Question about Xerox WorkCentre XD125F All-In-One Laser Printer
Xerox XD125F I have taken out the fuser assembly. I was expecting to see broken teeth on gear. I didn't. However, when I tried to gently turn the gear it would turn hard and didn't seem to be connected to the light brown tube (?). Should it turn the light brown tube. It seems logical that it would. I definitely heard a small something drop out when I removed the fuser assembly. I expected it to be small teeth...but it wasn't. I am not sure what fell...but I can only imagine that it was something that connected the gear to the small tube...a compression type ring? I am trying to avoid buying a $200 full assembly. Can I replace just the broken part? What steps do you recommend next?
  • RDCC Apr 08, 2008
    Thank you very much tryit. I spoke with Britt. He was very helpful and a part is ordered.
    RDCC
    President:
  • 2,072 Answers
What you can try is just replacing the fuser drive gear and the bushings on the heat roller.
That small tube your relating to is the heat roller. The plastic like busings are really tight not allowing it to move freely.
Not the easiest fuser to rebuild to be honest. You will also want some high temperature lubricant to use on those bushings and also on the pressure roll shaft to make that roller run smoother.
Clean it well and be sure it is running free.
You need to look at the heat roll and presure roller carefully to check for wear and grooves. If they are worn, you will be better off replacing the fuser then trying to rebuild it.
I will provide you the link to an excellent parts source, click on parts then the scroll down tot the XD125, They have about everything you want for that fuser.
If you call ask for Britt..
https://www.partsdrop.com/store/
Posted on Apr 08, 2008
SOURCE:
Where is the fuser located on MXC 311
The fuser unit is located in the right hand side of the machine. If you open the right door, inside the upperpart of the machine you will see 2 grey handles, 1 towards the front of the machine, the other towards the rear. If you pull these handles out you can then remove the fuser unit. There are 3 known faults for loud fuser noises,1 is the fuser drive gear inside the machine strips the teeth on it, second, the main drive gear in the rear of the machine strips the teeth(usually caused by the 1st problem getting broken teeth stuck in the remaining teeth causing the drive motor to strip the main drive gear) & thirdly, the pressure release mechanism breaks on the fuser unit itself. If it is any or these then unfortunately you will need the assistance of a dealer to replace the damaged parts.
Hope this helps.
Dave.
Oct 13, 2014 | Sharp Office Equipment & Supplies
I have a ticking-clicking sound coming from the top rollers of my HP4+ rear exit assembly?
The ticking sound you are hearing is most likely a broken part called a Fixing coupler. This small gear is what drives the fuser assembly and the output rollers. To check this you ill need to open the back of the printer and remove the fuser assembly, there are 2 screws in the middle of the printer, unscrew and pull the fuser out.
The fixing gear can then be seen behind where the fuser was on the left side. You will see a small gear about 3/4" around. Rotate this gear and look for broken or missing teeth. We repair printers in our shop and when we get Laserjet 4, 4+ or 5 series printers in with clicking or grinding sounds that is almost always what the issue is. The Fixing coupler is part RF5-0350 and is available here: http://www.ccl-la.com/catalog/product_info.php?cPath=24_41_48&products_id=125
It takes about 20 minutes to disassemble the printer to get to the fixing coupler so you can change it out. Well worth it if you do the work. A repair shop will probably charge you $75-100 plus parts to do the same thing.
I hope this helps, if so please rate my solution.
BuddyMc
Aug 17, 2011 | HP LaserJet 4 plus Printer
My HP Laser Jet 4 makes noise when I turn it on, but it indicates Ready. What could be causing this?
This sounds like you have a broken part called a fixing coupler. To check this unplug the printer, now turn the printer around so you can see the back side. Open the fold down cover. You will be looking at the fuser assembly. There are 2 screws that hold the fuser in place, remove them and pull out the fuser assembly. Now look inside the printer on the left side behind where the fuser was located. You should see a gear assembly. This is the fixing coupler. The small gear that is closest to the rear of the printer is the one that breaks and caused the issues you are having. Look over the gear and check if it has broken teeth. You can turn the gear by hand to look all the way around and see all the teeth. If you do find the gear is broken then you will need to replace the assembly. The procedure is fairly simple, if you can use a screwdriver then you can do the repair. We carry this part in stock and you can contact us at [email protected] if you need more information.
