How to get back off to put belt on samsung b1445s washing machine
Hi
The belt snapped on my Samsung B1445s washing machine.
I got into the machine by taking the lid off but can't see any panel at the back I could take off to fit the new belt. I could fit it from the top but the new belt's too tight so I need to get better access.
Any ideas?
    Scholar:
  • 116 Answers
See if the motor has adjustment , ie a slotted fixing hole, slacken the fixing bolts slightly and motor may move up and down to give adjustment, put the belt on and then put some tension on the belt once fitted by moving the motor down and tightening the motor bolts at the same time.
Or if no adjustment put the belt on the motor spindle first and then the drum by turning the drum as the belt is eased onto it.
Posted on Apr 08, 2008
SOURCE:
I have a new washer samsung I start it to wash put it's not spinning, I put it on spin and the water starts running out so why it won't spin to wash
look at the back of the machine you might find that the drive belt has snapped or has just been on an uneven sin cycle and come off eric
Dec 26, 2017 | Samsung Washing Machines
I have a 13kg Samsung wobble, its led panel works but the machine does not wobble or spin at all. Only thing it does it drains water well. Any solution or defective part that needs to be replaced. James
Sounds like your belt snapped or come off try to open up the back and you should see the belt and pulleys just simply put the belt over the pulleys a little bit then turn pulley and belt will slip rite on
Jul 28, 2014 | Washing Machines
I have a problem with a Samsung washer b1445s its leaks water from the intenal depenser tray, from the spare water inlet for hot water (not used cold fill only), it only leaks when filling for rinsing...
There can be a leak on the section where the hot water line inlet is connected. You can plug this hole using various types of fixers available in any hardware stores which can solve the issue.Removal and fitting back is the most important part as care must be taken to mark all parts removed..
Jan 06, 2012 | Kenmore Washing Machines
Hi! My 7kg Samsung J843 Front Loader Washing Machine is not spinning at all. Makes a whirring sound but no movement. Any tips?
Hi, I've had this problem before. It was a while ago but it was either a broken belt or the belt had slipped from the correct position and needed to be put back on. It was under warranty and a service tech fixed it.
May 08, 2011 | Samsung WF337AA Front Load Washer
Noise in spin cycle drum not turning
If you hear the dryer motor turning, then you probably need to replace the belt. This isn't difficult, but does require taking cover panels off the back on most models. Open up the cover panels at the back and see if you can tell what's going on. If the belt snapped it should be very obvious.
Aug 23, 2010 | Samsung Washing Machines
Replace belt j845 samsung front loader washing machine. how do i get replacement belt on as back and both sides of machine is one piece of metal
There is no belt on a front loader washing machine. The way the drum spins is by a stator in the back of the unit.
Dec 29, 2009 | Samsung WF337AA Front Load Washer
How to replace the belt on a Samsung J845 front loader washing machine
Its on the back of machine and after you remove the back cover plate youll see that its very easy to install the new one.You shouldnt have to use any tools to put on the new belt.Just loop it around the motor pulley and around the large tub pulley that you see right in front of you.It may even appear to be too tight while your winding it on the pulleys but its not .
May 20, 2008 | Washing Machines
Samsung b1445s washing machine
hELLO
HAD THE SAME PROBLEM LAST WEEKEND! THE BELT HAS TO BE SO TIGHT TO GET THE WORK DONE
PUT THE BELT ON THE BUTTOM SMALL WHEEL OF THE MOTOR THEN YOU VERY SLOWLY PUT IT ON THE BIG WHEEL BY TURNING SIMOULTANISLY THE BIG WHEEL CLOCKWISE, IT SHOULD I YOU ARE CAREFULL POP_UP AFTER A SEMI TURN,THAN SLOWLY TURN WITH YOUR HANDS THE WEEL 2 OR 3 TIMES AROUND SO THE BELT CAN FIND ITS PLACE;
hOPE YOU GET IT DONE
GREETS FROM bELGIUM
MY MAIL [email protected]
Apr 08, 2008 | Washing Machines
Washing Machines Logo
416 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
