Question about Onkyo TX-SR605 Receiver
Receiver keeps shutting off
When I turn the receiver on it gets to the point where the sound starts to come through and then it just shuts off. I've tried tightening the cables/wires, unplugging it, moving it to a different position in the cabinet but nothing seems to work. The first time it did it, I thought it had overheated because it was in a very tight space....I removed the shelf above it so that doesn't seem to be the issue. Also, sometimes it will work but if someone walks heavily past the cabinet it will shut down most times which leaves me to believe it's some type of short..........
  • 4,234 Answers
There could be poor solder connections inside that could cause this. If you have any soldering experience, look at the solder connections close to the voltage regulators. These will be small 3-legged transistors marked 7805 or 7812 and most likely attached to small heat sinks. Resolder tehse connections and any others that appear grainy or have rings. Let us know how you make out.
Dan
Posted on Apr 08, 2008
SOURCE:
Before my Onkyo receiver ht-r591 keeps clicking on/off rightnow is dead , won't power on at all ...Please Help!!!
Hi Markes,
It could be that there is a frayed speaker wire touching the back of the receiver and when playing at a low level the speakers do not require that much power, however when the level from the speakers increases more power is required and if there is a frayed speaker wire touching the back of the receiver there could be a short causing the receiver to shut down. A way to avoid the frayed wire is to use "Banana Connectors" that the speaker wires goes to and the connector will plug into the speaker posts. Please try the following to see where the issue is coming from. Have the receiver turned off, make sure all the speaker wires are labeled, and disconnect them from the speaker terminals. Turn the receiver on select a source that would give you sound if the speakers where still connected and turn the volume all the way up. If the receiver shuts down than it would need to go to a service center as it is an internal problem with it. If the receiver does not shut down, turn the volume down, shut the receiver off and connect one speaker and than turn the receiver on selecting the same source as before and raising the volume up. If the receiver shuts down, remove that speaker from the post and connect it to another speaker post to determine if it is the receiver or the speaker itself that is giving you the problem. If the receiver should shut down after moving that speaker you know it is a problem with the speaker or the wiring. If the receiver does not shut down, turn the volume down, shut the receiver off and connect another speaker followed by doing the previous test procedure. Keep adding speakers until you have them all reconnected to the receiver as long as it has not shut off while trying the test procedure. After determining whether it is the speakers or the receiver you would need to bring either to a service center to be repaired. To locate an authorized independent service center, check the dealer and service locator at our website: www.onkyousa.com or www.integrahometheater.com.
Oct 29, 2015 | Onkyo Audio Players & Recorders
Onkyo ht r591 keep clicking on/off
Hi Markes,
It could be that there is a frayed speaker wire touching the back of the receiver and when playing at a low level the speakers do not require that much power, however when the level from the speakers increases more power is required and if there is a frayed speaker wire touching the back of the receiver there could be a short causing the receiver to shut down. A way to avoid the frayed wire is to use "Banana Connectors" that the speaker wires goes to and the connector will plug into the speaker posts. Please try the following to see where the issue is coming from. Have the receiver turned off, make sure all the speaker wires are labeled, and disconnect them from the speaker terminals. Turn the receiver on select a source that would give you sound if the speakers where still connected and turn the volume all the way up. If the receiver shuts down than it would need to go to a service center as it is an internal problem with it. If the receiver does not shut down, turn the volume down, shut the receiver off and connect one speaker and than turn the receiver on selecting the same source as before and raising the volume up. If the receiver shuts down, remove that speaker from the post and connect it to another speaker post to determine if it is the receiver or the speaker itself that is giving you the problem. If the receiver should shut down after moving that speaker you know it is a problem with the speaker or the wiring. If the receiver does not shut down, turn the volume down, shut the receiver off and connect another speaker followed by doing the previous test procedure. Keep adding speakers until you have them all reconnected to the receiver as long as it has not shut off while trying the test procedure. After determining whether it is the speakers or the receiver you would need to bring either to a service center to be repaired. To locate an authorized independent service center, check the dealer and service locator at our website: www.onkyousa.com or www.integrahometheater.com, Thanks, JT
Oct 11, 2015 | Onkyo Audio Players & Recorders
My Receiver very rarely comes on but shuts off in few minutes even the standby doesn't lit up. but when on works perfectly.
