Question about Craftsman Garden
Have craftsman model 917.255581. replaced battery main cable,selenoid,30 amp fuse,ignition switch, starter and cable. won't even click to start. tried to jump and received a uhh, as well as a huge spark. please advise.
  • samuel sample May 30, 2010
    helpful, continued to ask follow up question.
  • 1,675 Answers
Hi this sounds like you have had a major short in the system, as you have said you have changed the ignition over but what about the wires connected to the plug that fits to the back of the ignition itself? if you have a short in the wiring you can test it by getting a well insulated pair of wide long nose pliers, and touching either side of the solenoid, if that then turns over ( make sure ignition is to the on position ) you will have to replace the wiring in the plug to the ignition itself, i myself have had a similar fault on a ACTO and i had to re-wire the whole thing as it just would not turn over only from the solenoid being shorted...hope this helps
Posted on May 30, 2010
    hey steve slamminsa209 here
    did what you said about using the long nosed pliers ans touched the solenoid, it tried to start so that means my kill switch is working, but it still won't start. Can you advise me from there? Thanks man.
  • steve morris
    steve morris May 30, 2010
    hi there are a couple of things to check, one of them is a bit of a pain, obvious one will be to remove the spark plug, and put it against an earthed part of the engine ( being on a small ht lead you might need assistance from someone to carry out this bit ) whilst shorting the solenoid to turn it over, see if you have a spark at all, if not, ( this is the bit that's a pain ) remove the top cover on the engine, there you will have a rotary type thing that the starter turns ( will have teeth around the outside ) in the center there is a nut that will have to come off, ( this bit is the next pain bit ) then you have to somehow pull the rotary thing off and it ain't easy, not if you haven't got a puller, do not do what i did hit it from underneath as i damaged a magnet when i did it, when you find a way of removing the rotary bit, there you will find a copper coiled section you need to check this for any burns and brakes in the wire, be careful also, this has a small wire leading the the coil and is easily broken also check the 2 wires leading to the coil so that's the hard bit done, also if you do get a spark this will be fuel starvation you will need to clean carb with some brake cleaner this normally sorts that out, just a foot note..have a look on the rotary bit and check to make sure that the magnetic contact area ( you will see this as it is different from the rest of the rotary bit ) is not gummed up with dirt as this will stop the spark plug sparking.....ps make sure you don't wear a watch while doing this as the magnets are rather strong lol..
A 2003 Yamaha 650 V Star Just home from repair shop. Started, ran about 45 miles. It stopped. Pushed starter button, NOTHING. Will not even turn over. No noises, clicking, nothing at all.
Hi, Stuart before testing any electrical component in the Starter Circuit it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test because your battery may have 12.5 volts or more but little or zero amps causing the battery to be faulty and must be replaced, especially "AGM" batteries.
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter.
4. Bank angle sensor needs a reset or is faulty.
5. FOB battery low or dead.
6. Faulty ignition switch.
7. Faulty starter button.
8. Faulty kickstand or clutch pull in switch/sensor.
9. Security alarm needs a reset.
10. Starter relay, solenoid or starter circuit wiring faulty.
11. Starter armature or field coils have failed.
12. Main fuse or circuit breaker may be blown or faulty.
13. The electric starter is working but starter clutch has failed.
14. Check for engine trouble codes.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
VStar 650 won start
What to do When Your Motorcycle Won Start
Yamaha XVS650 Service Manual
OEM parts for Yamaha
YAMAHA XVS650 Owner Manual
Apr 08, 2017 | Yamaha Motorcycles
Power will not come on when ignition is turned to start
Hi, Steve and the usual suspects are:
3. Discharged battery, needs to be 12.5 volts or better and be able to pass a load test if necessary, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Bank angle sensor tripped and ignition/light key switch not cycled to the "OFF" position and then back to the "ON" position.
