Question about Lexmark X5650 ALL-IN-ONE PRINTER
I have a Lexmark X5650 all-in-one printer. The power supply port was pulled out from the back and now the printer won't turn on. Do I need to buy a new printer or can this be fixed?
  • Official Brand Answer
  • 3,344 Answers
I strongly recommend you contact Lexmark Technical Support for assistance with that. If the problem is just the power supply of the printer, Lexmark Technical Support can send you one for free. Hope this helps. If you need more assistance, leave a comment and I'll get back to it. Thanks.
Posted on Jun 02, 2010
I installed new cartridges (Lexmark brank both black and color) and my printer won't work now.
A quick fix for most communication errors can be achieved by resetting the printer and/or rebooting the PC. Simply disconnect the printer from your computer (if USB connected)> reboot your pc > unplug and re-plug the printer into the power source to reset it. When the printer turns on, reconnect it to your computer (if USB connected). Then try to print again once the computer fully recognizes the USB connection or when the WiFi light on the printer turns solid green (if WiFi connected.).
If that doesn't help, try the steps below:
  1. Disconnect the USB cable connecting the printer from your computer.
  2. On your computer, go to Control Panel > Printers and Faxes.
  3. Delete the Lexmark print object.
  4. Reboot computer.
  5. Re-brick your printer by pulling out the power supply - black box where the power cord is plugged into on the back of the printer, and re-plug after 30 seconds.
  6. When the printer turns on, reconnect it to the computer.
  7. Wait until your computer fully recognizes the USB connection. To check, go to Control Panel > Printers and Faxes. If you see a new Lexmark print object in the list, try to print a document to verify that the problem is fixed.
Mar 15, 2012 | Lexmark X5650 All-in-One InkJet Printer
Printer will not print
If unplugging and re-plugging the printer into your computer doesn't help, try the steps below:
  4. Reboot computer.
You may also try to update your printer driver by visiting the Lexmark website at http://bit.ly/eVzv1x. Select your operating system, download and execute the file.
Feb 14, 2012 | Lexmark X5650 All-in-One InkJet Printer
I just bought ink cartridge and says ink low on my lexmark x5650 so i just bought ink cartridges for my hp 4140 and it wont work, is this a cproblem with my computer and not my printers? 2 printers do
As far as the Lexmark printer is concerned, try the steps below:
The problem could be due to a communication failure between one of the printheads (cartridges) and the All-In One (AIO) or by a short in one if the printheads. Please follow the steps below to identify and fix cartridge issues:
  1. Make sure the printer is on.
  2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-In-One is busy. Note: If the carrier does not automatically move to the center, turn off the printer or unplug the printer from the power source and then carefully slide the carrier to the center.
  3. Remove both cartridges from the carrier.
  4. Close the printer cover.
  5. Re-brick your printer by pulling out the power supply - black box behind the printer where the power cord is plugged in to, and re-plug after 30 seconds.
  6. When the printer turns on, reinsert one cartridge first. Close the printer cover and check for any errors.
  7. If no error appears, reinsert the other cartridge. Close the printer cover.
  8. Replace whichever cartridge is causing the error to appear with a new genuine Lexmark cartridge. Try to print a document again to verify that the problem is fixed.
Feb 12, 2012 | Lexmark X5650 AllInOne InkJet Printer
Lexmark x5650 cannot retrieve application list
  4. Reboot computer.
Jan 16, 2012 | Lexmark X5650 All-in-One InkJet Printer
My printer want scan to pc
printer wont scan to pc - Lexmark X5650 ALL-IN-ONE PRINTER
Dec 05, 2011 | Lexmark X5650 ALL-IN-ONE PRINTER
I cannot get my Lexmark 5600-6500 to turn on
Try to unplug the power adapter from the printer.
Then unplug the power cord from the power outlet. Wait at least 10 seconds before re-plugging the power cord into the power outlet in the wall (bypass any power strip) and the power adapter into the printer. This will give enough time for the printer to reset itself. If printer won't automatically turn on, press the power button. If that doesn't help, please contact Lexmark Technical Support Center for additional assistance.
Jun 28, 2011 | Lexmark X5650 All-in-One InkJet Printer
My computer won't boot up while my Lexmark X5650 is connected and turned on. Dell computer running XP pro. When I turn the printer off, it will boot.
Try moving the USB cable to another usb port. Ports can go bad; or if the printer interface is bad; it will cause this type of problem. If you want, you can try another cable too. In the end, you may end up having to replace the printer. But, certainly try another port first.
Oct 19, 2010 | Lexmark X5650 All-in-One InkJet Printer
Entered power saver mode how do I get it out of that mode
The power saver mode is a Lexmark X5650 feature that allows you to save electricity when the printer's not being used. That can be configured in the Device Setup in Settings. Adjust it on how long you want the printer to stay on before going on power saver mode but it can't be turned off. When the printer is on power saver mode, press and release the power button to power back on. Hope this helps.
Jul 15, 2010 | Lexmark X5650 ALL-IN-ONE PRINTER
My printer does not turn on?iam pushing the on button.
Unplug the power supply from the printer. The power supply is the black box behind the printer where the power cord is attached. With the other end of the power cord still plugged in to the power outlet, the power supply of your Lexmark X5650 should have a green light on around the silver contacts. If not, you might have a defective power supply. If that's the case, I suggest you contact Lexmark Technical Support for the power supply request. If there is, plug it back in the printer all the way through and in a correct position. Printer should power on automatically, otherwise, press the power button. If printer is still not powering on, it might be defective now. Contact Lexmark Technical Support for further troubleshooting.
May 11, 2010 | Lexmark X5650 All-in-One InkJet Printer
I have a paper jam in my lexmark x5650
hi try firstly to open the paper mount and then put ur hand to see if there is a paper jam there if not, try to open the color cartridge mount and remove the colour cartridge and install it back again if not, try to turn it off and on again.
Jun 07, 2009 | Lexmark X5650 All-in-One InkJet Printer
Lexmark X5650 ALL-IN-ONE PRINTER Logo
241 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
