Question about Olympus SP-350 Digital Camera
Card formatting Hi there, when I try to view my photos or take a picture my camera says the card needs to be formatted. now, i've had this camera for quite awhile and I have never seen this before. When i try to format it, it says everything will be deleted. I can't have that since there are photos I need to download. What happened? Is there anyway I could fix this?
    President:
  • 1,944 Answers
Try the card in an external card reader and back up the photos from there and then reformat the card.
Posted on Apr 08, 2008
My camera says the memory card is locked and memory card error appears when I turn on the camera. I've read that I have to format the card, but won't the photos be destroyed? How can I get my pictures
There is a tab on the memory card so you will you need to remove it from the camera and change the position of this tab to "unlock" it. DO NOT format the card until you've BACKED UP your files from it (typically to a PC or USB drive (stick or external hard drive).
Nov 18, 2011 | Canon PowerShot SX130 IS Digital Camera
I'm taking photos with my Samsung D860, and when I want to view the pictures taken, it says 'no image', 'file error' or 'card error'. Sometimes it also says 'card...
Actually the camera is fine and the cause of problem is memory card, Mostly cheaper cards do this but the original cards don't. And as far as concern that you have lost many precious pics, No need to worry about it. Just install any recovery software on your PC and with the help of the software you can get back your pics, Secondly, shift all your pics on memory card in your PC and then format the card through camera, this will solve your problem.(Remember that run recovery software before you format the card if you need to get back your data from memory card)
Thanks
May 13, 2011 | Cameras
I am using a fujifilm 2GB M xd card. After a photo shoot, when I turned the camera on it said "card not initialized." What can I do? I really do not want to lose these photos, as they were from a shoot and...
You need to format the card . Follow the procedure given below :
Insert the card into the camera and then go into the menu and find "format" and click format OK. Now complete format for the card is done .
Now use the software recovery tool from the link below to recover the photos :
Photo recovery
Hope this helps .
Apr 12, 2010 | Fuji FinePix S6000fd Digital Camera
Camera: Panasonic Lumix DMC-FT1 Problem: Camera is not saving photos Hi, my camera started responding very slugglishly yesterday. I took a few pictures, and some of them wouldn't save. If I tried to switch...
Are you formatting the card in the camera as you're supposed to? Have you tried going into the menu and finding "reset" and followed the on-screen instructions? Do you have photos on the internal memory? If so, remove your card and format the camera to erase the memory.
Mar 03, 2010 | Panasonic Lumix DMC-TS1 / DMC-FT1 Digital...
My camera kodak easyshare C1013 cannot show pictures. it says "unrecognised file format"..i need help
The camera stores the pictures in a JPEG format only. You can use .jpg files in most image editing programs. Videos are stored in a .mov format that you can view with QUICKTIME software or KODAK Picture Software.
* What you can do is transfer the pictures to your computer and check the file format
* You can delete photo then just take a photo again.
Unrecognized file format means the file format of the picture in the camera is not JPEG or the memory card is faulty
Nov 16, 2009 | Kodak EASYSHARE M1063 Digital Camera
Card Error
Take no more pics until you've recovered the photos, take the card out of the camera. Here's some freeware photo recovery software that should be what you're looking for.
You will need to use a flash card reader with this software. If you don't have one, get one, they're very inexpensive.
The reason this occurred is that you likely never formatted the card. The card will work fine in the beginning but eventually will corrupt. AFTER you've recovered the photos, format the card in your camera to prevent this from happening again (dig out that instruction manual to figure out how). Keep in mind formatting will also totally erase your card, so again only do this after you've recovered the photos.
Oct 04, 2009 | Cameras
After trying to upload photos from my Olympus 1050 sw I now cannot use the camera to take photos. It simply says ´write protect´. When trying to view the pictures it says ´no picture´ when there is at...
Sounds like you will need to format the memory card. This will permanently erase all the data from the card and then you will be able to use it again. To format the card: Press the Menu button - right arrow to Setup - right arrow to format option. You will see format yes or no. Choose Yes and press ok. This will clear the write protect message and the card can be used again.
Apr 08, 2009 | Olympus Stylus / mju 1050 SW Digital...
'File error' message on samsung L200 camera when viewing a photo
Possible solution:
I had/have the same problem using L200 and SDHC memory card, called Samsung. Can't view certain pictures on camera or computer, camera freezes when viewing those certain pictures, green light flashing.
Samsung support told me that I needed to copy my (good) pictures to a computer first because a memory format will erase everything. Then format (menu->settings->format->yes) my memory card. Tried this just now and took some new pictures, so far so good.
Jan 15, 2009 | Samsung L200 Digital Camera
Screen reading memory card not initialized
It sounds like your XD card is corrupted. How and why i couldn't tell you. You will need to get the pictures recovered from the card using a special software (image recovery software, can down load for free from some web sites, or some companies can try and do it for you) and then try and format the card in the camera. DO NOT FORMAT THE CARD BEFORE YOU RETRIVE YOUR IMAGES. If you do all traces of the images may be lost.
All the best and happy snapping.
Aug 20, 2008 | Cameras
Formating Smart Media cards
I would say that the card is starting to wear out. If you want to try to salvage the pictures, try something like "Smart Recovery" from Convar and then get a new card as the problem is likely to get worse: -
Sep 06, 2005 | Olympus D-320L Digital Camera
Olympus SP-350 Digital Camera Logo
Top Olympus Cameras Experts
Willem.
Willem.
Are you an Olympus Camera Expert? Answer questions, earn points and help others
