Question about Destroyit 4004 Shredder
Use of Mineral oil or Vegetable oil for shredder?
Can you use mineral oil, or vegetable oil to lubricate your shredder?
  • 86 Answers
Hi I am a shredder technician. Though it is not recommended you can use either as long as they dont gum up the machine over time. As this will cause you major problems. please leave feedback . Have a nice day. And good luck
Posted on Jun 03, 2010
Transmission oil not flowing from masterr cylinder to slave cylinder when bleeding
of course it won't be
transmission oil is mineral oil and brake fluid is vegetable base oil
no connection between the two systems
if you have been putting transmission oil in the brake or clutch systems, the rubbers will be expanded and n blocking all the holes and hoses
Dec 07, 2016 | Kia Cars & Trucks
Tip
How to keep your cutting boards from warping
To keep a cutting board in good condition never rub it with vegetable oil as it will eventually go rancid. Most cutting board conditioners seem to be top secret as they will not divulge what they have in it. Upon researching the internet i discovered that you could use paraffin or a food grade mineral oil. Mineral oil although a byproduct of gasoline manufacture is not toxic as almost all other petroleum products are. Brake fluid and transmission fluids are based off of mineral oil... but it is fine orally used for medical purposes as well. Cutting boards need to be turned over periodically and oiled monthly especially as the weather turns to wet weather... or as it goes back to cold dry air.
on Oct 19, 2013 | Cooktops
What kind of lubrication oil for paper shredders
Mineral oil is probably the best choice. You can also use "Paper Shredder Oil" which is probably the same thing but for more $$. Vegitable oil generally works well for lubing things, but have never tried it on a shredder.
Jan 08, 2014 | OfficeMax 0M96431 Shredder
What massage oil is best for using on babies?
You can pretty much use most mineral or vegetable oils for massaging your baby. Some people prefer to use safflower or grape seed oils as they are high in linoleic acid which helps protect skin.
If your baby has sensitive skin, it's probably best to avoid olive oil or sunflower seed oil as they can cause irritation.
Mar 04, 2013 | Health & Beauty
Are there any treat that help dealing with hairballs?
In order to lessen your cat's hairballs you should look for treats that contain petrolatum, mineral oil, vegetable oil or an equivalent intestinal lubricant.
Aug 07, 2012 | Cats
Paper keep stopping.I have to turn off and on the power 2 or three times before I could complete just one page of paper.Thanks
Have you lubricated the shredder recently? You can get special sheets that lube the shredder by shredding them, or you can get special shredder lubricant at the office supply store, or you can just use vegetable oil.
Feb 07, 2011 | Office Equipment & Supplies
I have an older version of JS55 strip shredder. I shredded some things that had glue on them. Now it jams a lot. Can I use olive oil on the shredder slots?
Remember that vegetable oils go rancid quickly; they're meant for eating and not industrial lubrication on a regular basis. The use vegetable oil trick is actually intended for people who use their shredders OFTEN, not OCCASIONALLY. I have a giant bottle of canola oil at the office for the big shredder, I use the branded oil at home. The amount of shredding most offices do is enough to warrant using vegetable oil since more than likely by the end of of a typical maintenance cycle, the oil is long gone from the blades and feeding mechanism.
Do not use olive oil, corn oil, cottonseed, peanut, palm, or ANY vegetable oil with an odor. Unless you want your shredder smelling like food, stay away from any vegetable oil with a distinct odor. Canola oil is the best substitute for branded oil. Also look for lower grade canola cooking oil, the ones you often find in thrift stores or 99 cent stores. It should look more "watery" than viscous.
Dec 31, 2010 | Royal JS55 (Strip-Cut) Shredder
Model ho-0218 at a given time can the mineral oil be refilled
hi , i have to ask why would you want to refill it , if the heater is leaking its rarely econamical to fix the leak and repair it , most of the oil heaters ive worked on were filled with vegetable oil .
Oct 15, 2009 | Pelonis WM-HO202C Oil Filled Radiator...
Destroyit 4004 Shredder Logo
361 people viewed this question
Top Destroyit Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Destroyit Office Equipment and Supply Expert? Answer questions, earn points and help others
