Question about RCA T25061GY 25 in. Combo
Wont stay on
Turn it on and it shuts back off within 5 minutes
    President:
  • 1,099 Answers
The power light may be flashing or if you are runing with a series light bulb it may be cycling on and off continuously. There may be a chirping or clicking sound from inside the set. (Note: using too small a series light bulb load during testing for the size of the TV may also result in this condition.)
If there is a low voltage regulator or separate switching supply, it could be cycling on and off if the horizontal output, flyback, or one of its secondary loads were defective.
Does this TV have a separate low voltage regulator and/or switching power supply or is it all part of the flyback circuit? For the following, I assume it is all in one (most common).
Some simple things to try first:
Verify that the main filter capacitor is doing its job. Excessive ripple on the rectified line voltage bus can cause various forms of shutdown behavior. An easy test is to jumper across the capacitor with one of at least equal voltage rating and similar capacitance (make connections with power off!).
Use a Variac, if possible, to bring up the input voltage slowly and see if the TV works at any point without shutting down. If it does, this could be an indication of X-ray protection circuit kicking in, though this will usually latch and keep the set shut off if excessive High Voltage were detected.
Posted on Jun 01, 2010
Sunbeam heater SQH310 keeps shutting off when it is on 2, what do I do?
If you have the same heater i do then in between the elements at the bottom there is a safety swith that bends when it heats up and breaks the connection Dont mess with it plugged in it will shock the hell out of you but if you bend it down it wont be able to lift off the circut and will stay running untill you turn it off
Oct 26, 2012 | Sunbeam Heating & Cooling
Does not shut off
with the car running the cap should be on. there is an adjuster near the terminals. be ready to adjust. run the car for a minute and then sut it off and adjust it so just turns off within a minute of sutting the car off. it may take a couple tries to fine-tune it. it now, should automatically switch on and off as the voltage changes between running, and resting.
Jun 21, 2012 | Lanzar Opticap 50 5 Farad 24v Oval...
Why does it turn off by itself? it turns on fine
if the engine light stays on then you can have the codes checked i would change the fuel filter its easy and cheap.
Dec 09, 2010 | 2005 Nissan Armada
DC 17 UPRIGHT BRUSH MOTOR WONT STAY RUNNING. TURN
have a look at the filters first as it sounds like you blokeage
Oct 31, 2009 | Dyson DC17 Animal Bagless Upright Cyclonic...
My Magnavox digital converter box shuts itself off every 5 minute
Check that you have not got an auto power off setting on. Check that the aerial connections are good. That the signal is strong from the stations it is picking up. Weak signals can cause the box to shut down.
It the box is very hot when it shuts down, you might have a fault on it.
Apr 04, 2017 | Philips Magnavox M61117 (DBM61117)
Laptop shuts down at random times it sometime shut dowm within 5 minutes i use or can stay on allday but now it shuts down within like 20 minutes of use.please help
I THINK ANY VIRUS MAY BE IN YOUR SYSTEM. PLEASE FULL SCAN YOUR COMPUTER THROUGH A GOOD ANTIVIRUS. IF PROBLEM REMAINS SAME THEN YOU HAVE TO CHOOSE FORMAT WINDOW AND THEN REINSTALL WINDOW.
Sep 30, 2009 | Sony VAIO VGN-AR630E Notebook
My RCA HD50LPW175yx7 is blinling five(5) times and then shuts off
i have the same t.v. the owners manual says "if the light blinks 5 times, pauses, and blinks again 5 times, the lamp is trying to turn on.If the t.v. does'nt turn on after 5 minutes and the light blinks steadily for 1 minute , one of the following is possible: lamp door is open , lamp is dead , or the power supply within the t.v. needs service.
Nov 29, 2008 | RCA HD50LPW175 50" HDTV
Lennox Gas Furnace that turns on and shuts off in minutes
After troubleshooting like mad, I found that the flame sensor (rod that sits within the flame) was fouled with carbon on the surface. I believe this shields the rod from proper heat detection and the sensor reports that there is no flame and to shut off the gas valve to avoid explosion. Once I pulled out the rod and cleaned it with a wire brush, I have no problem whatsoever--fixed.
Nov 10, 2008 | Heating & Cooling
My samsung projection television model pch521r wont stay on
when the set does come on do you notice any thing odd in the picture or sound of the set.
Aug 19, 2007 | Samsung PCH521R 52" Rear Projection...
Televison & Video Logo
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
