the thermistor 90% your problem solves- thankyou
Dec 15, 2010 | Ricoh Aficio MP 1600L Black and White...
Sc 541 power off on
sc 541 is a fuser error. you have to reset the code. here are the steps to follow.
press clear mode button once, clear mode button is the yellow one
press 107
press and hold clear/stop red button until you see the screen changes to copy sp mode written.
press copy sp on the screen and off and on the machine
it should reset the code.
Oct 26, 2010 | Ricoh Aficio 1035 Copier
Ricoh Aficio MP 2510 SC 541, SC 542 Errors
To clear level A SC codes such as this SC541, you need to
Enter SP mode, and then turn the main power switch off and on, only.
Please check if the thermistors are the proper ones and are installed correctly in their position properly.
This is also useful for SC542.
Please check the thermostats and fusing lamps for open circuit.
Good luck and please rate me, thanks.
Jan 17, 2009 | Ricoh Office Equipment & Supplies
Code 541
hi!!!!!
may be the was damaged
or
try to clean use dry tissue
or replaced the drum
Sep 21, 2008 | Ricoh Aficio 2018D All-In-One Laser...
Error code sc 541
I have infotec machine when I powered machine a error code genereted sc 541 what is the solution?
Err0r sc 541
Hi
fuser code your thermistor is bad
good luck
Error Code SC 541
Its a fuser code. Hold down both of the arrow keys for 10 seconds, then press enter. Select 2 for engine, ok, select 7 for data log, ok, scroll to 7807 and execute. exit all of the way out until you get back to engine, then select 3 for end. Recycle power.
Apr 01, 2008 | Ricoh Aficio AP600N Laser Printer
Ricoh Aficio 1035 Copier Logo
338 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
OfficeServiceAjnc
OfficeServiceAjnc
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
