Acer Aspire - tried to replace a damaged screen, but now the system wont start up properly... goes through a 5/6 second cycl, of powering up and down, continuously, never actually seeing anything on the screen... please can you help?
  • paul_arscott May 30, 2010
    sorry to ask, just that we have an urgent requirement! just keeps cycling through this power problem, very infuriating! :)
  • 4,924 Answers
If it is like a loop than the ram memory is to blame ..try to remove them ..and replace it and give it a try ..If it has more than one ram units in it ..remove them and only let one inside and try to boot...this way by changing them you will see if one of the ram unit is damaged..
if only have one ..and after removing it and place it back again it do not want to boot..but still in a restarting loop with a click noise...than it is a issue that can be solved by removing the bios battery to reset bios settings and make it see the devices again ..If you know how to open it ...remove the keyboard and probably the wifi card to get to the battery ..remove it ...place it again ...insert all again with care ..and give it a try ...should prompt you to press something to go to bios and make the time settings and after that will boot fine ..if all you changed in it is functional..
Posted on May 30, 2010
  • 2 more comments
    HI, thank you... sorry to be a pain, but am no expert here. how do i find the ram?
  • Catalin Turcu
    Catalin Turcu May 30, 2010
    http://www.youtube.com/watch?v=7xKSpW3q0...
    OK I didnt know the model so I placed for aspire one ..this is the most common and to get to the ram memory you have to actually remove the mother bord ..this is a tough operation but in my link there are several videos and if you carefully watch them you see that it is a issue just of the order of the operation a few ribbons from the peripherals and a few snap clicks...of the case... if you open it ..remove and place the ram in again ...and also remove the battery ..this will force to get to default settings and recognize the hardware again ..
    For other models of laptops the access to the ram is made from the back by removing the lid screwed there ...
    thank you... will give it a go with a clear head and clear eyes in the morning!
  • Catalin Turcu
    by the way ..this is a issue that usually follow a sudden power lost ..and you should first try to remove the battery and all power source ..put them back ..and give it a try to see if this will fix...and only if the issue is permanent than remove ram and battery
  • 1,472 Answers
Paul_arscott
It sounds like ether you do not have a connection right and/or you are having some kind of power issue.
Please let me know the exact model of Acer you have so I can look some info on your system.
Issken
http://www.fixya.com/users/issken
  • 3 more comments
    HI, its acer aspire 4810TZ... the connection for the new screen seems to be fine, slotted in perfectly. Previously, teh screen was damaged due to impact, but we could see the start up and log-in... now having replaced the screen, it just wont start up. do i need to fully secure the whoel screen and front befor eit will fire up? I have done all except for the plastic front, so i would think it would be fine.
    hi are you still online?
  • Will Hartford
    Will Hartford May 30, 2010
    paul_arscott
    As long as all the connection are connected properly then you may just need to clear the flee power on the system.
    To do this you will need to remove the battery and unplug the AC power
    Next hold down the power button for 30 to 45 seconds
    After you do this plug back in the AC Adapter and try to turn on the computer
    Let me know how things go
    Issken
    hi again... alas no, it didnt work. someone else suggested i remove and replace the ram, which ive also done, no joy. this problem didnt exist before i replaced the screen, so am very confused! appreciate your help... :)
  • Will Hartford
    paul_arscott
    The next question I would have is where did you purchase the screen from. It is possible that the replacement screen you got was DOA and/or not the right model for your computer.
    Do you have access to an external monitor. If you do you may try hooking it up and see if you can get the system to boot. You may also try disconnecting the new screen to see if you can get the computer to fully post. Then you may be able to pull the error logs from Event Viewer if the system was booting that far.
    Issken
Hi I have just replaced a cracked screen which was running ok but now the laptop wont start I get 5 flashing orange lights and nothing it will not even activate fans.I have disconnected battery and...
