Question about Kenmore Dishwashers
My dishwasher doesn't distribute water. And sometimes it gets stuck on the blinking green "Clean" buttion.
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. If the clean light flashes, pauses, and then repeats. When the dishwasher doesn't sense a water temperature increase, it stops working and locks the functions (clean light flashes, all buttons are non responsive). It does this as a safety in case the element is broken and feeding electrical current into the water.
To resolve this you will have to reset the console. Do this by closing the door and press these buttons in sequence...
-high temp wash
-heated dry
-high temp wash
-heated dry
Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on May 30, 2010
The green "clean" light is
Hi
If clean light is blinking then it may be an issue with heater circuit, door switch or wash pump, please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry or Hi Temp Scrub, energy saver dry, Hi Temp Scrub, energy saver dry. Now let the unit run for 2-3 minutes and then you press the Cancel/Drain button and allow it to completely drain and reset. If this doesn't work then it's an issue with the wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. You'll have to check the heater using a multimeter; the meter should read between 3000 to 3300 ohms (Use multimeter on Rx1 ohm setting). If heater is fine then make sure water pressure is optimum and fill valve is working fine. Hope this helps... Please post back if you need more information.
Daniel
Aug 14, 2011 | Dishwashers
Green clean dishes light blinking instead not blinking. Dishes clean, but not totally dry. I removed them from dishwasher. Clean green light continues to blink after door is shut. Pushing cancel...
Hi
Daniel
Aug 04, 2011 | Kenmore Dishwashers
The green light for "clean" is blinking green and
Hello & Welcome to FixYa
Flashing clean light is reset by pressing two buttons in sequence 3-4 times, to reset your kenmore press these buttons in sequence:
High temp wash-heated dry-high temp wash-heated dry
Please get back to me if you have any other questions.
Kevin
Mar 07, 2011 | Kenmore 24 in. 17482 / 17484 / 17489...
The green clean light is flashing. It will not go off even when we press cancel. The wash cycle was not completed. The model # is 665.17283400.
The green clean light means that your dishwasher isn't heating the water. Go to the link below to see how to reset the error code and check for reasons that the error happened.
http://www.appliancerepairlesson.com/dishwasher-2/dishwasher-clean-light-blinking-7-times/
Good luck
Mar 05, 2011 | Kenmore Dishwashers
Dishwasher started up....didn't notice it quit running overnight...dishes seem only half clean. The "clean" green light is blinking. Tried opening and closing and then re-starting it. Can't get...
Greetings,
there is a temp related problem..this could be in the wash cycle not letting water get hot enough or a heater failure....remove your kickplate..there is a tech sheet..it explains how to reset this blinking light.....Bruce Denton
Jan 18, 2011 | Whirlpool Dishwashers
The "clean" light is blinking - so the dishwasher isn't working.
Hi
Please check if the clean light is blinking 7 times. If yes then please reset the power to the dishwasher. After, 5 minutes check if you are still getting the same error. If yes, then it is a water heating fault. To resolve this error try pressing this reset sequence-- Heat Dry - Normal - Heat Dry - Normal or High Temp - Air Dry - High Temp - Air Dry.
If this doesn’t work then it’s an issue with the heater circuit, door switch, wash pump not pumping the water past the heater efficiently or due to lack of water to heat. Please make sure that heater is not open circuited and is heating the water efficiently. If heater is fine then make sure water pressure is optimum and fill valve is working fine.
Please post back for further assistance.
Daniel
Aug 07, 2010 | Whirlpool Dishwashers
We can't get it to cycle.... the green light next to 'clean' is flashing on the panel - can't get it to stop flashing and run??
Found it; High temp scrub--Energy saver dry---High temp scrub---Energy saver dry--press start, close door ,wait for it to reset,open door press cancel and you are ready to go.
Jul 23, 2010 | KitchenAid 24 in. KUDI01FLSS Stainless...
Blinking Green Light
This indicates that the water did not heat properly. Follow the link below for instructions on what causes this and how to reset the control so you can use the dishwasher.
Blinking Clean Light
May 31, 2010 | Whirlpool 24 in. Built-In Dishwasher w/...
Whirlpool quiet partner I won't run just keeps blinking
is the cean light blinking 7 times and then repaeating?? If so this is a water heating fault and means that the computer sensed that the water temp didnt rise just 3deg in the last main wash cycle. If its not blinking 7times then repeat, it sounds like the user interface (membrane switches) have failed. Let me know more and i can help.
Apr 19, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Green clean light keeps blinking
HI, Same thing happened to me today and Sears more than willing to charge me 200.00 for a 1 year service agreement. I found the answer on askmehelpdesk.com and the answer is: To reset a Kenmore Ultra Wash elite series dishwasher (stuck on clean) simply push heated/dry then normal wash and do the same thing again. Panel will reset itself and it hopefully will run normally again. Mine did and I am rejoicing! Julie
Aug 24, 2007 | Kenmore 24 in. 16302 Built-in Dishwasher
Dishwashers Logo
12 people viewed this question
Top Kenmore Dishwashers Experts
D. E. Hev
Adam Dower
Adam Dower
Level 1 Expert
Fred Sops
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
