Question about Whirlpool Washing Machines
My Whirlpool/Kenmore Elite HE 3t washer is suddenly giving me an "F9" code occassionally when washing . What does that mean? I restart it and it runs. There is possibly a new noise when it pumps out before the rinse cycle
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. F9 error occurs if the Overflow contact on the pressure switch is closed for more than 60 seconds an Overflow condition will occur. In an Overflow condition, the Door will remain locked, and the Drain Pump will run constantly, even if PAUSE/CANCEL is pressed twice and the Display is cleared. You’ll need to unplug the unit and:
• Check the drain hose and make sure it is not plugged or kinked
• Check Wire Harness connections to the Drain Pump, Pressure Switch, and
Central Control Unit (CCU)
• Check/ Clean Drain Pump Filter of foreign objects
• Check for Drain Pump Failure
• Check the Inlet Valve for proper shut off
• Check the Pressure switch for proper operation.
Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on May 30, 2010
  • richard_smik May 30, 2010
    How do I check the drain/pump filter?
  • Rylee Smith
    Rylee Smith May 30, 2010
    Please click on this link and check its repair manual which will tell you how to check the drain pump. Please do accept the solution if the issue is resolved or post a comment for further assistance.
    Thanks
    Rylee
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    Cycle will not spin and drain properly near end of cycle. Keep getting F11 fail codes when I try resetting my kenmore elite HE 3t any suggestions?
    Hi Shaun, I just found (and watched!) a good youtube video which may help with your problem regarding the F11 code, link follows below.
    Trust this helps, best regards Alan
    Troubleshooting and Repairing the F11 Error Code in Whirlpool Duet Washer
    Feb 12, 2015 | Kenmore Washing Machines
    Kenmore Elite HE 3t steam washing machine shows a code of F71
    The F71 error code means "User interface heartbeat failure" to put that in simple terms what it means is,the touchpad/cycle selector is not talking to the main control board. To check to see why that code is being displayed ya would need to make sure that all the wire plugs between the selector and the control board are tight and in fully pressed in and making good contact at the respective connection point on the circuit board.
    If ya find the wire connections to be good and tight,ya would need to start the washer and if the drum rotates the cycle selector would have to be replaced. If the drum does not rotate the main control board would need to be replaced. oldtech2332_146.jpg
    Oct 20, 2011 | Kenmore Elite 45986 Front Load Washer
    I have a Kenmore Washer Elite HE 3t and I just started getting a code SUD and I do not have a manual so I don't know what this means. Thanks, Wendy
    Suds, it usually comes after the last rinse if too much detergent is used. Use less and make sure it's HE liquid like All or Tide liquid detergent.
    Feb 07, 2011 | Kenmore Washing Machines
    Kenmore Elite HE3T model 110 44932 200 I'm getting an F02 error code during the rinse cycle. I've lost my manual - pls advise thx
    Clean Out your Water pump filter if that is not dirty replace the water pump. f02 is Code for LD Long Drain something is clogging your water drain in the washer or your kids rock or pen got stuck and chewed up the blades on the water pump
    Jun 06, 2010 | Kenmore 44932 Front Load Washer
    I have a code that is 888 on my kenmore elite HE 3t. Does someone know what this means. How do i take off the capartment to check the wires?
    there are 3 screws in the back that will take off the whole top then you will see inside.is there any other codes?
    Mar 28, 2009 | Kenmore Elite 45986 Front Load Washer
    What does F9 mean on a kenmore elite washer and F6
    3-21-09 look at the gentleman site called "KC washer on now that is what is my continued problem now we are having enver ending issues with out of warrentee and replaced by sears many times the eniter panels: the ror codes are listed www. repair clinic.com and it listeed the sears or kenmore or whirlpool all the same manafacturersd if yuu iddnt know it under whirlpool trouble codes f9 is overflow condition check the drain hose
    check wire harness connectors to the drain pdump oressure switch & ccu control unit
    next clean the drain pump fil;ter of any objects ue shop vac to **** out water check drain pump the door is stsaying locked am i right? press cancel twice to clear the unit and unplug at this timedaniel440@verizon.net
    Mar 19, 2009 | Kenmore Elite 45986 Front Load Washer
    F 11 Error Code
    The door will stay locked if the machine did not drain properly. Try running a Drain & Spin cycle.
    Mar 17, 2008 | Kenmore Elite 45986 Front Load Washer
    Washing Machines Logo
    37 people viewed this question
    Dan Webster
    Dan Webster
    Gerry Harvey
    Gerry Harvey
