Question about JVC GY-HD100 Mini DV Digital Camcorder
MY JVC GY-HD100 Wont capture properly in Final Cut Pro. Always shows time code breaks where there are none. Only capture a minute or two at a time. What can I Do?
  • Anonymous Mar 25, 2009
    This is a common problem with those cameras. We have not been able to fix it for a year now. Its on many forums but no fix for it. We updated the cameras from JVC and it does the same thing. As a temporary fix, use capture now and hit escape before the actual pause between takes. For some reason that works or capture in Imovie.
    New Friend:
  • 4 Answers
Try firmware upgrade at JVC service
Posted on Apr 01, 2010
  • 78 Answers
Are you shooting 24p? Make sure you're using the correct capture presets. DV NTSC 48k 24Pa (presuming you're shooting 24p advanced)
if this doesn't help, close final cut and delete your com.apple.finalcutpro.plist file from library>preferences. This should solve additional cadence problems.
Posted on Apr 08, 2008
SOURCE:
JVC GY-HD100 is unable to capture to final cut pro. It shows "no communication" in the log and capture window. But It will capture useing IMovie with no problem. This creates an extra step in my...
You should select the Easy Setup preset that matches the cameras output before capturing.
You may need to start a new project for the Easy Setup to take effect.
Mar 03, 2011 | JVC GY-HD100 Mini DV Digital Camcorder
Technical repair manualwhere can I buy it?
Yes, service manual of JVC GY-HD100 can be downloaded from HERE for small fee.
Thanks.
Apr 15, 2010 | JVC GY-HD100 Mini DV Digital Camcorder
How do I access the jvc gy-hd100 admin menu
Push during 2, 3 seconds the "status" button on the side of the camera.
Aug 14, 2009 | JVC GY-HD100 Mini DV Digital Camcorder
My JVC GY-HD111E isn't located in final cut pro
Are you using HDV, make sure you set the signal to DV on the camera. Does it have a signal out option to switch from video to dv / firewire? Have you checked to see if it is supported? Also just keep trying, turn camera on and off, restart the computer with firewire connected then without. I had this problem with a deck and it randomly started working after my 5th try.
Mar 28, 2009 | JVC GY-HD111E Mini DV Digital Camcorder
View finder is not working.
lcd flexible cable is common problem in this model . try to move up down rotate if you see any picture change the flex cable
Mar 05, 2009 | JVC GY-HD100 Mini DV Digital Camcorder
The fuse on my JVC GY HD100 is dead. Can I replase it with somone other? Why dos it say: "Replace with same type of fuse" on the board? What is a cemical fuse
It is a very small fuse (about the size of a grain of rice) that is directly soldered to your circuit board. It is not a user replaceable part. You'll have to send it back to JVC to replace. In the future, what you need to do is power off when changing the battery.
Dec 26, 2008 | JVC GY-HD100 Mini DV Digital Camcorder
Pixel loss
you have to get to th camera admin menu
Jun 30, 2008 | JVC GY-HD100 Mini DV Digital Camcorder
Jvc hd 100 camcorder
The Video Output Jack Assembly Board is the part you are looking for. Please see below for a link to purchase this item.
GY-HD100 Video Output Jack Assembly Board VJK
Mar 11, 2008 | JVC GY-HD100 Mini DV Digital Camcorder
JVC GY-HD100 Mini DV Digital Camcorder Logo
1,483 people viewed this question
Top JVC Video Cameras Experts
Ekse
Larry Stiles
Larry Stiles
Al Rush
Are you a JVC Video Camera Expert? Answer questions, earn points and help others
