Question about Epic 425 Mx Treadmill EPTL88105 !
Manual to trouble shoot/run diognostics
Want to recalibrate machine--want instructions on how to enter maintainance mode and perform updates/solve problems etc
  • Steve T. Jan 26, 2013
    What if you get a "UEr" display? Also a 100 in the calories window
    President:
  • Epic Master
  • 832 Answers
These units only have a calibration mode. The High end units generally will have that. If this is a Epic Then this calibration procedure should work.
Press the Stop and the Speed Up keys down while inserting the safety key. Press the Stop key one time. The Time window should read EP:2P. Some newer models may also say FP, Pass, or the like. This means that it passes the EPROM test. Press either incline key and the incline will calibrate automatically. BE CAREFUL, THE TREADMILL WILL RUN AT FULL SPEED IN THIS NEXT MODE! DO NOT STAND ON THE WALKING BELT. Press the Speed Up key and hold it down until 85 is shown in the Distance window (some models may show the 85 number in another window). If the top speed of the treadmill does not match the displayed speed on the computer console, adjust the max speed potentiometer (pot) on the motor control board. This is the board that the red and black motor wires connect directly into in the motor area. The Max Speed pot is clearly labeled. The max speed potentiometer is a small square with a movable center and is located near the three small speed wire connections labeled H, W, & L and is on the same edge of the board and the red and black motor wires are located. Using a small insulated screwdriver adjust this potentiometer clockwise to speed up and counter-clockwise to slow down the max speed of the treadmill. A tiny turn of this potentiometer will make a big difference in speed so be careful when making adjustments. It is not important to get the speed set exactly at the max speed of the treadmill but do make sure to get the speed within .2 MPH of the max speed of the treadmill. For instance if the max speed of the treadmill is 10 MPH, make sure to have the speed set between 9.8 MPH and 10.2 MPH. Some models have a 12 MPH top speed, so please check your manual if you aren’t sure. THIS IS A VERY IMPORTANT STEP BECAUSE YOU WILL GET AN ERROR MESSAGE IF THIS STEP IS SKIPPED. After completing calibration of the speed, press the Speed Down key. The treadmill will automatically return to 0 MPH. Please allow the unit to stop completely before continuing. Press the Stop key once and remove the safety key.
Posted on May 31, 2010
I have a creative vision 5.0 sewing machine and it will not enter the embroidery stitch out mode. Why?
Are you using the touchscreen? It may need to be calibrated. The adjustment is found in the setting menu. Are you having trouble with any other parts of the touchscreen? If yes, recalibrate it.
May 04, 2015 | PfaFF Sewing Machines
I have a Samsung top load washer model number wa476dshawria1 and it goes almost through entire cycle and then starts flashing dc, I have already replaced pump and it seemed to work fine, how to I...
do not believe there is a recalibration but here is a link to the manual Samsung WA476DSHAWR A1 Trouble Shooting Guide User Manual Ver 1 0 English...
Mar 02, 2015 | Samsung Washing Machines
My Bunn VPS Coffee maker is not flowing properly, can you provide me with instructions on how to fix this problem
Hello Kate,
Thanks so much for choosing my ad to help you. I am a Bunn Expert, so I can help you out here. Your problem appears to be a descaling issue. In other words needs to be cleaned, I am giving you the complete manual to download in pdf format for everything you need to completely maintain your machine and to trouble shoot any future problems as well. It will tell you step by step how to clean your machine as well as parts if needed and the schematics of the machine.
http://www.bunn.com/pdfs/commercial/manuals/10053.0000.pdf
If you found this was helpful and this had solved your problem, some nice words with a nice rating will be appreciated. Thanks again, Mike
Nov 03, 2011 | Coffee Makers & Espresso Machines
I installed a rompaq update on the laptop and it stopped working. what do i do? the laptop is so dear to me. pls help.
if the laptop was working perfectly before you installed the rompaq update, then it means the rompaq is the cause of the problem.
You need to perform a system restore in order to undo the installed rompaq.
Run your system in safe mode and perform the system restore.
To run system in safe mode, Turn on the computer and immediately, start pressing F8 constantly till a windows booting option shows up. Use the arrow key on your keyboard to select safe mode and press enter, then wait for the windows to load completely.