5. Faulty starter button/switch.
6. Faulty kickstand or clutch pull in switch/sensor.
7. Security alarm needs a reset.
8. Starter control circuit, relay, or solenoid faulty.
9. Main fuse or circuit breaker may be blown or faulty.
10. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
Steps to Take When Your Motorcycle Won Start Dennis Kirk Powersports Blog
TROUBLE SHOOTING
troubleshoot motorcycle not starting
May 28, 2016 | Power Motorcycles
My 2001 PT cruiser will not start. Replaced starter, battery good, get no click when turning key to start
try to jump the starter whit a wire a the selenoid if that wok posible problem whit range sensor , fuse or the ignition switch
Mar 14, 2015 | 2001 Chrysler PT Cruiser
Ignition problem
Check if the small wire on the starter has power with the key held in crank position. If battery voltage there, either bad battery cables or connections, or the starter solenoid has a malfunction. If no power when key held in start, it could be the safety switch (a clutch interlock switch on manual transmissions, or a park/neutral switch on automatics). You may need a wiring diagram to see the start circuit from ignition switch to the starter solenoid-some have a start relay in that circuit.
Find wiring diagrams at http://www.bbbind.com/technical.html
Free TSB's and wiring diagrams for every make and model.
Feb 09, 2014 | Cars & Trucks
V star 950 won't start
Hi, Joe you may have fried the ECM while trying to jump it from the Jeep otherwise the usual suspects are:
3. Discharged battery, needs to be 12.5 volts or better and be able to pass a load test if necessary.
4. Check the battery terminals for damage or corrosion check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
5. Tip over sensor needs a reset.
9. Starter control circuit, relay, or solenoid faulty.
10. Main fuse or circuit breaker may be blown or faulty.
11. Check for engine trouble codes.
VStar 650 won start
Frustrated Yamaha Star Won x27 Start
2009 2012 Yamaha XVS950 Star Service Repair Manual DOWNLOAD Download...
YAMAHA XVS950A Owner Manual
May 31, 2013 | 2011 Yamaha V Star 950
Nothing turns on when I turn the ignition on
Hi, Josh before testing any electrical component in the Starter Circuit it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test because your battery may have 12.5 volts or more but little or zero amps causing the battery to be faulty and must be replaced, especially "AGM" batteries.
10. Starter relay, solenoid, starter have failed or circuit wiring faulty.
MY Katana 600 Won Start it won even Click
OEM parts for Suzuki
Suzuki GSX 600F 2000 Owner Manual
Suzuki GSX600F Service Manual Page 2
May 11, 2017 | 2002 Suzuki GSX 600 F (Katana)
Toro/Wheelhorse Tractor wont start
AS YOU HAVE CHANGED ALL OF THESE COMPONENTS TO NO AVAIL IT HAS TO BE A BREAK IN THE WIREING ITSELF, YOU WILL HAVE TO FOLLOW THE WIREING WITH A MULTI METER TO FIND WHERE THE POWER IS LOST.
May 02, 2012 | Echo Garden
Honda rebel cmx250 1986 won't start
Hi, Jenn before testing any electrical component in the Starting System it is "IMPERATIVE" that you have a fully charged battery of 12.5 volts or more and be able to pass a proper "LOAD" test if necessary, you may have a preliminary reading of 12.5 volts or more but little or zero amperage, the battery is faulty and must be replaced. AGM type batteries fall into this scenario more so than lead acid batteries.
8. Faulty kickstand, clutch, neutral safety switch.
Rebel 250 won start Need help advice
What Do Check When My Motorcycle Won Start Honda Shadow Forums Shadow...
Rebel CMX250 250 1985 2009 Motorcycle Service Repair Manual Download... $10
http://www.partsfish.com/page/oem-parts-for-honda
Honda CMX250C REBEL 2007 Owner Manual
Jul 03, 2017 | Honda CMX 250 Rebel Motorcycles
Craftsman garden tractor Mod # 917.257740 blows main fuse.
Try checking the battery - make sure it is not under rated - over rated and be sure the starter it's self isn't drawing too much amperage.
the battery may need replacing and for a temp fix - put in a larger fuse - say 50 amp.
Thanks for choosing FIX Ya
Gary @ Fix Ya
Jul 06, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
It won't start
do you have power to the solenoid?? with the key on there should be 12 volts on one side of the solenoid then when you turn the key to start it should send 12 volts out the other side to the starter
Apr 28, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Garden Logo
62 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
