Question about Toshiba Satellite (K000004080) Motherboard
Blank screen While I was using my Toshiba L305 S5930, the screen went blank. The VGA output port does not seem to have any signal. The notebook powers up and down, the fan works, but the caps lock led does not light up. I'm thinking that the video card failed, I'm guessing a new motherboard is in order. Any thoughts would be helpful!
  • Toshiba Master
  • 11,800 Answers
Yes, this looks like a video fault. Last hope test - remove the hard and optical disks and try again using different memory module and processor. If it's the same then you will know for sure
Posted on May 31, 2010
Toshiba laptop screen out, what cable is used to hookup to external monitor
You can use a VGA cable to connect the VGA out port of your laptop to externel monitor.
If your Laptop and Monitor has HDMI port, you may use that.
Dec 15, 2013 | Toshiba SATELLITE L755-S5214 15.6"...
I connected my Toshiba L305 laptop via a VGA cable to my hdtv and it worked beautifully for a while. Suddenly, the TV indicated that there is no signal. I
If you were using the computer at the time, it may be a cable/plug/socket failure. Try a different cable.
If you were watching a movie, you may want to check your screen saver settings. Try doing what you were doing and see if it disconnects after a specific time (so if your screensaver is set to 10 minutes, does your TV lose signal after 10 minutes?).
Apr 30, 2012 | Toshiba Satellite L305-S5911 Notebook PC
L305D-S5930 dvd wont burn documents to a dvd disc
You need a program, like nero.
if that doesn't work then put a DVD in the drive & see if the computer picks it up in the my computer.
the first thing that goes in a CD/DVD-RW drive is the DVD heads, thats if your drive is a CD/DVD-RW.
Have a look on the front of the drive tray, if it say CD-RW DVD ROM then it doesn't burn DVD's it only plays them.
Jan 30, 2012 | Toshiba Computers & Internet
I cannot connect to my hp dv5220us to the tv through vga. i think the vga driver is not installed . please suggest me which driver am i supposed o download.thank you.
Most laptops have three modes for video:
* output only to internal LCD screen
* output only to external VGA port
* output to both internal and external
Hold down the 'fn' ("function") key on the keyboard, and press one of the twelve 'F' ("function") keys, to "toggle" the video through the above 3 modes of operation, until you get output through the VGA port to the TV.
Also, on the TV, use the "input" or "source" button on the TV's remote control to select the 'VGA' input-port as the signal to be displayed on the TV screen.
Jul 16, 2011 | HP Pavilion Dv5220us Notebook
What do I need and how do I connect my Toshiba L305 model PSLB8 050302f to my hdtv to view online tv?
I dont believe that laptop has an HDMI port on it. If you have an LCD TV then your TV may have a VGA or DVI input on it. You can connect your laptop to the TV by using a VGA to VGA or VGA to DVI cable. If you your TV doesn't have one of these input ports, then you're not going to get your laptop connected to your TV.
Mar 03, 2011 | Toshiba Satellite Pro L300 Notebook
I own a Toshiba NB 205 Notebook PC. I connected my flat screen TV to the notebook so I can use the TV as the Toshiba's monitor. I purchased a male-to-male VGA cable and plugged it into the VGA port on...
you need to tell the computer to move the signal over ---look for a picture of 2 tv screens on the laptop usually F5 or F8 (use with Fn key)otherwise right click on the desktop>choose PROPERTIES>SETTINGS
Jan 01, 2011 | Toshiba Computers & Internet
Connect laptop to toshiba 50h8250
This requires a converter. If the laptop has a VGA port, use an VGA to component video or VGA to composite video converter. See this site for some examples: http://www.svideo.com/pctocomponent.html . Do not use a VGA to component video cable - these are meant for projectors that use RGB signals.
If the laptop has an HDMI port, you'll need a different type of converter, like this: http://www.hdtvsupply.com/hdmi-to-component-adapter.html . Then set the output to YPbPr.
I hope this helps.
(I doubt your laptop has a video controller that can output a non-RGB signal.)
Nov 14, 2010 | Toshiba 50H82 50" Rear Projection...
Toshiba Satellite L305 no VGA signal to TV
Try to roll back the driver on the Toshiba...there are times when the current driver will get corrupt out of the blue.
Aug 28, 2009 | Toshiba Satellite L305-S5894 Notebook
Can i connect my laptop to the tv?
Yes there is a way to connect the laptop to the TV via VGA output. You can easily connect most of the laptops to TV via VGA and your notebook is fine for that purpose as well.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Aug 07, 2009 | Toshiba Satellite L305-S5933 Notebook
Screen blank off after xp logo on startup
it sounds like it is possible that your lcd backlight has died. it's not that easy to fix yourself. i would recommend bringing it somewhere to see how much it would cost to get it fixed, it will not cost as much as a new laptop. or you can just continue to use it through it's vga port but now it is no longer a laptop but a desktop.
Apr 24, 2009 | Toshiba Tecra A5 Notebook
Toshiba Satellite (K000004080) Motherboard Logo
473 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
