Question about Ruud UAKA037 Air Conditioner
Fan wont come on unless I hit the top of the unit
  • 674 Answers
Check the wires for the fan where they connect to the contactor and capacitor to make sure they are tight. Also make sure the compressor is running. If it's not running too then there could be a problem with the contactor. Check the capacitor too.
Posted on May 30, 2010
My heater won't start unless I hit it on top
Check the thermostat. Make sure to unplug and clean unit before inspection.
Dust can cause a problem and create a similar problem.
Nov 30, 2014 | Heating & Cooling
Goodman ckl36-1e
You do not need a new unit ,it can be fixed, good luck finding an honest tech
Jul 01, 2013 | Heating & Cooling
Loud Squeaking from unit outside
The fan motor or fan shaft in the outside unit may need lubricating. Also check to see if some foreign object has gotten thru the grate cover on the top and the fan blades are hitting it.
Feb 24, 2011 | Heating & Cooling
COOLING FAN WONT COME ON UNLESS AC IS ON. ALREADY CHECKED FUSES
the temperature sending unit is not telling the fans to come on will need to get replaced or make sure wire is connected and grounded...the ac part lets you know the fans are working and not the problem need to find switch that turns fans on temp sending unit or another parts store can tell you if thay are good .....
Oct 03, 2010 | 1998 Ford Escort
I have a goodman cpk j42 -1b ac unit on the outside and a central heat and air unit inside. the ac unit come on and runs fine but when it hit the temp the thermastat clicks and the fan outside goes of but...
Hello BWOOD Check the thermostat FAN button is in AUTO position not ON position.That might be it .The relay is in the blower unit but they RARELY become frozen/welded stuck on.
Aug 30, 2010 | Heating & Cooling
The compressor doesn't start up unless I hit the high pressure reset button.
If the compressor is shutting off due to high pressure, the condenser coils may be dirty or blocked. Remove the top grill (may include fan and motor) and clean the coil fins from the inside out with a garden hose. Also cut any grass or shrubbery from around the unit. Remove any obstruction you see that may block air flow. Good air flow is crucial to keeping the high pressure down, especially in hot weather. I hope this helps!
Sep 08, 2009 | Ruud Heating & Cooling
Buzzing sound
If noise stops when you open the door, you may have a noisy fan (or could have ice build up, causing fan blade to hit ice and cause noise). I gather it is a frost-free model ie has a fan in the freezer compartment. If noise is caused by fan hitting ice build up, you may have a problem with the auto defrost system, as you should not get ice build up in a frost free.
Noise stops when you open door because fan turns off when door is opened.
Aug 09, 2009 | LG Refrigerators
My AC unit fan won't kick on. I hit the ''cool'' switch setting and the unit sounds like it is trying to run, then stops.
Possible bad capacitor. You may need a service tech unless you have knowledge of AC wireing. Russ
Jul 23, 2009 | Heating & Cooling
KENMORE 55689
It seems as if your refrigerators fan may be hitting the ice that might have accumulated nearby or it has gone kaput n you'll be needing a replacement...these frost free fridges have a lot of fan problems...not to worry just replace it.
Jun 04, 2009 | Kenmore 55682 / 55684 / 55689 Side by Side...
Ruud 12 seer heat pump not heating
It sounds like the unit is tripping off from high pressure. Check you filter and indoor coil. You may have low air flow inside that is causing the refrigerant pressure to be to high.
Mar 22, 2009 | Ruud Central System Air Conditioner
Ruud UAKA037 Air Conditioner Logo
Top Ruud Heating & Cooling Experts
Donni Steen
Bill Long
Tim Whalen
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
