Question about Microsoft Xbox 360 Console
I am unable to connect to the internet with my xbox but can with a pc or laptop, the router has been reset just to be sure it is not that,it has been working fine for the last 2 yrs any ideas what is wrong?
    Scholar:
  • 121 Answers
Check the cable you're using. If that doesn't solve your problem, then maybe the modem inside the Xbox is screwed.
Posted on Jun 03, 2010
I canot connect to the internet but my laptop detect my router
Make sure your modem is plugged in, first and foremost.
Make sure your modem is connected to your Router with the Ethernet cable.
If you're unable to connect still, do a reset on both the modem and the router at the same time. Unplug both, wait for 30 seconds and plug them back in again.
If you are still unable to get an internet connection, right click your wireless connection in the toolbar on the bottom left (Assuming you're using a PC). Click "diagnose" and it will run through your connection, to identify the problem.
Follow the instructions on screen.
If you are still unable to get a connection after trying these, contact your ISP and have them reset the modem and walk you through wireless setup for their particular system.
Thanks!
Hope this helped!
Jun 03, 2011 | Computers & Internet
I am able to connect to the wireless router, but I am unable to access the internet. This is a problem with the Sylvania netbook only..i am connected to the internet on another laptop. Please...
The router did not assign an IP address to the netbook ... so first try this
try resetting the router (unplug for a few minutes) next --be sure the wifi switch is enabled on the netbook---next---go to CONTROL PANEL>NETWORK CONNECTIONS--right click oin your wifi card and choose properties--highlight INTERNET PROTOCOL and choose properties and be sure "OPTAIN IP ADDRESS AUTOMATICALLY" is checked--Does the laptop "SEE" the router?
You will need your SSID to logon to the router(internet)
If this was helpful, please indicate so, if not -comment back so we can dig further to resolve this
Dec 28, 2010 | Sylvania G-Netbook
My router can no longer connect to my xbox live. It began as a problem where i had to restart my modem in order to get connection on either my laptop or xbox but now, only my laptop can be connected to the...
you need to register the router to your internet provider so that the modem will always give an internet connection to the router even if the router will be reset.
from that the xbox should follow through and connect to xbox live if you have an open NAT type.
Sep 14, 2010 | Linksys WRT160N Wireless Router
How to connect xbox 360 to the internet with laptop
I'm not sure if you can connect an Xbox 360 to the internet with a lap top. What I would do, is get a router (guessing that you already have one). But if you don't, it's basically a splitter for Ethernet cords. You plug the router into the Modem (the box that makes the internet), buy an Ethernet cord, plug it from the router to your Xbox and you should have internet. Or, you can get a wireless router, and get a network adapter for your Xbox to get internet wireless. But I don't think you can just get internet from your laptop.
Jul 10, 2010 | Microsoft Xbox 360 Console
I have a Cayman 3347w wireless router and I am trying to use one of the wired slots to connect my xbox 360 to the internet. the xbox will not connect. is this router xbox compatable?
Please try the following steps below;
To make a router connection to Xbox LIVE:
  1. Before you connect any cables, turn off your router, modem, PC, and Xbox 360 console. (Unplug your modem from its power source to turn it off.)
  2. Connect one end of an Ethernet cable to the Ethernet port on your modem and the other end to the Ethernet input port on the back of your router.
  3. With another Ethernet cable, connect one end to one of the router's Ethernet output ports. Connect the other end to your PC's Ethernet port.
  4. With the third Ethernet cable, connect one end to another of the router's Ethernet output ports. Connect the other end to the Ethernet port on the back of the Xbox 360 console.
  5. Turn on your modem, then your router, then your PC.
  6. Make sure your PC can access the Internet. If not, you may need to configure the router for Internet access. For help configuring the router using your PC, check the instructions that came with the router.
  7. Turn on your Xbox 360 console and sign in with your profile.
  8. If this is the first time you've turned on your Xbox 360 console, see Create Your Gamer Profile to get started with both the Xbox 360 system and Xbox LIVE play.
If you're unable to connect to Xbox LIVE, you can try to diagnose the problem right on your console. Go to My Xbox and open System Settings, then select Network Settings (setup XBOX using Automatic Configuration DHCP), Test Xbox LIVE Connection.
Hope this helps!
Mar 28, 2010 | Netopia Cayman 3347W-Ent Wireless Router
Cant connect to internet using internet stick
The internet stick you have would be a USB device which is not supported by Xbox 360, you can connect to Xbox 360 wirelessly or through a wired connection
One way of connecting wireless internet is through the ethernet cable to a laptop paired with your wireless router, or you would have to buy a Wi-Fi adapter for Xbox 360 which retails around $90.
Since Xbox 360 does not have a software like a PC, it is unable to recognize the USB internet stick you have as a internet connection, it may probably end up showing it up just as a USB device on the system settings menu on the Xbox 360 dashboard
Jan 22, 2010 | Microsoft Xbox 360 Console
Network Issues - XBox 360
make sure you having network sharing enabled on your computers
Jan 22, 2009 | Microsoft Xbox 360 Console
Linksys wrt54gs router and Xbox live
make sure that internet connection working fine first..if it is connect you xbox via wired or wireless(if wireless, make sure that you connect to your own wireless network and enter the wireless security if there is)...check if you can get an ip address, better set to obtain the ip address and dns of your xbox, if all set and still unable to access internet, access the linksys router setup page by typing 192.168.1.1 on the address bar of your internet explorer, when pop-up for username and password type admin under password, leave it empty for the username. Click administration tab and disabled UPnP. Check if your X-BOX working fine. Hope this help you.
Sep 29, 2008 | Linksys Wireless-G WRT54GS Router...
UNABLE TO FIND IP ADDRESS
I think the Ethernet cable needs to run directly to your router/modem, you can't bypass it through a laptop (as far as I know!)
Nov 18, 2007 | Microsoft Xbox 360 Console
Wireless modem not connecting to everything on the network
this sounds as if either the router is not set at enable DHCP which gives your pc's and x box an automatic assigned ip address, so check in the routers settings via your web browser that DHCP is enabled, also go to your wireless network card and go to the properties, select the TCP/IP line, click properties again and make sure automatically obtain ip address is ticked, ok and close window. Do the same with the Xbox in the network settings and make sure that automatically obtain ip address is highlighted and automatic DNS is set. Lastly make sure non of the pc's network setup is set in a way that other pc's connect to the internet through this computer type set up, they should all be set up using the network wizard using the 'this computer connects to the internet through a gateway' setup, which is your router, but if your laptop is Vista, then everything should have set up automatically when a connection to your router was found. Lokk in the routers DHCP clients and look to see if all your pc's and the Xbox is listed and given IP addresses.
Jun 26, 2007 | Belkin (F5D9230-4) Wireless Router...
Microsoft Xbox 360 Console Logo
24 people viewed this question
Top Microsoft Video Game Consoles & Games Experts
marley mcelhinney
Tre Elkins
Martin Murray
Are you a Microsoft Video Game Console and Game Expert? Answer questions, earn points and help others
