Question about Microsoft Wireless Network Adapter Xbox 360 (SKWIFIX360)
Outlook Express If you click the icoon - it takes over 1 min. till it opens
  • 591 Answers
Suggest you uninstall OE then reinstall it, clearing all cache. No way a properly installed app should take this long if it's problem-free.
Posted on May 30, 2010
How can I open .dbx files saved Outlook Express bits
Please follow these specific steps and this should repair your issue or another paid way must assist you http://www.dbx.openfiletool.com/ DBX Open File Tool
https://social.msdn.microsoft.com/Forums/en-US/ae400b3b-17c2-4e89-b509-261ce01f185f/how-to-repair-damaged-dbx-file-of-outlook-express?forum=messengerconnect
Step 1: Save your existing e-mail
Launch Outlook Express.
Create a new folder under Local Folder:
Right-click Local Folder (in the left bar)
Select New Folder
Type the name of the new folder (e.g. Saved E-Mails)
Click OK
Click Inbox.
Select all your messages and move them into the new folder (e.g. Saved E-Mails).
Quit Outlook Express.
Once this has been done, we need to make sure we can have access to the inbox.dbx file. So now follow these steps.
Step 2: Show hidden files
Right-click the Start button and select Explore to open Windows Explorer or click Start and select My Computer.
Click the Tools menu and select Folder Options.
Click the View tab.
Select Show all hidden files and folders.
Click OK
Next we are going to find the file so we can delete it. Outlook express will later recreate it.
Step 3: Search for ".dbx" files
1. Click Start and select Search.
2. Click All files and folders on the right.
3. Click Advanced options, then click More advanced options.
4. Make sure that Search hidden files and folders is selected.
5.In the box labelled All or part of the document name, type *.dbx.
6.Click Search.
Now once you finsih the search, the file inbox.dbx should come up in your search results. select the file and press delete.
Once you have done this, you can go back into Outlook Express and it should have fixed the issue.
Jul 09, 2015 | Microsoft Outlook Express
Tip
WHY DOES OUTLOOK EXPRESS INSIST ON COMPACTING FOLDERS WHEN WE CLOSE IT ?
OE has a long and troubled history with compacting folders. In the most current version, OE compacts all folders automatically after you open and close the program 100 times. Compacting folders is absolutely essential for maintaining your files in good working order. Therefore,
Do not interrupt the process once it has begun
It is best not to use your computer at all until the process is complete, which can take a few minutes.
Under no circumstances must you ever use Task Manager to kill the msimn.exe process, or put your computer on Standby, or turn off the power, or use a memory-intensive program while compaction is occurring. Any of those can cause destruction of your files and the loss of your messages.
If you don't like waiting for that 100th closing, you can compact all folders manually at any time. For best results always use this procedure.
1: On the File menu, click Work Offline so that no new messages will be arriving
2: In the Folder list, click on Outlook Express so that no e-mail or news folder is open.
3: Close the Folder list by clicking the X in the upper right-hand corner of the list panel. Alternatively you can click Layout on the View menu, and then clear the checkbox for "Folder List”.
4: On the File menu, point to Folder, and then click Compact All Folders. Do not use your computer until the process is complete, which might take several minutes.
5: If an error occurs, close Outlook Express, re-open it, and begin the process again from the top. If the same error occurs again, close Outlook Express, restart your computer (or log off and then log on again), open Outlook Express and then begin the whole process again.
Unfortunately that does not reset the internal counter to zero, so OE will still compact after the 100th closing You can edit the registry manually to reset the counter, or you can use OE TOOL to compact all folders and reset the counter at the same time. To reset it manually
1: Close Outlook Express and all message windows.
2: Click Start, click Run and type without quotes "regedit".
3: Navigate to this key
HKEY_CURRENT_USER\Identities\{GUID}\Software\Microsoft\Outlook Express\5.0
where GUID is the long number used for your Identity
4: In the right-hand pane, double-click "Compact Check Count", then change the value to zero(0).
on Jul 03, 2010 | Computers & Internet
Tip
Duplicate emails in Outlook Express?
When Outlook Express is configured for POP3 mail access it uses a file called pop3uidl.dbx to keep track of which message have been downloaded so that it can download only new messages. Sometimes this file becomes corrupted which results in the same messages getting downloaded again. So we will need a different copy of this file. Please do the following to recreate it:
- In Outlook Express click on Tools and Options.
- Click on maintenance tab.
- Click on Store folder button.
- It will open a small window with a path to the store folder.
- Copy the whole path.
- Click on start and Run.
- Click inside the run box and press Ctrl+V, it will paste the whole path we copied.
- Click on OK. It will open the store location.
- Close Outlook Express.
- In the folder that was opened, locate the pop3uidl.dbx file and right click on it and select rename.
- Rename that to pop3uidlold.dbx.
- Open Outlook Express and you will no longer receive any duplicate messages.
If you are using IMAP account, that can happen if your IMAP account is the default mail account and OE is configured to both open directly to the Inbox (which downloads headers automatically) and check for new messages when starting (which also downloads headers automatically). To stop the duplicates, simply choose one option or the other, but not both:
In Outlook Express click Tools > Options, then
1. Remove the check mark for When starting, go directly to my ‘Inbox’ folder
OR
2. Remove the check mark for Send and receive messages at startup.
If you already have duplicates showing, click Tools > Synchronize Account or Synchronize All.
on Nov 18, 2008 | Microsoft Outlook Express
Recover Outlook Express e-mails which are not displayed anymore in INBOX
Try this first:
How to restore Outlook Express items
Note To restore items when you use multiple identities in Outlook Express, you may have to re-create the identities before you follow these steps. Repeat each step as needed for each identity. Step 1: Import messages from the backup folder
  1. On the File menu, point to Import, and then click Messages.
  2. In the Select an e-mail program to import from box, click Microsoft Outlook Express 5 or Microsoft Outlook Express 6, and then click Next.
