Question about Hoover U6630-900 WindTunnel Bagless Upright Vacuum
No suction the unit seems to be blowing air instead
  • Hoover Master
  • 43,501 Answers
Here is a tip that I wrote about my Bissel but I bet you have the same problem and the hose is clogged...
Bissell Bagless Upright Vacuum not working
http://www.fixya.com/support/r4387950-bissell_bagless_upright_vacuum_not
heatman101
Posted on May 31, 2010
4 Suggested Answers
  • 126 Answers
SOURCE: Hoover Steam Vac Model F5826-900
When you put the lid on the recovery tank, you have to be sure that the front of the lid is properly engaged into the two tabs on the top of the tank. With the lid installed, if you can lift the front of the lid off the tank with two fingers, then the lid is not on correctly. Also, make sure the square duct that goes into the front of the tank is in place. You have to remove this duct to install the hose for doing furniture but must replace it to go back to the floor function. By the way, the "blowing air" you refer to is normal. This is exhaust air from the motor and it is used to propel the solution onto the carpet.
Posted on Feb 19, 2008
SOURCE: No suction from base or hose attachment
I had the same problem with my Eureka vacuum cleaner. I don't have the problem with the beater bar, but I had the problem with the attachment hose not getting any suction. I found out that I was putting attachment on the wrong end of the hose. The end that you use in the front. Don't how I got that confused because it always worked before. Hope this helps with the hose part of the problem.
Glen
Posted on May 24, 2009
  • 4088 Answers
SOURCE: it seems to blow air out instead of sucking up
Remove the bag on top and the plate on the bottom. Clean out the air passages, top and bottom, looking for a clog. When it seems clear, turn on the vacuum to see if air is moving through. Don't allow a full bag to remain in place Check the brush on the bottom for string, hair, or thread caught in the bristles or bearings on either end. Hope this helps!
Posted on Mar 12, 2010
Testimonial: "it's fixed"
It seems to be blowing the dirt away instead of sucking it in?
Sounds like it has blockage somewhere in it causing low suction, therefore brush 'blows' dirt away instead.
Jan 27, 2016 | Oreck Vacuums
How do I get reverse suction with the electrolux epic 6000?
I have no idea just what reverse suction would be or how to get it from ANY vac. If you're looking at getting the blowing air from the vac instead of suction, then simply move the hose from the suction end to the exhaust end.
May 25, 2014 | Electrolux Vacuums
Hello,i have a vacuum cleaner but their is no air pressure in it
Do you mean the suction is very low? Or really none at all?
If low, there can be a hair/dust ball clogging the tube way deep. If you can remove it and the vacuum cleaner has an 'blow air' out you could connect the tube and blow the junk out possibly. The clog could be inside the unit instead.
If no suction at all then it's probably a complete disconnected tube somewhere.
Oct 06, 2013 | Oreck UPR014T XL Pro 14 Upright Vaccum...
Brought a dirt devil envision vacuum cleaner yesterday, assembled it and tried to use it. as i am running it, the dirt/dust seems to spread on the carpet/nothing seems to go in the dirt camister. The...
Fro what you say, the unit is blowing instead of sucking, There must be a pipe that is connected to the wrong outlet. Feel where there is suction instead of pressure, that is where your vacuum pipe must be connected.
Jan 30, 2011 | Dirt Devil Vacuums
My Bissell bagless vacuum does not seem to work anymore. It will start to with a suction and then instead of picking up the dirt, it appears to blow the dirt out almost in a cloud of dust and debris from...
this is caused by a dirty air filter and/or a blocked vacume hose ( most of the time the blockage is at the bend where the hose enters the floor sweeper area ) ---
remove and tap out and brush the filter ( or use a air compressor to blow out filter ).
then with the vacume on its side - remove the bottom plate ( like you were going to change the belt ) and use a coat hanger and clean out the hose between the floor sweeper and where the suction hoes attaches. this will restore your vacume to full operation.
c...
Jan 23, 2011 | Bissell 6595 Lift Off Bagless Upright...
What color is the air flow indicator supposed to be? Mine is yellow but I have no suction. I have read that some people have red, others yellow. I have cleared out all hoses and cleaned the filters with...
the unit may be experiencing something other than a blockage. Perhaps the dirt canister is not put back into place properly and the unit is sucking through there instead of through the hose.Check to see if the lid and the canister are both on the unit correctly and see what happens. I do not think that the unit is blocked up on you.
Normal air flow indicator color by the way is the same as when the unit is in the off position. The indicator is generally like a pen spring and stretches when the hose or suction is blocked off.
Good luck.
Mark
Nov 09, 2010 | Hoover Elite Rewind Bagless Upright...
Seems to **** up the dirt/dust and simply blow it out instead of capturing it inside
Most of these have an suction hose and a blow port. One blows air, one sucks air. Make sure the suction hose is on the correct port. Also, a dirty air filter will cause the same effects. The filter must be good to prevent the dirt and dust being blow around.
Nov 08, 2010 | Craftsman 17026 Wet/Dry Vacuum
Suction stopped working immediately
There is a hose on the unit. Disconnect it at both ends. Stretch it out. Look down it. If you can't see down it, rod it out.
May 28, 2009 | GE Vacuums
No suction - air blowing OUT from tube
Is the air blowing out of the pick-up tube or out of the exhaust tube on the unit? I am assuming the pick-up tube. The installer has hooked your system up to the exhaust tube on the unit. Hook up to the intake on the unit instead.
May 27, 2009 | Hoover L2310 GUV Central System Vacuum
No suction
1, Does the blower (discharge) side blow bunches of air??
Yes: Something is clogged from the bag to the hose end. Try blowing out the hose from the discharge side.
Or: The bag is not properly seated. Make sure that the plastic piece is properly inserted into the bag, and properly aligned and locked in place with the suction intake.
No: Something is wrong in the motor/fan assembly.
2: The hose has a plastic cover on the end farthest from the unit. Make sure that this cover is closed. If it is open, your suction will go way down.
Feb 23, 2008 | Kenmore 23313 Whispertone Bagged Canister...
Hoover U6630-900 WindTunnel Bagless Upright Vacuum Logo
339 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
