Question about Canon Normal EF 50mm f/1.4 USM Autofocus Lens
How do i fix a broken auto focus? - Canon Normal EF 50mm f/1.4 USM Autofocus Lens
    President:
  • 405 Answers
Found something that should help you. Copy the link below.
http://users.abo.fi/jskata/300Drepair/
Posted on May 31, 2010
Who can fix my
Your problem may be a broken zoom ribbon. If the lens works OK in manual focus this could be it. You'll need a professional repair which is not expensive.
Jan 25, 2015 | Sigma 17-35mm f/2.8-4.0 EX Aspherical HSM...
Will not auto focus
If it manually focuses and not auto focus you may have a broken ribbon cable in the lens. If that is so you'll need to take it to be repaired / cable to be replaced
Jan 30, 2014 | Nikon Nikkor 55-200mm f/4.5-5.6 G AF-S...
Auto focus does not work on canon eos 300d camera
It may be that the ribbon connector has broken in the lens.
Nov 26, 2013 | Canon EF-S 18-55mm f/3.5-5.6 USN Lens
I am using smasung ES73 digital camera, and i dont know why everytime i took pictures most of it are blurred.. i wonder how to fix this problem..thankyou
Make sure you hold down the shutter button half-way before taking the shot and let the camera auto-focus. Also make sure the lens is clean, as grime and fingerprints can mess up the auto-focus. If that doesn't work, the motor drive in the lens is probably broken and needs to be sent in for repair.
Mar 15, 2011 | Cameras
Just purchased a Kodak Ektagraphic AF1 & neither manual/auto focus or slide advance work. My other Kodak Ektagraphic AF had both auto & manual advance broken as well. Used it for many years. Was...
The model AF-1 did not have remote focus feature. It does have the Auto-Focus feature. The auto-focus adjustment is a pretty "fine-tune" adjustment that requires a factory alignment tool & a trained hand.
Your model AF is quite old, and probably requires replacement of the "link" that connects the slide change solenoid to the slide change mechanism. The problem is the plastic the "link" was made of gets brittle over the years and cracks, rendering slide change non-functional.
Both problems are easily remedied by a qualified repair dealer with the tools, training and parts.
Oct 19, 2010 | Kodak Office Equipment & Supplies
My auto focus will not work.
lens af unit gear is broken, or lens af saft if broken, or lens af flex is broken.
or could be camera sub mirror spring is come out from mirror unit.
take it to canon repaire centre to estimate
Jul 05, 2010 | Canon EOS Rebel XSi Digital Camera
Lense only focuses manually
its not junk, prob too expensive to fix. but makes a nice fixed focus lens. Quantray were on the same level as vivitar, sigma. So they are now that expensive to replace
Jan 18, 2010 | Quantaray AF 70-300mm f/4.0-5.6 High Speed...
Broken power outlet 2006 ford focus (recently bought used)
begin by changing the fuse. look in your manual for the location of the fuse and be sure to replace it with a new one exactly like the old one, available at any auto parts store.
Aug 17, 2009 | 2006 Ford Focus
Nikkor Lens Cannot Manual Focus
It sounds like you had the lens set for manual focus when you took the A / M switch plate off. If this was the case then when you but it back together the little arm behind the plate is on the wrong side of a moving gear assembly.
To fix, remove the auto/manual focus switch plate from the camera (just the one screw not the ribbon beneath) Push the switch over to A. Hook the bottom of the plate back to the lens and put the screw back in. Done!
Jul 26, 2009 | Nikon Nikkor 18-55mm f/3.5-5.6G ED AF-S DX...
Canon Rebel Xti Wont autofocus
You have your own answer - the lens is damaged, probably beyond economic repair.
Jul 29, 2017 | Canon Rebel XT / EOS 350D Digital Camera
Canon Normal EF 50mm f/1.4 USM Autofocus Lens Logo
1,201 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