  3. Click Import mail from an OE5 store directory or Import mail from an OE6 store directory, and then click OK.
  4. Click Browse, and then click the Mail Backup folder.
  5. Click OK, and then click Next.
  6. Click All folders, click Next, and then click Finish.
Step 2: Import the Address Book file
  1. On the File menu, click Import, and then click Other Address Book.
  2. Click Text File (Comma Separated Values), and then click Import.
  3. Click Browse.
  4. Select the Mail Backup folder, click the address book backup.csv file, and then click Open.
  5. Click Next, and then click Finish.
  6. Click OK, and then click Close.
Step 3: Import the mail account file
  1. On the Tools menu, click Accounts.
  2. On the Mail tab, click Import.
  3. In the Look In box, select the Mail Backup folder.
  4. Click the mail account that you want to import, and then click Open.
  5. Repeat these steps for each mail account that you want to import.
  6. Click Close.
Step 4: Import the newsgroup account file
  2. On the News tab, click Import.
  4. Click the news account that you want to import, and then click Open.
  5. Repeat these steps for each news account that you want to import.
  6. Click Close.
How to preserve the Blocked Senders list and other e-mail rules
For more information about how to preserve the blocked senders list and other e-mail rules, click the following article number to view the article in the Microsoft Knowledge Base: 276511 How to back up and restore Outlook Express Blocked Senders list and other mail rules.
If not try this:OE-Mail Recovery (download) is a tool for repairing Outlook Express folders if they are damaged or corrupted. OE-Mail Recovery (Outlook Express mail recovery tool) extracts and saves e-mails from .dbx files in which Microsoft Outlook Express stores messages and folders on the local drive. The DBX Recovery tool will help you avoid troubles with Outlook Express folders, fix the problems with Outlook Express folders that you can't open or recover .dbx of Outlook Express.
Mar 01, 2015 | Microsoft Outlook Express
Need to change e-mail server in my pop up for outlook express on my presario SR1403WM
Who is your email service provider? it's easy to change the email server settings.
Outlook Express 5/6
1. Open Outlook Express
2. Click on "Tools"
3. Click on "Accounts"
4. Click on "Mail" Tab
5. Click your existing Email account and click on "Properties"
6. On the pop-up window click on "Servers" tab
7. You can change the pop server that you have there
8. Press ok, then close then close and open Outlook express
Jan 07, 2010 | Compaq Presario sr1403wm AMD Sempron 3000+...
I am trying to export my messages from Outlook
I dunno but you might be better off just copying the outlook express data files from one computer to the next instead of trying to export.
http://support.microsoft.com/kb/270670
from the horses mouth.
Oct 27, 2009 | Microsoft Windows XP Home Edition
How to disable Outlook Express 6 Compact message prompt
Unfortunately, there is no easy way to disable this. The best you can do is delay the messages, or avoid them altogether. I have listed both methods below, and would suggest number 1 over number 2:
Method #1 - In Outlook Express, click on Tools>>Options>>Maintenance. Click on the Cleanup Now button, and then Compact. Doing this regularly will keep you from getting the messages.
Method #2 -
  • Open the registry (click on Start, Run, type Regedit and click Enter).
  • Browse to HKEY_CURRENT_USERIdentitiesyour identitySoftwareMicrosoftOutlook Express.0.
  • Look for the registry value titled Compact Check Count. This typically has a value of between 1 and 5, which means Outlook Express will check every 1 to 5 times to see whether you need to compact. Double click on the item, and set the number to 100, so you will only see the message every 100 times you open Outlook Express.
- I offer remote control assistance as well! Please send me a note at Info@LoganComputersER.com
Oct 19, 2009 | Microsoft Outlook Express
In Outlook Express when I send a email it takes forever then when it does finally gets sent I close OE and there is the screen that says email sent and completed. I have to go to tasks to close it. Usually...
Hi All
if you are running XP then open up explorer and go to
C:\Documents and Settings\*your user name*\Local Settings\Application Data\Identities\{65C0EAFC-BB65-4A91-A733-2B5FA75AFB49}\Microsoft\Outlook Express
then delete outbox.dbx (Make sure outlook express is closed)
then start Outlook Express and try to send an e-mail again.
Apr 18, 2009 | Microsoft Outlook Express
Can't Open Attachments In Outlook Express
If you cannot open attachments while using the Outlook Express e-mail client, your security settings may be too high. When you try to open attachments, you may see the following message: “OE removed access to the following unsafe attachments in your mail.”
To check your e-mail security settings:
1. Open Outlook Express.
2. Click on Tools in the menu, and scroll down to Options.
3. Click on the Security tab.
4. Make sure “Do not allow attachments to be saved or opened that could potentially be a virus” is UNCHECKED.
5. Click on the Apply button. Click on OK.
You should now be able to open attachments.
Sep 30, 2008 | Computers & Internet
Open Questions:
See all Microsoft Wireless Network Adapter Xbox 360 Questions
Microsoft Wireless Network Adapter Xbox 360 (SKWIFIX360) Logo
26 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
