Question about Umax AstraPix PC210 Webcam
Tengo una web cam gigaware pero mi cpmputadora no lee el cd de instalasion
    President:
  • 8,637 Answers
Copy this site and paste it in your web browser address bar and hit your enter key.
http://www.radioshack.com/uc/index.jsp?help=yes&page=software
It has the Description and Model number.
Then download the driver for your camera and install it as below.
Disconnect the Camera from the USB port and reinstall the CD or Downloaded software program. When the program asks you to connect the camera to the USB port, do so and it should work.
Then to use it on the Web, do this.
Web Camera's have to be setup on the program they are to be used with. Just installing the camera on your computer does not set it up to broadcast on messengers or Skype.
Each program has Options that have to be setup in order for the Audio and Video to function properly.
A. Skype Setup:
After downloading and installing Skype
http://www.skype.com/intl/en-gb/download/skype/windows/beta/downloading/
set it up as follows:
Go to Tools, then Options, and click on Audio Settings and set the Microphone and Speakers to the computer Audio Card.
Then click on the Video Settings.
The camera, if Installed Properly, it will come up and show a video picture.
Then, on the bottom of the page click save.
The camera and audio should function properly. Your friends and Family will now be able to see and hear you.
B. Yahoo Setup:
After downloading and installing Yahoo Messenger
http://www.soft32.com/download_30.HTML
Go to Messenger at the top left and click on it.
Next go down to Preferences and click on it.
Next Calling and Devices on the right and set the Microphone and Speakers to the computer Audio Card.
Next go to the Test Audio section and (in blue writing) click on "Open the call setup assistant" and follow the instructions on the left window.
C. Windows Live Messenger:
http://download.live.com/Messenger
After you start Windows Live Messenger, expand the view by clicking on the square on top left next to the red X.
Then on the Windows Live messenger window on the right side, click on " "Show Menus." And then click on "Show the Menu Bar".
Next go to the Menu Bar on right side, click on " "Action."
Go to "TOOLS" and click "Audio and Video Setting" and follow the instructions.
NOTE: Your audio and video should work. Enjoy.
When done both the Audio and Video will function properly so you can chat and see family or friends you are connected to.
D. AIM (AOL) Messenger:
http://dashboard.aim.com/aim
On the VIM sign-in window click on Edit.
Then click on Settings Enhanced IM.
Next click on Enhanced IM.
Then click on Audio Video.
The Audio and Video portion has drop downs so you can select the proper audio card and video camera installed in you computer.
The Audi Video drop downs are
Microphone
Speaker
Camera
The audio and camera should function now.
Additional information to use with VIM settings.
Adjust Your Audio and Video Settings:
In order to adjust your audio and video settings, please follow the steps given below:
1. Click the Audio and Video Settings button directly below the My Buddy or My Camera window. If you are currently
Participating in an AOL Live Video IM session, a message will display: You must disconnect the current AOL Live Video IM
Conversation before running setup. Would you like to disconnect now? Click the Yes button.
2. The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working
Properly. Follow the on-screen prompts.
Notes:
The first time you use AOL Live Video IM, a message will display: Would you like to first check your audio and video settings? Click the Yes button.
The Audio and Video Tuning Wizard will appear to help you verify that your camera, speakers and microphone are working properly.
images in AOL Live Video IM may appear reversed, or as a mirror image (text may appear backwards) when you look at your own camera feed or at the
Picture-in-picture (PIP) display.
After making the settings your ready for a chat and video talk with your Family and Friends.
Hope this helps. Bud
Posted on Jun 05, 2010
NO APARECE MI CAMARA WEB QUE VIENE INCORPORADA A LA LAP, COMO LE HAGO, DICE QUE NO SE ENCUENTRA O QUE ESTA OCUPADA O QUE NO TENGO, QUE DEBO COMPRAR UNA Y ESO NO ES POSIBLE, POR QUE SI TENGO CAMARA WEB,...
que hago tenia instalado en mi pc oficce 2003lo cambie por 2010 pero cuando quiero reproducir una presentacion de power poit dice que no se encuentra el punto de entrada del procedimiento except handler 4 common en la biblioteca de vinculos dinamicoas de msvcrt.dl que devo de hacer por favor quien me puede ayudar
Feb 24, 2011 | Computers & Internet
Tengo problemas con una batidora hobart. hl 600. lellega voltaje a la tarjeta de controles ( velocidad y tiempo) pero no enciende nada y no tengo control de el arranque y paro.
