Question about Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed
Engine will not start. good spark, have cleaned carb, but still does not want to fire. have added fuel down carb and have been able to get motor to fire for a moment but seems like I am not getting fuel to come from the carb
  • dvsxutact May 30, 2010
    have you removed the carb bowl to verify there is no old fuel in the carb clogging up the fuel jets?
    i had this same problem with my Craftsman LT4000, turns out that the main fuel jet was totally clogged and not letting fuel pass from the main line into the carb bowl.
There is a solenoid on the bottom of the bowl on the carburator. This solenoid shuts off the fuel when the key is in the off position. Remove the gas line, remove the connector on the solenoid and unscrew it from the bowl. Plug the connector back in with the solenoid removed and watch to see if the solenoid is pulling in the rubber stopper when you turn on the key. If not, check that the solenoid is receiving power. If not it's probably in the wiring. If it has power and doesn't operate, you need a new solenoid.
Posted on Jun 18, 2010
  • 4 Answers
Pour Mr. clean in the gas tank and start it! This will make a huge differance
Posted on May 31, 2010
2001 1200 sportster cranks and backfires, carb and fuel good, could it be crank sensor?
Wasted spark system. If fuel and electrical is all good/correct it is often the case in these symptoms that motor cycle spark plugs that although looking good and firing outside of the engine are breaking down and will not fire under compression pressures on a power stroke but will fire unburned fuel on the unpressurized exhaust stroke when the plug again fires in a wasted spark ignition system and when so firing the result is a backfire, usually quite loud.
Jul 23, 2014 | 2001 Harley Davidson XL 1200 C Sportster...
Engine won't start- I have changed gas, I have a good spark, and no air blockages
Put a nice new spark plug in the engine and clean the carb with carb cleaner. Spray some cleaner in the carb throat, and put some liquid carb cleaner in the fuel tank.
Mar 05, 2014 | Troy-Bilt Super Tomahawk Chipper Shredder...
Toro str will not start, motor spins but will not fire
Ensure clean fuel. Always use Stabile in fuel. Follow fuel line from fuel tan to carb, ensure no leaks. Remove carb fuel bowl to check float operation. Have pliers to crimp line or use fuel shut off valve. Remove carb float bowl and clean. Float should hang down freely gas should flow. Push float up gas should cut off. Replace spark plug, ensure plug wire snaps on tight. Clean or replace air filter. Ensure oil is full, 30w oil. All mowers have low oil shutoff.
Sep 12, 2012 | Toro TimeCutter Zero Turn Lawn Mower...
Won't start. Drained old fuel and added fresh; cleaned in-tank fuel filter; cleaned plug. Still won't start
i would take the plug out and and the spark plug wire on the plug and try cranking it over and make the plug is firing if there is no fire then the ignition coil is dead but if you have fire then its a carb problem rarely ever a timing considering most mowers are timed with key ways which prevent them from jumping time.but if you have fire your good their but my overall suggestion is to rebuild the carb and swap out the spark plug if the mower has set for a period of 6 months or longer.
Aug 26, 2011 | Garden
Briggs and stratton engine model #31H777,type0297 E1,code041014ZA-motor turns over but won't start-getting fire at the plug also plug is wet with gas.
there are the basic things for an engine to start. air, fuel, and spark. if you are getting spark at the plug one down. try taking your air cleaner off and spray starting fluid into carb with choke open then close. if it starts and runs a litlle then dies then you have a fuel problem. take carb off and clean real good take bowl off and clean with carb cleaner. that should solve you problem if not let me know
Dec 24, 2010 | Garden
Apache quad 100cc Bike will not start, battery is ok, plenty of petrol in it but will not fire, can anyone help,
this typically comes down to basics. you engine needs air,fuel and spark to run. FUEL - pull the main fuel hose in to the carb from gas tank and turn on to be sure fuel is getting to the carb. SPARK - next pull out spark plug and while still connected to igntion cap, touch end of plug to motor and turn over engine. if you do not see spark, this is your issue and is usually the most common issue. if spark is present, spray starting fluid into the spark plug hole, reinstall plug and try to start, if it trys to start as in starts then dies, your not getting fuel past or from your carb. Clean carb. AIR - last but not least check your air filter and insure it is not clogged or obstructed and is allowing air to the engine. As for no spark, the can be many issues from a bad CDI ignition coil or generator/stator to just a bad kill switch or cut/unplugged wire.
Dec 14, 2010 | ATK 125 2-stroke Motorcycles
JD LA140 quit running all of a sudden. It was directly after I added older gas to it as the tank was almost empty. It won't even almost crank as if it isn't getting fire. However, the plugs are firing...
First thing. Dump the fuel! Pull the fuel line ahead of the fuel filter and drain it all off! Old fuel is sometimes accompanied by a lot of water. Especially if stored without proper container closure.
Next, drain the carb bowl. The carb bowl should have either a drain screw in it or the bottom of the bowl has a hex head fitting to allow the entire bowl to be removed. Take off the bowl and get rid all the fuel inside it. Look for water droplets that sit under the fuel on the the metal surface after the fuel has been poured off. If you have the bottom hex fitting type carb look at the barrel of this fitting. That is where you main jet is! You can use a fine piece of metal wire strand and clean out this jet. The holes are generally on the side *(if the jet has a bottom adjustment screw built in than it also has a hole in the center. Run the piece of wire through where you see dark spots and see if they clear out. Look through the jet and see if your handywork is allowing light through. *(yes? than you found a blocked jet and just cleaned it!
Now, put the bowl back on. reconnect the fuel line and put some fresh fuel in it. You might want to recharge the starter battery since you have probably cranked the battery down from all of this.
You can check for spark by getting another spark plug and using it as a tester. Leave the engine plug in place and just lay the tip of the plug on something meta/grounded and see if there is spark while cranking.
If you find spark this rules out a bad ignition system. Put the spark plug boot back on the plug on the motor and start it up!
If you can take off the air filter and look into the carb you might want to try putting a little bit of clean gas right into the carb opening. This will help prime the motor and perhaps get it running enough to eject the remaining water inside the intricate spaces in the carb.
Be careful and good luck.
May 25, 2010 | John Deere Garden
2.3 ford marine engine
Gas engines need fuel, air and spark. You have air and spark check the fuel filter and pump. If the boat is being commissioned after winterization it is possible that the fuel system has a varnish build up if a fuel stabilizer was not added at time of lay up. Take of the float bowl, remove the needles and clean well with a carb and injector cleaner. Try to blow out the jets. Good luck.
Apr 02, 2009 | Boating
Poulan 42-Inch Steel Deck 17.5 HP Briggs & Stratton I/C Engine With 6 Speed Logo
662 people viewed this question
Top Poulan Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
