Question about Black & Decker Spacemaker 10-Cup Coffee Maker
I put the coffee on to brew and it stops after a few cups
I put the coffee on to brew and it will brew little then stop and brew a little then stop. Now I've cleaned the coffee pot over and over and it does not help? ?
    New Friend:
  • 47 Answers
If the display works and the platter heats up when it is turned on to brew, this might be the problem and solution. Please read both (scroll).
Posted on Sep 26, 2010
Is there a way to stop coffee from spraying?
There is a little part that sells on ebay for $2 that slides into the Keurig brewer lid and stops coffee from spraying from reusable K-cups. It works great and is guaranteed or money back. Here is the link:
http://www.ebay.com/itm/EASY-FIX-STOP-COFFEE-LEAKS-FROM-REUSEABLE-K-CUP-EKOBREW-SOLOFILL-CAFE-KEURIG-/271239290594?ssPageName=STRK:MESE:IT
Nov 14, 2011 | Keurig B70 Coffee Maker
Coffee is too weak
I just spoke to someone at customer service. My coffee has been weak and kind of thin. We had the Superautomatica by Saceo for years and I remembered the coffee being richer.
Anyway! The person suggested that I adjust the grind but slowly. So set it to the coarsest setting, brew 2-3 cups. Then put it to the 2nd-coarsest setting, brew 2-3 cups. To the third, brew 2-3 cups. To the forth, brew 2-3 cups. Etc. Until you're at the finest grind setting. Again, brew 2-3 cups. An awfully sensitive machine. It seems to have worked although the last few seconds of brewing continue to be a kind of milky colour (as opposed to a deep black coffee colour). You can, though, press the "cup" button to stop the brew. So once, it starts running milky, you can stop the cycle.
I hope this helps. I know I've been struggling and cursing the machine for a while :)
Dec 30, 2009 | Saeco Odea Giro Plus Coffee Maker
Won't finish brewing
We were having the same problem of it quitting the brew cycle about 1/2 way through. We put a mixture of 5 cups vinegar & 5 cups water through followed by a pot of just water and now it works like new. The vineagr must clean some sort of built in sensor.
May 30, 2009 | Cuisinart Grind and Brew 10 Cup Coffee...
Doesn't brew with the k-cup in, stops in 3 seconds
Sounds like the exit needle is clogged, pop out kcup holder, remove bottom cover,clear needle with a paper clip rinse and reassemble.
May 19, 2009 | Keurig B50 Coffee Maker
Keurig starts & stops without brewing coffee, just descaled
The pic is clogged with coffee or the air bladder is bad. Use the tool on the underside of the tray to clean out pic. If that doesn't work, the bladder will be bad.
Apr 06, 2009 | Keurig B50 Coffee Maker
GE Model 169164 stops brewing
A couple of people on here mentioned he filtration system, or charcoal filter that is in the
water resovoir as being problematic. We removed it. This morning the pot brewed entirely.
Not sure how that all is inter-connected, but it worked.
Feb 04, 2009 | GE 106591 Coffee Maker
Stops brewing
It's under warranty, return it to the manufacturer for warranty service.
Brews most of the water than stops and shuts itself off
Cuisinart Coffeemaker Decalcification Process
Run 2 cups distilled white vinegar and 2 cups water through the system - brew it like it was regular coffee. Then run plain water through the coffemaker to rinse the vinegar out and make sure the decalcification was successful. Repeat as needed. Don't forget to remove the charcoal water filters first.
-Tha Mp3 Doctor
Aug 27, 2008 | Cuisinart DCC-1200 Coffee Maker
Black & Decker Spacemaker  10-Cup Coffee Maker Logo
792 people viewed this question
Top Black & Decker Coffee Makers & Espresso Machines Experts
eyecam
iandunn_tms
Henry  Thomas
Henry Thomas
Are you a Black & Decker Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
