Question about Kenmore Dehumidifiers
Percent humidity indicator is On and I can not get it to any other label. All else works fine. Model is 580.54501 50.
  • 713 Answers
Hi,the problem is actually a setting problem,the solution to your problem is in the manual of your device,i will implore you to take your time,and go through your manual carefully to get the actual setting that will solve the problem.
Thanks and take care
Posted on May 30, 2010
  • llewdac May 30, 2010
    I have read manual thoroughly and have not found a solutioin?
  • llewdac May 31, 2010
    I have read the manual thoroughly twice and nothing in there has helped this problem.
Followed turn on instructions in manual.CO display 2 days. continually. Unit gets Very warm & fan runs if turned off. Have to unplug to stop. Unit used approx.3 mo in '14 & just restartd this week.
could you be mistaking the room humidity indicator for the time? reason I ask is on these one display units this happens more frequently than Id care it too , the one display shows both time and room humidity also set point humidity , the only way one can tell is on some models there is a tiny light that shows up next to labeled function , easy to miss It , also if your machine is sort of new (last few years) it has been decided that it's more efficient to let the circulation fan run all the time , regardless of room humidity . this makes it a little annoying (noise) but they do cycle the compressor to regulate the room humidity
May 28, 2015 | Dehumidifiers
My kenmore 5949 dehumidifier is not lowering the humidity in my basement. The unit is on and the fan is running, but the humidity stays at 99 percent.
Is the water tank filling up? That will verify that the unit is really functioning normally. If so, is it possible that outside air is infiltrating the space?
Aug 08, 2011 | Kenmore Dehumidifiers
I was just given a DD50PC as a gift from a friend who did not have the accompanying instruction booklet. He told me to turn the unit on and let it work. I do not know what temp to set it at. It has to...
On a dehumidifer, you set the relative humidity, not temperature. Normally the humidity should be set within 40 to 60 percent humidity.
Click on this link for a copy of the manual for your machine. www.sylvane.com/images/.../delonghi-dd50p-dehumidifier-user-manual.pdf
Hope this helps you.
Jul 01, 2011 | DeLonghi DD50P Dehumidifier
Getting humidity to 30 percent
A refrigeration type dehumidifier will not go much below 40%, just can't get the water to condensate below that at normal temperatures...
You will need to use a desiccant type unit to go to 30%..
http://www.fixya.com/support/r4662409-dehumidifier_running_but_no_water_in
heatman101
Apr 11, 2010 | Whirlpool AD35USS Dehumidifier
Our dehumidifier model #MDC-25AEN3 or MDC-45AE or MDC-65AE only dehumidifies about 1 inch in the pan. There is about 80 percent humidity so something is wrong because it should fill it up. It has worked...
There are many reasons for a dehumidifier tto not work or collect water.
Here is a tip that I wrote to help people to figure out what is going wrong with their dehumidifier.
Dehumidifier is running but no water is in bucket
heatman101
Apr 09, 2010 | Dehumidifiers
Kenmore dehumidifier M/N 580.53650200 only runs for about 1 minute, then stops. Dehumidifying level is set to minimum (40) and it's damp in the basement so I know the air is not too dry. The fan works, the...
Well to knowledge the problem 40 percent is dry. means your basement is great. humidity should be 30/50 percent 50 grows mold. also if it runs for a min the auot shut off is activating. check this first.
Manifestr
Oct 06, 2009 | Kenmore 5365 Dehumidifier
I have a Goldstar GHD30 dehumidifer that I bought used last week. It's pulling 20-30 pints of water each day out of my basement so it appears to be working. The compressor only runs for 1-2 minutes at a...
yes cycles should be longer either that or the unit is keeping close to desired humidity. Also the unit is under sized 30 pint is for 400sqft. or 20 by 20 room. humidity should be 30/50 percent check your level desired room temp is 70 degrees but its a basemnt 60 works.
Jul 28, 2009 | Goldstar DH504EL Dehumidifier
Moisture not collected
low on freon is the compressor running?
Jun 18, 2009 | DeLonghi DE400P Dehumidifier
Dehumidifiers Logo
144 people viewed this question
Top Kenmore Dehumidifiers Experts
Bill Long
Mike Squire
Are you a Kenmore Dehumidifier Expert? Answer questions, earn points and help others