I hope this helps, if so please rate our solution.
BuddyMc
Corporate Computer
www.ccl-la.com
Nov 24, 2010 | HP LaserJet 4 plus Printer
395 Service Engine Error
Hello kieran,
This might help you. I found this on one printer forum.
From the manual:
Fuser Drive and Contact Cam System Service Check
Error Code 993: Indicates the cam sensor has not been activated.
The sensor activates when the fuser drive motor turns the cam disk.
If the fuser drive motor does not turn on, or the drive parts are not
operating, go to A.
If the fuser drive motor turns and appears to be operating properly,
and the cam is turning, go to B.
and the cam is not turning, go to C.
A The fuser drive system is not operating properly.
FRU Action
1 Fuser Assembly
Fuser Drive Motor
Fuser Motor/Paper
Feed Motor Carriage
Unit Motor Cable
Engine Board
Check the fuser assembly internal drive gears
for binding, or broken or worn teeth. If a
problem exists, repair or replace the fuser
assembly.
Remove the fuser drive motor from the stay
assembly, leaving the motor cable connected
to the motor. Turn the printer on, but do not
allow the motor to touch other areas of the
printer. Verify the motor turns during POR. If it
does, the problem is most likely in the motor
mounting stay assembly. Go to step 2.
Check the motor for shorts between the case
and each motor winding. If a short is found,
replace the motor.
Note: Damage to the engine board may result
from a shorted motor.
Check the motor for open windings. If found,
replace the motor.
Check continuity of the fuser motor/paper feed
motor/carriage unit motor cable.
• If incorrect, replace the cable.
• If correct, replace the engine board.
2 Motor Mounting Stay
Assembly
(Fuser Drive Parts)
Check the fuser drive gears, gears C3-1, C3-
2, the clutch spring, motor drive gear, gear C2
and C4 for signs of chipped gear teeth, worn
parts, or improper operation. If problems are
found, repair as necessary.
Check the cam gears and solenoid for proper
operation and signs of broken or worn gear
teeth or damaged parts. If found, repair or
replace the motor mounting stay assembly.
B The fuser drive system is operating properly and the cam disk is
turning.
FRU Action
1 Cam Sensor (PH16)
Engine Board (M4)
SN Cable
Be sure the cam sensor is mounted correctly
and locked into place.
Check the following voltages on the cam
sensor:
Pin # Signal Voltage Voltage
Voltage Disc in Disc Out
1 (Orange) +5 V dc +5 V dc +5 V dc
2 (Brown) -CCSENS +5 V dc 0 V dc
3 (Green) GND 0 V dc 0 V dc
Note: The voltage on pin 2 should vary, as the
cam turns from approximately 0 V to +5 V dc.
• If the voltage on Pin 1 is incorrect, check
the cable. If incorrect, replace the cable.
• If the cable is good, replace the following
FRU's in the order shown:
1.Cam sensor
2.Engine board
3.SN cable
C The fuser drive system is operating properly and the cam disk is
not turning.
FRU Action
1 ContactCam
Solenoid
CRF Cable
Engine Board
Check the solenoid for proper operation,
making sure it picks during POR cycle.
Disconnect the solenoid and check the
resistance on the solenoid cable. It should
measure approximately 65 ohms. If incorrect,
replace the solenoid.
Check the voltages on the solenoid cable
connector.
Check the following voltages on the contact
cam solenoid cable connector:
Voltage Static Picked
1 (Red) +24 V dc +24 V dc +24 V dc
2 (Black) -SL2ON +24 V dc 0 V - +24 V dc
Note: All voltages are approximate.
continuity of the CRF cable to the cam
solenoid.