Could be a battery that has reached the end of its life cycle. Or the power adapter could be faulty. If you have access to another power supply try plugging it into your machine and see if it powers up properly. Likewise with the battery. Do you have access to another battery to see if it will allow your machine to come up?
You may also need to double check that the screen is plugged into the motherboard properly.
Mar 20, 2015 | Acer Aspire V5
My Acer 5552G won't turn on.
try a system reset see below link
http://www.pctechbytes.com/acer/acer-aspire-system-recovery-partition/
Jan 20, 2013 | Acer Aspire 5552 5552g 5553 5553g 5560...
My AspireOne ZG5 Does not start up. When starting up the power light comes on and all the LEDs light up for a second and I can hear what sounds like the hard drive starting up but I get nothing on the...
if there is no diaplay ....u need to update the bios ...download zip file from this site http://macles.blogspot.com/p/acer-aspire-one-bios.html exteact in formated USB drive... plug the charger keep press FN+ESC button and trun on laptop u can see light flashing when light gose off u can relase button .. and wait for 5 min .. system will restat and u can see display... thanks
Sep 13, 2010 | Acer Aspire One PC Notebook
I have a ACER Aspire 1640 model ZL8 I replaced the battery and power supply. I plugged in the power supply to the unit with the new battery installed. the unit started immediately but went to a blank...
I'm facing the same prob ,system power on,cpu fan spin for 5 to 10 seconds n then stop.(system is still on with leds)no display or sometimes the acer logo only.
I opened the system n found the following Ic over heating
(24 U4 EC PC97551 (Power and I/O Connector)
24 is the number on service guide
any suggestions?????????
Sep 02, 2010 | Acer Aspire 1640Z Notebook
ACER Aspire laptop power cycles on and off
Sir, form the symptoms I believe that the Battery is completely dead, the system is unable to identify the battery. If possible try checking the battery with a similar model, and the the system should be all set to go.
please encourage us,if this tip was helpful to you.
Apr 02, 2010 | Acer Aspire 7520-5185 Laptop
The screen goes black ACER Aspire
I have the same problem with my Acer 5684 laptop. Just bought display backup light (CCFL) from ebay. Hopefuly will arrive within next 5-10 days. I will let you know if this solves it.
Sep 30, 2009 | Acer AL1914 19" LCD Monitor
Acer aspire 7720 start up problems
You need to try to isolate the problem. Try connecting an external monitor to your laptop. Press function screen keys. If you have a picture on your external monitor then you have a video problem - most likely an inverter, although you may need a new screen, unlikely but possible.
If you have no picture then you have a system problem. Disconnect the battery and AC adapter. Remove the memory and reseat. Repower your laptop and see what happens.
Aug 02, 2009 | Acer Aspire 7720 Notebook
Acer Aspire 7004 wmsi Will not start.
When you press the power button does anything happen? such as lights or LED's illuminate?
You could try the following -
1. Make sure there is nothing plugged into the computer (USB devices or memory cards etc etc).
2. Remove the power cable & the battery
3. Press the power button for 30 seconds
4. Insert the charger but not the battery and try and start it up.
If that doesnt work check the USB ports for damage and the port where the charger is plugged in aswell.
If they are damaged or it still wont start it will probably need repairing.
Jan 18, 2009 | Aspire (ATX-AS500W-BL) (atxas500wbl)...
Acer Extensa 5210 laptop wont boot
Try the following:
1) Remove power cord, battery and hold the power switch down for at least 30 seconds.
2) Remove and reinstall your memory module(s).
If those don't do it, get back to me for more ideas.
Thanks!
Ron
Dec 14, 2008 | Acer Computers & Internet
Acer Aspire T180 turns green and blocks.....
TRY BOOTING FROM A SYSTEM DISK , IF THIS DOESN'T WORK YOUR RAM MAY NEED TO BE CHECK TO SEE IF ITS FUNCTIONING PROPERLY
Jul 31, 2008 | Acer Aspire™ T180 PC Desktop
Computers & Internet Logo
David Payne
David Payne
