Question about Jenn-Air Dishwashers
Jenn Aire Dishwasher Model JDB-5 Does not clean
Jenn Aire Dishwasher Model JDB-5 Does not clean dishes consistently, leaves spots and debris on glassware as well as flatware.
  • 145 Answers
SOURCE: Jenn-Air (Maytag) Dishwasher Leaves Film on Everything
Make sure you are using rinse aid like jet dry. All newwer dishwasher are made to only work properly with this in it.
Posted on Apr 23, 2008
  • 677 Answers
SOURCE: GE Profile Dishwasher (5 years old); Leaving residue on dishes
There is a new product out that actually filters the water going into your dishwasher. My dishes came out amazing after the first load. No more cloudy glasses. I was very impressed. Who knows whats in the water cleaning your dishes so i thought this filter was great. It is very affordable and you can get it at www.dishwasherfilter.com. Hope this helps some people.
Posted on Jan 06, 2009
SOURCE: Bosch dishwasher
Although I previously posted with the same problem of a film on the dishes after cleaning, I did find a section in the owner's manual which solved my problem. Lift up the rinse aid cap on the inside door - the factory setting is on "4". The rinse aid works in conjunction with your local water, which has variations in it's hardness or softness. When your dishes are streaky, lower the rinse aid setting to 1 or 2. If your dishes are spotted, raise the rinse aid setting higher.
Posted on Feb 20, 2009
  • 127 Answers
SOURCE: dishwasher leave debris on dishes
there is no filter except the screen in the water inlet valve to keep big pieces of grit in the water from defecting the inlet valve..
i dont know exactly why but it sounds like your unit was not installed with a recommended air gap in the drain or something similar and somehow dirty sink/drain/sewer water is making its way back into the unit and onto your dishes.
often times there is a little rubber check valve/flapper in the drain line either installed in the pump or the drain hose just after the pump to keep foreign material from entering the unit..
other than that it would just be mineral and calcium deposits if you are on well water or chunky city water..
hope this helps,
best of luck,
ttfn
Posted on Oct 27, 2009
  • 677 Answers
SOURCE: Leaving spots on dishes, glasses
the problem is hard water. go to www.dishwasherfilter.com. they have a new product that works great. very affordable and finally solves this embarassing problem.
Posted on Jan 22, 2010
Our Jenn-Aire #JDB1100AWS leaves gritty residue in/on the upper rack dishes. I have had success solving this problem in the past, with different units, by pulling and cleaning out the filter usually...
Hi, I have an older dishwasher also and recently mywife also complained about it not cleaning right... so me being the man I amtried in vain to clean the things... Bought new spray arms online and installedthem in minutes...now the thing works like new... However I have also foundthat if the heating element goes bad then that also can mess things up bad...So I would buy new spray arms, and also check out the heating element to makesure it is working... Here is a tip that will help you with the onlinebuying...
Dishwasher SprayArms not Spinning
How to Buy ApplianceParts Online
A bad heating element causes many problems in dishwashers...
Dishwasher Problems The HeatingElement not Working
DishwasherMaintenance DishwasherResidue and Film on Dishes
heatman101
Asker's Testimonial "explanation very clear. will give it a go and see howsimple it was. thanks Ronnie " - ronnieshomes
Jun 14, 2011 | Jenn-Air 24 in. JDB1100AWS Built-in...
Dishwasher displaying L# what do I do??
press start and light will not come on and start
jenn-air dishwasher jdb-5
Nov 14, 2010 | Jenn-Air JDB1095AW Built-in Dishwasher
How do I remove the screen to clean out debris below it ?
The problem is hard water. www.dishwasherfilter.com has a product to solve this problem once and for all. It filters the water going into your dishwasher and removes the hard minerals that leave those spots. It is very affordable and even has a money back guarantee. You will love the way your dishes look with this product.
Apr 05, 2010 | Kenmore (15132) Built-in Dishwasher
Does not get my dishes clean, leaving a film on my glasses, not getting food off. tried to take apart to clean but could not figure out how to get bottom filter out with the large water bracket going up...
Oct 09, 2009 | Jenn-Air 24 in. JDB1100AW Built-in...
Dishes have a powdery residue
If there is not enough water, the dishes would not get cleaned. This could be caused by a partially closed water shut-off valve (located under the sink), or a faulty dishwasher water valve (located at the bottom of the dishwasher, behind the kick panel, on either side).
Also, There is usually two, sometimes three spray arms in a dishwasher. Make sure there is no debris blocking the holes inside each spray arm.
**Water temperature Note***
To get the best results, the water has to be at 120 degrees Fahrenheit when entering the dishwasher.
NOTE(((excessive calcium build up inside the dishwasher can cause this as well. I recommend cleaning the inside of the unit with a dishwasher cleaner called Dishwasher Magic. its good stuff and it will get rid of that calcium build up)))
Jul 30, 2009 | Jenn-Air JDB1105AWS Stainless Steel...
It is not cleaning dishes, it leaves food residue on dishes and deposits small bits to other dishes especially on glasses.
Jul 15, 2009 | Jenn-Air 24 in. JDB1080AWS Built-in...
Leaving gray white streaks and spots on dishes
Check the following to address this issue--
1. Not enough water
2. Clogged spay arms
3. Water temperature is too low
4. Not enough soap
If you only fill one part of the soap cup, try adding soap to both parts.
Jun 01, 2009 | GE 25 in. Nautilus GSC3400J Free-standing...
Jenn-air JDB-2100aws dishwasher not drying properly
1. If you do not use Jet-dry liquid in detergent dispenser left side compartment, the drying result for dishes will be very poor.
2. You should check the heating element for continuity(conections for heating element under bottom panel of d/w).
Dec 15, 2008 | Jenn-Air Dishwashers
My dishes comes out still dirty
I put a bottle of CLR in the dishwasher and I did a wash without any dishes. Repeat if needed.
Aug 18, 2008 | Maytag 24 in. MDB5651A Built-in Dishwasher
Dishwashers Logo
127 people viewed this question
Top Jenn-Air Dishwashers Experts
John Tripp
John Tripp
Mike
Are you a Jenn-Air Dishwasher Expert? Answer questions, earn points and help others
