Question about Marantz SA-7S1 SACD Player
Is SACD output supported via the digital outputs of the SA-7S1, and is is DSD, PCM, or either?
  • 10,594 Answers
Signal format of SACD is DSD (Direct Stream Digital) and SA-7S1 support that audio format including all other audio formats as it can playback all format cds, player has analog, coax and digital optical output ports to hook it with any amplifier.
Hope this info helps.
Thanks.
Posted on May 30, 2010
Is there a docking device for connecting iphone with panasonic receiver
There are lots of docks, but they all connect via USB
https://www.google.ca/search?q=iphone+6+plus+dock+connector&rls=com.microsoft:en-CA:IE-ContextMenu&biw=1366&bih=643&source=lnms&tbm=isch&sa=X&ved=0ahUKEwjMh9Hpg97QAhVPVWMKHVosD3kQ_AUIBigB#tbm=isch&q=iphone+6+plus+dock
Your receiver only has s-video.
Total Harmonic Distortion 0.7% (6ohms) (at 20Hz-20kHz)
  • S-Video Inputs/Outputs 5 inputs, 1 output
  • Video Inputs/Outputs 5 inputs, 1 output
  • Video Rec Outputs 1 output (with S-Video)
  • Front Audio Inputs 1 input (S-Video)
  • Digital Inputs/Outputs 4 in (3 optical, 1 coaxial)
  • Audio Inputs/Outputs 6 in, 1 out
  • VIERA Link™ HDAVI Control 3
  • HDMI Input/Output 3 in, 1 out
  • Dimensions (H x W x D) 6 1/4'' x 16 15/16'' x 13 11/32''
  • Weight 11 lbs
    Panasonic SA BX500 AV Control Receiver with High Quality Amplifier Decoder...
  • Dec 05, 2016 | Panasonic Audio Players & Recorders
    I would like to connect my computer to my panasonic sa-ht800v unit and hear the sound thru the surround sound speakers
    In general, your PC's sound card (and its controlling software) will determine what it can connect to.
    Even the most basic PC would have stereo analog output via the typical green 1/8" connector or a headphone jack that easily adapts to RCA pair for analog audio connection. Any Line Level input EXCEPT PHONO would accept the PC's output. The output level would be controlled by the sound card software and settings.
    The SA-HT800's single LINE Input would accept the Green stereo audio or speaker output from a standard PC, once adapted. Select VCR.
    Find your PC's Sound Controls and enable the applicable input. make sure the volumes of both Inputs and Outputs are turned up.
    Though not applicable to theGemini, more-advanced sound cards and audio hardware would have similar adaptable 5.1 or 7.1 (paired) analog outputs and / or digital audio outputs that conform to the s/pdif or Dolby Digital standards.
    Mar 26, 2011 | Panasonic sa-ht800V Home Theater Audio...
    It no longer reads all cds sacds it use to, thought cds were bad,bought second cds and still will not play help love the sounds
    When you say it doesn't read SACD's do you mean it doesn't put out 5.1? Keep in mind that you have select the SACD multichannel area and use the 5.1 analog outputs for that and NO digital output will be produced.
    The manual...
    http://www.retrevo.com/support/Marantz-SA8260-manual/id/511bh850/t/2/
    Dec 28, 2010 | Marantz SA8260 CD Player
    I have a Sharp Aquos with a optical output, i conected it to the tv optical input of the panasonic sc ptx7 but it doesnt have audio via optical,on the contrary via rca works perfectly.
    hi,
    check the following on ur tv
    1. Press MENU to display the MENU screen,
    and then press c/d to select "Digital
    Setup".
    2. Press a/b to select "Audio Setup", and then
    press ENTER.
    3. Press a/b to select "PCM" or "Dolby
    Digital", and then press ENTER.
    4. Press MENU to exit.
    PCM The optical output terminal output studio signal in PCM form. If your digital audio system does not support Dolby Digital, select "PCM".
    Dolby Digital
    The optical output terminal outputs audio signal in Dolby Digital form. it reproduces sound from surround program of digital.
    also check the input assignment of ur dvd palyer's tv input. if it is selected as analog then change it to digital.
    ok
    Dec 20, 2010 | Panasonic SC-PTX7 Home Theater System With...
    What is the best way to attach a Sony SCD CE595 CD player SACD to a Denon AVR 2105 Receiver. I thought the optical input would be best but according to a web posting, toslink does not support SACD
    That is correct. Digital connections through some models of SACD players are via "firewire", otherwise it is analog output. There are no optical connections.
    The shortest pair of RCA cables, or even component video cable as an alternative will work.
    Dec 12, 2009 | Denon AVR-2105 Receiver
    My PS3 will not play sound on my Sony Bravia HDX275 surround sound system. I have the HDMI cable plugged from the PS3 to the TV. I have another HDMI cable from the receiver to the TV as well as a opitcal...
    Adjust the system's audio output settings. These settings are mainly used when the system is connected to audio devices that support digital audio output, such as AV amplifiers (receivers) for home entertainment systems.
    1.
    Confirm the formats supported by your audio device.
    Settings vary depending on supported formats. For details, refer to the instructions supplied with the audio device.
    2.
    Select in_soundset.gif (Sound Settings) under in_setting.gif (Settings) in the home menu.
    3.
    Select [Audio Output Settings].
    4.