After the computer and successfully booted in safe mode, go to:
Start > All programs > Accessories > System tools > System restore.
Read and follow instructions. System will restart during the restore process.....
After that try again and observe of your laptop will function/work properly/normally.
Please let me know if this doesn't solve your problem so that I can help you further.
Regards.
Jun 12, 2011 | HP Compaq Evo Notebook N410c
Thread from bobbin is not coming up and stitch is not proper
Visit this website http://www.singerco.com/accessories/manuals.html
enter in your model number and download the manual for your machine, threading issues usually either bobbin not in correctly, thread not in tension or machine incorrectly threaded, so review the manual threading instructions and follow them to trouble shoot your machine.
May 23, 2011 | Singer Sewing Machines
My canon photocopy machine displays an error code presenting as (E 000602 - 0003)Please help me solve this problem.
Hi these means that you have HDD trouble, and it needs to be changed and upload the system on it - CALL SERVICE.
Aug 19, 2010 | Canon Office Equipment & Supplies
I can not receive a fax
Hi there, Fax machines are still in common use today despite the widespread adoption of computers along with their multiple communication tools, including e-mail and social networks. Fax problems can include trouble receiving faxes, dialing issues, faxes not printing and poor print quality. Performing periodic maintenance can help with fax problems. Check any visual indicators for trouble. Many fax machines have a display panel and use it for reporting error messages. Often the messages are in plain text and can be understood without referring to the instruction book. Refer to your fax machine'smag-glass_10x10.gif instruction manual for any numeric error codes.
  • Step 2.Replace the cables. In particular, replace the telephone line cable that runs from the wall to the fax machine. The plugs can become lame, and the wire itself can break inside, providing no visual indication it's broken.
  • Jul 31, 2010 | Sharp UX-B750 Inkjet Fax
    I hav a sansa e260 player it was working just fine until recently the screen is just blank and only the ring glows .my pc doesnt recognize the device please help
    Download the converter after you run the link below ....Put check next to converter/firmware update/Manual download...Go to your start menu programs go to sansa choose Sansa updater follow instructions.......(http://mp3support.sandisk.com/sansa/Installer/1082/SansaUpdaterInstall.exe) here is the link After installation connect your sansa......
    Also make sure you are connected to a 2.0 usb the back of the computer is best (the motherboard2.gif).... USB mode located on the sansa if asked to change to MSC goto menu press enter scroll to settings press enter scroll to usb mode press enter scroll to msc press enter press menu.....Connect should auto start sansa software..... Sansa software/driver Updates firmware follow instructions Downloads manual Downloads converter
    Set sansa to recovery mode, Start the updater plug the sansa into the computer, unplug when told sansa, should restart (Lock sansa press and hold rec and menu until recovery begins)
    Reset All
    NOTE: THIS IS AN ADVANCED OPERATION AND RESTORES ALL SETTINGS
    TO THE FACTORY DEFAULTS. NORMAL USERS ARE NOT RECOMMENDED
    TO PERFORM THIS OPERATION!
    If your device freezes up press the Menu button and hold for 15 seconds.
    This is like a power down of the device. Once you perform the reset, the adjustments you made during last operation
    will be gone.....
    Go to my computer click on folder scroll to sansa and open the media folder and open each sub folder and delete manually then delete the folders Right click on your sansa then format a couple of times hope this works
    Oct 22, 2009 | SanDisk Sansa e260 MP3 Player
    CANNOT GET INTO THE MEMORY CLEAR SCREEN OF XEROX WORKCENTER M15
    Once you press menu #1934 you have to then press the machine status button then scroll to maintenance, then scroll to clear memory. Once you do that repeat entering the tech mode, press machine status, maintenance and perform a shading adjustment with 5 pieces of paper on the glass, that will recalibrate the scanner.
    Feb 25, 2009 | Xerox WorkCentre M15i Laser Printer
    Epic 425 Mx Treadmill EPTL88105 ! Logo
    664 people viewed this question
    Top Epic Exercise & Fitness Experts
    Matt Olenzek
    Matt Olenzek
    Electro Med Services...
    L Pfaff
    L Pfaff
    Are you an Epic Exercise and Fitnes Expert? Answer questions, earn points and help others