Assembly
Check the clutch spring, clutch boss, clutch
disk and gear C4 for signs of wear, broken
teeth or binds. Repair or replace the motor
mounting stay assembly if a problem is found.
Normaly the fuser is not turning - check the cleaner pad is not jammed in too tight. Then replace the fuser drive block 12G1348.
Jul 29, 2009 | Lexmark C510 Laser Printer
Error message 993, what is this?
that is a fuser drive error on printers. it is the part that fixes the ink to the paper.
i have a check for you but is not an easy fix.
if fuser drive is gone will cost approx £12 to replace.
operating, go to A.
FRU Action
1 Fuser Assembly
Fuser Drive Motor
Fuser Motor/Paper
Feed Motor Carriage
Unit Motor Cable
Engine Board
assembly.
replace the motor.
replace the motor.
Assembly
(Fuser Drive Parts)
turning.
FRU Action
1 Cam Sensor (PH16)
Engine Board (M4)
SN Cable
sensor:
1.Cam sensor
2.Engine board
3.SN cable
not turning.
FRU Action
1 ContactCam
Solenoid
CRF Cable
Engine Board
connector.
solenoid.
Assembly
Feb 25, 2009 | Ricoh Aficio GX3050N Printer
Gx3050n error code 993 what is this?
operating, go to A.
FRU Action
1 Fuser Assembly
Fuser Drive Motor
Fuser Motor/Paper
Feed Motor Carriage
Unit Motor Cable
Engine Board
assembly.
replace the motor.
replace the motor.
Assembly
(Fuser Drive Parts)
turning.
FRU Action
1 Cam Sensor (PH16)
Engine Board (M4)
SN Cable
sensor:
1.Cam sensor
2.Engine board
3.SN cable
not turning.
FRU Action
1 ContactCam
Solenoid
CRF Cable
Engine Board
connector.
solenoid.
Assembly
Feb 25, 2009 | Ricoh Aficio CL1000N Printer
HP Laserjet 4100 series , paper jam output tray.( on top of the printer ). The roller under the topcover is turning the wrong way. The paper can't get out of the printer, and jams between the upper roller...
Hi F_bulsara,
First thing to try is to flip the paper over in the input tray. There are 2 sides to paper. One side may curl a bit too much due to heat of the fuser and get caught near the output rollers.
Unless the Output Assembly was assembled wrong, it is impossible for the rollers to turn the wrong way. The gear in the fuser drives the output assembly. The top rollers are rolling out.
If the rollers are not rolling, then one of the gears must be broken or missing. The output rolllers might need cleaning.
Next check the fuser unit. Disconnect power to printer and turn printer round. Remove the back output tray and the two small covers (left and right). Undo the 2 screws that hold the fuser in place. Pull the fuser out. Check the gears on side of the fuser. A broken gear in the fuser could cause this problem.
S88
Nov 18, 2008 | HP LaserJet 4100 Printer
Rebuilding the brother fuser for the intellifax 4100
Although it fit the broken fuser, it does not mean it's ok.
1-they must have the same number of teeth ( diif. gears have diff. amounts of teeth)
2-it must be the same diameter ( so they can mesh together, otherwise it's touching the tip of hte teeth and may be skipping.
But I'm not sure the double image is coming from there, it would jam the paper because the timing is off.
Anyway you need to eliminate the obvious then see what happens, I think you said you had another tonertry putting that in, if it doesn't work then change the gear for the correct one.
try precisionroller.com
Sep 08, 2008 | Brother IntelliFAX 4100 Laser Fax
Paper jam problem in laser printer 4100
if this happens every time you need to replace the fuser. but there is a possibility it could be the main gear drive assembly, 9 times out of 10 it's the fuser. a gear on the fuser usually breaks a few teeth. the fuser is very easy to replace and is a part that will eventually need replacing on all printers.
Jan 07, 2008 | HP LaserJet 4100 Printer
Xerox WorkCentre XD125F All-In-One Laser Printer Logo
110 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Clive
Clive
Philip Hughes
docukaaf
Level 1 Expert
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
