Question about Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher
The unit flashes F1 with a spanner sign showing on both drawers
The motor drives in what sounds like top gear and the lights flash.
  • thecalverts May 31, 2010
    noise machine is making - high rev
    both drawers lights flashing
  • Fisher and P... Master
  • 3,247 Answers
Refer your problem with fisher and paykel DD603 dishwasher. Please clarify how are you able to assess the motor is driving in top gear. Which lights are flashing?
Is this problem in both drawers or just one?
Posted on May 31, 2010
Testimonial: "thank you first time using this site and appreciated the prompt response, turned out it was the lids and water was getting thru, thanks."
  • Sam May 31, 2010
    can you please answer the questions I had asked rather than rate my solution with 2 fingers. I have not given you any solution yet.
    it is difficult to help if the problem details are not given. Please remove the rating if you are not keen to receive assistance from fixya.com
  • Sam Jun 01, 2010
    I take it that F1 code is flashing on both drawers and motor is running.
    What happens when you take the mains power off and then turn on after as short delay?
    Most likely the drain hose is burst and water has collected in the housing. The F1 error occurs when the flood switch in side the dishwasher trips.
    You will have to find the source of the water coming in and dry the flood switch after taking the drawers off.
F1 error on Fisher and Paykel Dish Drawer
Sorry did not see your problem report earlier. If you have checked the sensor under the bottom drawer and it is dry, then F1 is caused by top drawer power filter fault. This means the bottom drawer controller is giving the F1 error but the top drawer controller has no power. Can you confirm this.
Apr 08, 2013 | Fisher and Paykel 23 in. DD-603SS Built-in...
Hp 4L printer won't pickup paper from tray. Sequence- green led light- motor running but with grinding- no movement from pickup roller or foot- finally a misfeed led light.
That is a very common problem with the Laserjet 4L and 4P printers. The sound you hear is caused by a broken motor drive gear. This is a small plastic gear on the drive motor shaft. They can develop a small crack which prevents the motor from turning the gears for paper pickup and toner movement. When the motor tries to turn the broken gear can not turn the other gears and makes the popping or grinding sound when the gear teeth slip. You will need to replace the motor gear, it is available here:
http://www.ccl-la.com/catalog/product_info.php?cPath=24_41_49&products_id=61
I hope this helps,
BuddyMc
Jul 16, 2012 | HP Office Equipment & Supplies
94 explorer, manual trans. last night while driving, 4x4 and low range lights flash on then off. when I shifted into 5th getting on freeway, lose all drive power as if clutch suddenly went out. 4x4 light...
It sounds like the bearings inside the transfer case are going out, with pressure on it while accelerating its fine, then when you push in the clutch the transfer case gets slack allowing the internal parts to move, causing the lights to flash as gears move causing the shift motor to move. I would start looking for a replacement transfer case.
Feb 18, 2011 | 1994 Ford Explorer Limited
I have F1 flashing on my dish drawer....turn it off a couple of months ago because of the same issue and have not used it since....turned it back on and used the bottom drawer...all OK...went to use the...
Please confirm if the F1 on top drawer shows up immediately you press the Start button or part through a wash cycle? What happens when you turn off the power and back on.
Sep 02, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
My HP LaserJet 4L printer just makes a grinding sound when I attempt to get it to print. It makes the sound for several seconds and then the Paper light starts to flash without printing
Common issue with these older 4L printers. The problem is a small plastic gear on the main drive motor has cracked. This is what causes the noise and since the machine is not "running" there is no paper feed and thus the paper jam light. Basically there is no drive to any of the printers components. May be hard to find a replacement motor these days but that is what you would need to fix the printer.
wheatlandsvcs
Aug 18, 2010 | HP LaserJet 4L Printer
F1 flashing with a spanner showing
Hi..
F1 code indicates a leak,you will find the water under bottom drawer.Might be the lid probably not sealing well. You have to seal it well properly to fix this error in your dishwasher.
Thank u !!
Jun 17, 2010 | Fisher and Paykel 24 in. DD-602 Built-in...
Lights come on with f1 spanner sign flashing and bleeping
There is a leak causing the bottom housing wet so the floor sensor triggers. Dry out the bottom housing F1 will be disappear. However if the leak is not fix, the sam problem will happen again. The leak is from improperly being sealed between the top lid down against the top edge of the tube during operating.
May 07, 2010 | Fisher and Paykel DD605HSS 23 in. Built-in...
My dishwasher is showing signs of a spanner
I am slightly unsure if your double drawer dishwasher is the prefinished model (self standing with LCD display) or the integrated model with no LCD display.
The spanner symbol on the top drawer is telling you that a fault code is actuated. But I am not sure where this symbol is on your unit if it is built -in (integrated model).
You will have to check which red light (from the left) is coming on.
I assume there are 5 lights on the inside of drawer.
With the bottom drawer - again you will have to check which light from the left comes on sometimes as you mentioned.
If you have a user manual you should be able to tell what Fault code it is - something like F1 or F2 etc. Is it continuously beeping when the red light is on? How do you turn the beeps off?
The scrubbing bush symbol on bottom drawer may not be a problem. It appears the drawer is programmed to a particular option. But I am not sure where this symbol is showing if you do not have an LCD display panel. You can reset the option - possibly auto lock or auto power or dish cleaned (depending on your model) if you follow the user manual.
happy to take you through a possible cause of the problem if you post answers to my questions above.
Jan 18, 2010 | Fisher and Paykel 23 in. DD-603SS Built-in...
Flashing yellow arrow / dashboard. What does this
this indicates an automatic gearbox problem associated with the winter mode switch
does your car drive ok or are you stuck in ultra low gear with a max speed of about 10mph??
Dec 26, 2009 | 1994 Volvo 850
HI my fiser and paykel dishwasher is flashing f1 and is showing a spanner whay does this mean
The F1 error means a flood switch has been activated in the drawer. The spanner means you need to call a technician.
The possible causes are that the solenoid that controls the water inlet does not shut off or the sensor that detects the water level is not working. Also it is possible the water pressure is not optimum for the setting on your unit.
Nov 05, 2009 | Fisher and Paykel 23 in. DD-603SS Built-in...
Fisher and Paykel 23 in. DD-603SS Built-in Dishwasher Logo
623 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