Hola amigo, mi nombre es ramon, a mi me sucedio algo parecido, primeramente debes revisar los 24V Ca en la tarjeta, este es rectificado a 24v cd y 12 Cd quienes son los que alimentan el control, no te desgaste buscando en los interruptores de proteccion, el display debe encender autamaticamente cuando la maquina esta energizada, esto es un defecto al parecer comun en estas maquinas, esta tarjeta tiene un Circuito integrado que alimenta a relay C3 y este a C2, hay varios relay de control los cuales pueden o no activarce pero es fundamnetal que arranque el microprocesador de esta tarjeta, quizas con un poco de tiempo puedas reparar esta tarjeta revisando el relox de control y todos los circuitos de control para el funcionamiento de la misma, hubiera que buscar los datos de estos y hacer una ingenieria inversa para detallar el funcionamiento de la misma, pero para que sea mas facil revisa el cable del puerto de comunicacion entre la tarjeta de mando y el variador de frecuencia, si este esta bueno teniendo continuidad, Ah en este cable hay una linea de color ***** que no se utliza esta solo conectado en uno de los estremos, si todo esto esta bien sustituye esta tarjeta por una nueva la misma esta averiada y si no tienes mucho conocimiento en electronica no la podras reparar o poco tiempo que es lo que sucede a mi, que tenga suerte.
Ramon
Aug 19, 2010 | Hobart HL600 Legacy Stand Mixer
No tengo el disco de la camara genius e-messenger112
mi pc no lee el cd de instalasion de mi camra web genius .mensseger 310
Dec 24, 2009 | Genius VideoCAM Messenger Webcam
No tengo el cd para intalar mi camara y quisiera consegirlo
tengo una camara marca gigaware, tengo el cd pero no instala en mi pc
Sep 28, 2009 | Radio Shack VGA PC Camera Webcam
Instalacion de camara gigaware
Hola,
Descargue el primer, si es para el Windows XP, descargue el segundo uno, si es para el Windows Vista.
Y hay instrucciones para el webcam, pero ellos son para inglés :(
Gigaware VGA PC Camera (Original Drivers for Windows 98SE/ME/2000/XP (11.9 MB))
Gigaware VGA PC Camera (Vista Standard WHQL Driver (14.7 MB))
Gigaware VGA PC Camera (User's Guide)
¡Buena suerte!
Chris (ziraffa)
Dec 28, 2008 | Radio Shack VGA PC Camera Webcam
Necesito ayuda .......
tengo una camara web marca cap y no tengo elo cd con el driver el codigo de la cam 49152-DM
Jul 23, 2008 | Computers & Internet
Tengo una lg webpro lic-200 y se me perdio el drivers por favor que hago
Hola, en http://www.mvredes.com/
en la seccion descargas/lg/network/drivers/multimedia tienes los drivers.
El modelo de tu camara es: LIC 300
Espero que te resulte de utilidad
Jul 12, 2008 | Computers & Internet
Problemas con la camara web
Hola soy nuevo en esto de los foros, tengo problemas con mi camara web 1,3m que viene integrada a mi Toshiba Satellite A215-S4807, tengo Windows Vista Home Premium, entonces mi camara web casi nunca logra funcionar con el msn e incluso el programa que trae ("C:\Program Files\Camera Assistant Software for Toshiba\traybar.exe.exe") no funciona correctamente ya que a veces funciona y otras no... ahora ultimo no ha querido funcionar mas con el msn.
Quedo de ustedes y esperando sepan ayudarme.
Gracias de antemano. Carlos
Jan 25, 2008 | Computers & Internet
No tengo el progrma para instalar mi webcam
hola perdi el cd de instalacion de mi wed cam GENIUS LOOK 312P. como hago para instalarla??
Aug 23, 2007 | Genius VD3000022 Webcam
Umax AstraPix PC210 Webcam Logo
Top Umax Computers & Internet Experts
EKASYS IT SERVICES
EKASYS IT SERVICES
tdk1988
Are you an Umax Computer and Internet Expert? Answer questions, earn points and help others