    Select the input connector on the audio device. Channel numbers and audio formats that are supported vary depending on the connector in use.
    soundoutput001.jpg Input connectors on the TV or AV amplifier (receiver) PS3™ system output connectors Channels that can be used for output 2 Ch. 5.1 Ch. 7.1 Ch. HDMI HDMI OUT connector in_maru.gif in_maru.gif in_maru.gif Digital Out (Optical) Digital Out (Optical) connector in_maru.gif in_maru.gif - Audio Input Connector / SCART / AV MULTI AV MULTI OUT connector in_maru.gif - - 5.
    Select audio output formats.
    Select all output formats that are supported by the audio device in use. If [Audio Input Connector / SCART / AV MULTI] is selected in step 4, the screen for selecting audio output formats will not be displayed. If [HDMI] is selected, you can also select to automatically set the audio output format. (In this case, the HDMI device must be turned on.)
    soundoutput003.jpg 6.
    Check your settings.
    You can go back to the previous screen and revise the settings by pressing the in_left_key.gif button.
    soundoutput002.jpg 7.
    Save your settings.
    The audio output settings are saved on the system.
    Hints
    • [Linear PCM 2 Ch.] audio is set to be output from all output connectors by default. If you change the audio output settings, audio will be output only from the connectors that were set.
    • If you change the audio output settings, the system will no longer be able to output audio from multiple output connectors at the same time. For example, if your system is connected to a TV via an HDMI cable and to an audio device via a digital optical cable and you switch to [Digital Out (Optical)] under [Audio Output Settings], audio will no longer be output from the TV. To output audio from the TV, switch the setting to [HDMI], or select in_setting.gif (Settings) > in_soundset.gif (Sound Settings) > [Audio Multi-Output] and set the option to [On].
    • If you select [Linear PCM 2 Ch. 88.2 kHz] or [Linear PCM 2 Ch. 176.4 kHz] in step 5, sound may be intermittent or may not be emitted from some audio devices.
    • When using an HDMI cable, only [Linear PCM 2 Ch.] audio will be output from PlayStation®2 and PlayStation® format software. To output Dolby Digital or DTS audio, you must connect the PS3™ system and the audio device using a digital optical cable and switch to [Digital Out (Optical)] under [Audio Output Settings].
    • If a device that is not compatible with the HDCP (High-bandwidth Digital Content Protection) standard is connected to the system using an HDMI cable, video and/or audio cannot be output from the system.
    (Information taken from here)
    Hope it helped.
    Nov 18, 2009 | Sony Playstation 3 (PS3) Console
    My marantz DV 9500 doesnt output digital signal for audio cd anymore but outputs audio for dvd,sacd,dvd audio. Does it need servicing
    Make sure your playing componet like CD player have a digital output socket. Connect this to a digital port on the amp witk a single RCA or Optical cable if output available on CD. Make sure the digital assingment in amp is set for cd function and corresponding input(example cd plyer connected on dig 4 input on amp, press menu, setup, assignment, go to cd player, make sure setting on dig 4 or change input to dig 4, go to next component to memorise setting.and exit, see manual to assist you) if still no sound take dvd cable for instance that is working and put that in dig 4 port. if that works check in cd player that settings spdif/raw/pcm is correct one for yor digital output if still no sound soun pc board faulty.
    Aug 11, 2009 | Marantz DV-9500 DVD Player
    Marantz SA-1 installation question
    Does your Marantz have an "optical" or "digital" out?
    If so, use them. Assuming you have a quality receiver/pre-amp/amplifier it will have it's own D/A converters.
    If you plug into the receiver's CD inputs you will be using the D/A converters in the Marantz.
    If you plug into the DVR/SACD inputs - it depends on the receiver et al.
    Try both. See if one sounds better. Select the one that sounds best. For a top-notch system you need high quality from cables to receiver, and speakers. You system can only be as good as your weakest link, so what sounds good/great to your ears, that is the best!
    Cheers
    Mar 27, 2009 | Marantz SA-1 CD Player
    I like the look and price of the Marantz SR 6003 receiver, my only question being whether it suppports DSD data output from a SACD player like the ONKYO like the OPPO DV-980h. In other words can it receive...
    Downloaded the user manual for the Marantz SR 6003 A/V Receiver. In this it stated that if a SACD player was connected to the SR 6003 with an HDMI interface earlier than 1.2 then the digital data from the SACD could not be transferred over the HDMI cable to the SR 6003. This implies, but does not confirm, that if a SACD player does provide a digital output on an HDMI 1.3 interface, then SACD audio data can be transmitted to the SR 6003 and, presumably, decoded and converted to 6 analogue streams which are then amplified and deleivered to the (6) analogue output terminals.
    I'm fairly sure that the native DSD data from the SACD has to be converted to PCM before transmission over the HDMI interface which is better than nothing. What I was hoping for though was for the data to be transferred in DSD and converted in the SR 6003 directly to analogue, avoiding two intermediate conversions. This ideal solution can be done by only a few SACD/ A/V Receiver combinations, which is silly considering that it is also the simplest. One example, which has made a big impression amongst high fi enthusiasts, is the OPPO DV-980H Universal DVD player (plays any audio or video disc and costs almost nothing) and the Integra DTC 9.8 home theatre processor.
    Jan 14, 2009 | Televison & Video
    Marantz SA-7S1 SACD Player Logo
    32 people viewed this question
    Top Marantz Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Electro Med Services...
    Are you a Marantz Audio Player and Recorder Expert? Answer questions, earn points and help others