Hi Joseph,
Jun 28, 2015 | Onkyo TX-DS989 Receiver
How to repair a onkyo A-812XG if a volume is higher the unit is shutdown
Hi Ryan, It could be that there is a frayed speaker wire touching the back of the receiver and when playing at a low level the speakers do not require that much power, however when the level from the speakers increases more power is required and if there is a frayed speaker wire touching the back of the receiver there could be a short causing the receiver to shut down. A way to avoid the frayed wire is to use "Banana Connectors" that the speaker wires goes to and the connector will plug into the speaker posts. Please try the following to see where the issue is coming from. Have the receiver turned off, make sure all the speaker wires are labeled, and disconnect them from the speaker terminals. Turn the receiver on select a source that would give you sound if the speakers where still connected and turn the volume all the way up. If the receiver shuts down than it would need to go to a service center as it is an internal problem with it. If the receiver does not shut down, turn the volume down, shut the receiver off and connect one speaker and than turn the receiver on selecting the same source as before and raising the volume up. If the receiver shuts down, remove that speaker from the post and connect it to another speaker post to determine if it is the receiver or the speaker itself that is giving you the problem. If the receiver should shut down after moving that speaker you know it is a problem with the speaker or the wiring. If the receiver does not shut down, turn the volume down, shut the receiver off and connect another speaker followed by doing the previous test procedure. Keep adding speakers until you have them all reconnected to the receiver as long as it has not shut off while trying the test procedure. After determining whether it is the speakers or the receiver you would need to bring either to a service center to be repaired. To locate an authorized independent service center, check the dealer and service locator at our website: www.onkyousa.com, Thanks, JT
Apr 26, 2015 | Onkyo Audio Players & Recorders
The protect mode is active what are the causes
Turn the receiver on select a source that would give you sound if the speakers where still connected and turn the volume all the way up. If the receiver shuts down than it would need to go to a service center as it is an internal problem with it. If the receiver does not shut down, turn the volume down, shut the receiver off and connect one speaker and than turn the receiver on selecting the same source as before and raising the volume up. If the receiver shuts down, remove that speaker from the post and connect it to another speaker post to determine if it is the receiver or the speaker itself that is giving you the problem. If the receiver should shut down after moving that speaker you know it is a problem with the speaker or the wiring. If the receiver does not shut down, turn the volume down, shut the receiver off and connect another speaker followed by doing the previous test procedure. Keep adding speakers until you have them all reconnected to the receiver as long as it has not shut off while trying the test procedure. After determining whether it is the speakers or the receiver you would need to bring either to a service center to be repaired. To locate an authorized independent service center, check the dealer and service locator at our website: http://www.onkyousa.com/Support/servicecenterLocator.php?source=globalnav
Apr 12, 2015 | Onkyo TX-DS787 Receiver
The protect mode is active - what are the fixes
When i turn my car on the my avic-f90bt pioneer goes on but after about 20 seconds shuts right off again and continues doing the same thing over and over again
Check your wiring. Sounds like you've got a bad ground, or missed a 12v source somewhere. Remember - There is a 12v constant that keeps your radio constantly tied in (so your clock stays correct, etc) and a 12v Ignition/ACC which tells your radio when you've turned the car ON or in ACC mode (which turns the radio on).
If you've mixed the two up, you'd probably get the results you're getting.
May 11, 2011 | Pioneer AVIC-F90BT GPS Receiver
Receiver keeps shutting off after 3 seconds. what
Be sure the face is secure, and there is no dirt in the connection on the face, and head unit.
Sha'ul
Jun 27, 2009 | Harman Kardon AVR 120 Receiver
Denon receiver shutdown
Try turning down your tone controls. Like your bass, treble, or your equalizer. If you hear too much tinny or hissing sounds, the treble has to be turned down, or turn down the upper bands controls on your equalizer to the optimun level. If you hear too much bassy sounds, your bass control has to be turned down, or the lower band controls has to be turned down to the optimun level. If you are planning on turning the volume up, you may have to turn down some of the tone controls to the optimun levels, otherwise, your receiver may shutdown, or you may blow fuses in your speakers. Also make sure you speaker wire polarity is hooked up right. Red wire on the + red terminals, and the black wire on the - black terminals. Also don't have the volume turned up too high to the point where your receiver would have clipping or distortion, or else your receiver may shutdown, or you may blow fuses in your speakers.
If this don't help, then there may be something wrong with your receiver or your speaker.
Apr 05, 2008 | Sherwood RX-4105 Receiver
Onkyo TX-SR605 Receiver Logo
160 people viewed this question
Top Onkyo Audio Players & Recorders Experts
Ted28
Level 1 Expert
 Grubhead
Grubhead
Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
