Hello, my lcd "goodmans LD3265D" is dead at all i have check the inside and plug fuses and they are ok , can be the power module ?
  • RUI MOREIRA
    RUI MOREIRA May 30, 2010
    thank you very much , is allways a good thing to have an opinion from a guru :)
  • 10,594 Answers
Yes, if power indicator on tv front does not lit after plugging tv in wall socket then its power module that need to be replaced.
Hope this helps.
Thanks.
Posted on May 30, 2010
Power light is off. won't turn on.my washing machine completed a load of washing then i put another load in and it won't do nothing
hello you would have checked the fuse in the plug if ok then check the glass fuse inside the washers power supply if it's blown the make sure you use the same rated fuse. beware if it blows again then you have a dead short hope it helps
regards
shaun
Jan 23, 2011 | Washing Machines
We have a whirlpool AWM6140/3 1400 spinspeed when I turned machine on it fused the supply at the fuse box not the plug,now it won't turn on
hello because there a dead short somewhere the fuse inside the washer power supply could have blown if this ok you will need to check wiring if ok then there could be a fault with the power supply board hope it helps
regards
shaun
Jan 08, 2011 | Whirlpool AWM6140 Front Load Washer
Machine is completely dead. Fuse and plug ok.
hello, have you checked the glass fuse inside the washer's power supply ,but beware if you put another one in and blows again then you have dead short , make sure you use the same rated fuse
hope it helps
regards
shaun
Oct 11, 2010 | Hotpoint Washing Machines
Why does mt goodmans tv ld3265d keeps turning its sel*** on standby its getting worse and driving me nuts
i had same tv and bought new power supply on ebay and no more probs i suggest u do the same mate
Jun 15, 2010 | Televison & Video
No lights, no power, whatsoever when plugged in
hello obviously you've checked the fuse in the plug if thats ok it could have blew the fuse inside the washer it will be on the power board glass type . beware if you put another 1 in and blows again then there's a dead short someware good luck
regards
shaun
May 29, 2010 | Kenmore HE2 Plus Front Load Washer
Dead tv ,plug fuse is ok,
hello have you checked the glass fuse inside the it will be power supply .beware if you replace it and blows again then you have dead short circuit also make sure you use the same rated fuse . the value will be at the end of the fuse or on the fuse holder on the circuit board
regards
shaun
Apr 07, 2010 | Samsung HCM5525W 55" Rear Projection...
Goodmans crt tv dead
there is another supply missing from your power supply, chec your components on that power supply a ht of 90volts is missing,
check all active components like transistors,diodes and resistors with very small values,
if you go through you are going to win that problem, ok.
Apr 03, 2009 | Goodmans 257NS 20" TV
No picture and sound from my LCD 32
ya kunle bawo ni ? are u a technician? well do this .check your power moudle outputs if all are ok(no voltage drop, no fluctuation & no burst or swolling electrolytic capacitor). disconnet your backlight inverter supply from the power moudle.plug your speaker & antenal firmly. plug your tv & power on, scrol tru your channels, if sound. your backlight inverter is bad. if all still remains dead ur analog/digital converter(mianboard) is bad
thanks. o seun.
Dec 13, 2008 | Goodmans W280NS Television
Goodmans 27 inch LCD
Sounds like the power surge may have blown the fuse in the TV. You can replace the fuse and see if that works. If not, more damage to the power supply unit may have occurred.
Jun 09, 2007 | Goodmans W280NS Television
Televison & Video Logo
85 people viewed this question
Top Televison & Video Experts
Electro Med Services...
