Question about Garden
Troy-bilt TB590 EC brush cutter Starts fine but loses power and ultimately stalls when trigger is pressed.
  • 7,482 Answers
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please do not forget to rate me,
Thanks,Good Luck, I hope this helped
Posted on May 30, 2010
Runs great, blower and trimmer heads will not turn/work. Tried using the blower attachment and the fan turned very slow
Contact the consumer desk.
TB22 EC Curved Shaft String Trimmer by Troy-Bilt
www.troybilt.com/.../troybilt/TB22EC-trimmer
Troy?Bilt Products
Rating: 3.7 - ‎232 votes - ‎$99.99 - ‎In stock
25cc, 2-Cycle Gas Trimmer / Attachment-Capable Design ... The TB22 EC gas string trimmer is both JumpStart™ and TrimmerPlus® attachment capable, making ...
Gas Trimmer ' TB635 4-Cycle Curved Shaft ... - Troy-Bilt
www.troybilt.com/.../troybilt/tb35-ec-curve-shaft-gas-...
Troy?Bilt Products
Rating: 3.3 - ‎32 votes - ‎$179.99 - ‎In stock
The TB635 EC curved shaft gas trimmer with SpringAssist™ technology features the new Click N Trim™ bump head, making line replacement easier than ever. ..... next one they put on - will only run for about 4 seconds. they've had for about 2 ... Both String Trimmer and Edger work great, easy to start and very low vibration.
Dec 09, 2015 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
Troy-Bilt Pony TB 465SS need to lock shaft to remove bolt extender to replace head with brush cutter head. Please help & Thank you.
Simple solution. Contact Troy-Bilt company. I am sure customer service would be more than willing to help.
Jun 02, 2015 | Troy-Bilt Garden
Troy-Bilt Tb575 Ec
  1. Replace carb or,
  2. Overhaul carb or,
  3. Try one of the new "on-engine" carb cleaner-solvent kits which are available at most auto parts stores.
I've never tried one of these kits so I don't know if they actually work, or are just another marketing "pretty face!"
Jun 30, 2014 | Troy-Bilt Tb575 Ec 17-inch 29cc 4-cycle...
Troy bilt G C 720 manual
I have a new troy built garden cultivator (modelGC720). It won't turn and the motor stalls when the trigger is pulled. Should I return it or is there a easy fix ?
Feb 13, 2013 | Troy-Bilt Troy Bilt Gc720 Trimmer Plus...
Troy bilt rototiller stalls when opening choke
The carburetor will need to be cleaned very good. New needle valve maybe float and new gaskets That should take care of the problem.
Apr 20, 2010 | Troy-Bilt Pony Garden Tiller
Pressure washer sputters and stalls when trigger is engaged
Hi k2times01
It is a always a good idea to clean out the gas tank and use new fuel, however, this sounds like an RPM problem. Try adjusting the RPM up a tad and see if it runs better when you load it. If the RPM isn't the problem, you may have to clean the carburetor thoroughly.
Jul 15, 2009 | Garden
Engine stalls when engaging cultivator tines
im 99 percent sure all you have to do is get the carburator cleaned out.
Jun 28, 2009 | Troy-Bilt Garden
Garden Logo
346 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
